7.1 speaker mismatch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-12-2012, 08:57 PM - Thread Starter
Teletodd's Avatar
Recently replaced old Klh fronts and center with pioneers. Thinking about getting a 7.1 receiver and using the Klh fronts and sats as part of the 7.1. Will that mismatch with the pioneers work?
Teletodd is offline
post #2 of 5 Old 12-12-2012, 09:06 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
As long as the fronts and center are Pioneer, it can work for now.
5.1 would be enough for me - however, your call.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #3 of 5 Old 12-12-2012, 10:28 PM - Thread Starter
Teletodd's Avatar
I understand that the extra set of speakers in a 7.1 set up are basically a second set of front speakers. Assuming I'm correct, if the fronts should match the center, wouldn't a second set of fronts have to match also? Or, are the extra set merely a second set of back surround speakers which handle mostly sound effects and hence matching is less critical?
Teletodd is offline
post #4 of 5 Old 12-13-2012, 01:13 AM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
No, rears as well as surrounds.
lespurgeon is offline
post #5 of 5 Old 12-13-2012, 01:41 AM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
A typical 7.x setup is Front L/R, Center, Surround L/R, and Surround Back L/R. So. In your case, you would have the three Pioneer up front and can use the former KLH Fronts as Surround L/R and the KLH satellites as rear surrounds. The only reason to put the biggest KLH speakers in the surround position is because 90% of content is still 5.x and having your BEST speakers in these places gives you a solid core 5.x setup. Matching the back four speakers to the front isn't that critical. In a DSX, Neo-X setup you have the option of only running a pair of surrounds along with 5 speakers up front in either a height or wide configuration. That will also depend on what your receiver will let you do as far as assigning amps goes. My receiver has fully assignable amp sections, so I could assign two sets of speakers to Front L/R but I would have to tinker with speaker placement in order to get them to sound decent because of differences in distance from listening position if they aren't the same.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
Reply Speakers
