Center channel for Nxg Pro 4.1 Satellite Speakers?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 12-14-2012, 11:24 PM - Thread Starter
K-Dubb's Avatar
Quoted: 16 Post(s)
Hi,
I just ordered 4 of these for a friend with budget, as well as a wife who wants the speakers to be small. He will be using these for L/R/SR/SL.
Here is a link:
http://www.amazon.com/dp/B0044UHVOK/ref=pe_175190_21431760_3p_M3T1_ST1_dp_1
I have heard really good things about them. The problem is, they are discontinued, and the matching center channel cannot be found anywhere. Now i know it is recommended to match the center with the fronts, but I probably won't be able to do it in this case. What do i need to do to find a center channel that will work well with these speakers? Any recommendations?
K-Dubb is offline
post #2 of 9 Old 12-14-2012, 11:32 PM
zieglj01's Avatar
Quoted: 943 Post(s)
Liked: 846
Buy another Pro 4.1 and use it as a center channel.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #3 of 9 Old 12-15-2012, 04:50 PM - Thread Starter
K-Dubb's Avatar
Quoted: 16 Post(s)
I would prefer a center channel type speaker.
K-Dubb is offline
post #4 of 9 Old 12-15-2012, 05:11 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Why? An identical speaker is better if the space will accommodate it.
rick240 is offline
post #5 of 9 Old 12-15-2012, 05:18 PM
zieglj01's Avatar
Quoted: 943 Post(s)
Liked: 846
^^^ This
Who AM I
zieglj01 is offline
post #6 of 9 Old 12-15-2012, 05:50 PM - Thread Starter
K-Dubb's Avatar
Quoted: 16 Post(s)
Can you explain why other than the preferred of the center matching L/R? I guess I was just thinking for dialog 2 woofers would be better, and clearer than 1.
K-Dubb is offline
post #7 of 9 Old 12-15-2012, 05:56 PM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
The best match to a pair of speakers is another identical one.
"Standard" centre speakers are a compromise because most people can not accommodate the height of another identical speaker. To do it you typically need either:
- an acoustically transparent screen
- a tall space in the middle of the TV stand (you may have this)
- a really short speaker (you do have this - hopefully short enough)
In my case I have co-axial drivers so I am able to lay my centre on its side.
"Standard" M-T-M designs have off axis lobing issues in wide rooms.
rick240 is offline
post #8 of 9 Old 12-15-2012, 06:56 PM
zieglj01's Avatar
Quoted: 943 Post(s)
Liked: 846
Not really, no guarantee there.
A good speaker is a good speaker.
Who AM I
zieglj01 is offline
post #9 of 9 Old 12-15-2012, 10:27 PM - Thread Starter
K-Dubb's Avatar
Quoted: 16 Post(s)
Thanks for the info! I really appreciate it. So if this speaker can't be stood up as a center, then it is probably not a good idea. I think the spot it is going it may have to lay on its side.
K-Dubb is offline
Reply Speakers
