What would you get for $100-150? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 12-12-2012, 10:42 PM - Thread Starter
EXreaction's Avatar
My speakers took to a fiery death and I am looking for some new ones.
I'm looking for some good clear sounding speakers for my desktop; for music, movies, and video games. RCA + 3.5mm inputs would be nice as I may end up using them for other things if they are good.
A 2.0 or 2.1 set would be nice and I'd prefer not overly large satellites as I do not have a ton of space right now.
I'd prefer not to spend more than $150 or so (on Amazon).
I've done a bit of looking around and am not at all sure what to go with. I had seen the Audioengine 2 recommended a few times but I'm not sure whether or not it's worth it over something that's half the price.
EDIT: Amazon choice is because I have about $200 worth of Amazon gift cards to use.
EXreaction is offline
post #2 of 21 Old 12-12-2012, 11:21 PM
Ben_Tech's Avatar
Dayton Audio DTA-1 Class T Digital Mini Amplifier $34
...and ....
Pioneer SP-BS22-LR $129
...is about the best combo for that kind of money.
My Blog - Ask Toy Tech
Ben_Tech is offline
post #3 of 21 Old 12-12-2012, 11:30 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
I would say the BS21's are a better deal, for only $50pr right now
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405
Not sure how necessary the amazon need is, but that's a crazy deal for a pair of real speakers.
Jay1 is offline
post #4 of 21 Old 12-12-2012, 11:46 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 756
...and ....
I actually like the Lepai 2020A+ better than the DTA-1 because it has one set of RCA inputs and one 3.5mm stereo input, plus bass and treble controls.
I've purchased both and prefer the Lepai.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=310-300
Afro GT
afrogt is online now
post #5 of 21 Old 12-13-2012, 10:43 AM - Thread Starter
EXreaction's Avatar
As far as Amazon goes, I have about $200 in gift cards from Amazon I wish to use.
Thanks for the suggestions so far. I've seen some of those recommended before (that's a good thing to me smile.gif). How would those compare to say the Audioengine 2 set?
post #6 of 21 Old 12-13-2012, 09:38 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3093
The Pioneer BS22s are much better than the BS21s. The BS41s are another choice within your budget. If you could squeeze $19 plus the aforementioned gift cards you could get the Cambridge S30s.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is online now
post #7 of 21 Old 12-13-2012, 09:48 PM - Thread Starter
EXreaction's Avatar
I do not plan on using all of the amount on the gift cards on these speakers (I've actually spent some of the aforementioned $200 on xmas gifts for others).
I do not wish to spend more than $150 unless there is a very significant improvement for even the slightest amount more.
post #8 of 21 Old 12-13-2012, 09:48 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Yes the BS22 is a real nice option - and will go down lower than the BS21
The BS22 measured -3db at 63 hz > and measured lower than the BS41.
For a little more money - the Cambridge S30 is my preference.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #9 of 21 Old 12-13-2012, 10:25 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
The Audioengine has limited bass response, and the midrange can be weak.
Who AM I
zieglj01 is offline
post #10 of 21 Old 12-13-2012, 10:40 PM - Thread Starter
EXreaction's Avatar
I am thinking about:
http://www.amazon.com/Pioneer-SP-BS22-LR-Designed-Bookshelf-Loudspeakers/dp/B008NCD2LG
http://www.amazon.com/LP-2020A-Lepai-Tripath-Class-T-Amplifier/dp/B0049P6OTI
Any other/final opinions?
post #11 of 21 Old 12-13-2012, 10:40 PM
bradymartin's Avatar
Quoted: 28 Post(s)
for my computer desktop setup i have that lepai amp and a pair of bs21s. pllenty of power more than i need. the speakers sound great, very clear natural sound. i have not heard the new bs22s though.
if you end up with the lepai though, you should upgrade the power supply to a 5 amp. the one it comes with is weak and will cut off power too early.
bradymartin is offline
post #12 of 21 Old 12-13-2012, 10:48 PM - Thread Starter
EXreaction's Avatar
Does that only happen when the volume is turned up rather loud?
What happens exactly in that case, does it just shut off or not get any louder as you turn the volume up or what?
post #13 of 21 Old 12-13-2012, 11:00 PM
Quoted: 28 Post(s)
it happens when you turn it up too loud, the sound is shut off, then you have to turn volume down to get sound again. i had a 5 amp computer monitor power supply that i wasnt using and replaced the stock one. now that doesnt happen. believe me that little amp puts out plenty of power. i even tried it on some towers from my home theater setup, the pioneer fs51s and worked great.
post #14 of 21 Old 12-14-2012, 10:08 AM - Thread Starter
EXreaction's Avatar
I see, I will keep that in mind if I ever run into that issue. In an apartment building you have to keep things a bit on the quiet side, so I might not even get it that loud. smile.gif
post #15 of 21 Old 12-14-2012, 10:21 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
I use the Audioengine 2 speakers with my PC. They have no bass to speak of, but I don't understand the comment that the midrange can be weak. That is not true in my experience, and is certainly the opposite of what the Stereophile reviewer had to say about them. The midrange is excellent.
I use a cheap Sony 12" subwoofer with them; it is adequate for the limited space and low volume I need.
commsysman is offline
post #16 of 21 Old 12-14-2012, 08:59 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3093
I think this would be a nice budget setup since you can't go with the Cambridge speakers (the S30s are a definite step up in quality).
post #17 of 21 Old 12-15-2012, 02:56 PM - Thread Starter
EXreaction's Avatar
Anyone heard of these before?
http://www.amazon.com/JBL-ES20-High-Performance-Bookshelf-Speakers/dp/B00167340E
They are on sale for a good discount according to Amazon, now the same price as the bs22 (although I do not really trust Amazon's list price).
post #18 of 21 Old 12-15-2012, 08:17 PM
wormraper's Avatar
Quoted: 313 Post(s)
Liked: 154
The Polk Monitor 40's are on sale for $109 a pair on newegg right now
wormraper is online now
post #19 of 21 Old 01-25-2013, 11:34 AM
rswanker's Avatar
Moved
rswanker is offline
post #20 of 21 Old 01-25-2013, 12:42 PM
pitviper33's Avatar
Quoted: 267 Post(s)
Liked: 116
I own a few pairs of the Pioneer BS-21s and several of the little Dayton and Lepai class D amps. I also own a pair of Audioengine A2s with the little wedge stands that I use on my desktop. I seriously considered another Pioneer/Lepai setup for the desk, but I decided against them for the reasons below.
So... Would the Pioneers + a D-amp sound better in most applications than the A2s? Yeah probably. But on a desktop? For that I'm less sure. They're really big. And the waveguide around the tweeter pushes the CTC distance pretty wide. Extreme nearfield listening is going to put you pretty far off axis for one driver or the other. How far are the speakers going to be from your ears? As for the bass, I've found the A2s completely adequate. I think the reinforcement from my desk and monitor help.
Then there are the practical considerations. The Pioneers are seriously big for a typical desktop setup. Do you have room to put them on your desk? Far enough from your head to avoid being far off axis for one driver? Without putting their rear ports all the way against the wall? I don't, but maybe you do. The A2s are signal sensing and go into a low power usage mode when they aren't being used. Will you leave the Lepai amplifier on all the time (with its overly bright blue light ring), or will you turn it off when you aren't using it? For me, I was pretty sure I'd end up leaving it off much of the time and have no sound at all. Then when I did turn it on, I'd forget to turn it back off when I walked away from the computer.
And last is looks. I like the look of the Pioneers, but them plus an amplifier on my already crowded desk would have just looked silly. And the A2s are the cutest little speaker I've ever seen. In person they just look fantastic. Their finish and level of visual refinement is a definite step above the Pioneers.
Anyway, that's how I made my decision for desktop sound. I hope it helps. Good luck making yours.
pitviper33 is online now
post #21 of 21 Old 01-25-2013, 01:05 PM - Thread Starter
EXreaction's Avatar
I did end up buying the Pioneer BS-22s and that Lepai amp. Now the price is down to $90 for the speakers, which Amazon was kind enough to match the price for, making this a really good deal for me.
The amp did end up failing within a couple weeks, but I have a replacement now and hopefully it will be fine.
The speakers did end up being a bit larger than I expected and don't fit the best in the space I have, but I won't have to deal with that for too long before I get some nicer space to use them in. I guess I wouldn't recommend them for most users desktop use for the same reason you explained.
They do sound fantastic, far better than any speakers I've had myself before, I can't wait to use them in a nice HT setup.
Reply Speakers
