How high should my speakers be mounted? - AVS Forum | Home Theater Discussions And Reviews
Old 12-16-2012, 07:53 AM - Thread Starter
belfert's Avatar
I took advantage of Amazon's sale on JBL speakers yesterday and bought the ES20 bookshelf speakers along with the subwoofer and center channel speaker.
How high should I mount the bookshelf speakers as my front speakers? I've read that the tweeter should be at ear level when seated which is around 41" for me. If I put the speakers on top of 31" speaker stands would that be too high? Would 24" stands work better? I am looking to get either the Sanus BF31B or BF24B stands depending on the height. (Are there better stand out there?)
belfert is offline
Old 12-16-2012, 11:04 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
24" stands are good.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
Old 12-16-2012, 03:31 PM
JimWilson's Avatar
Quoted: 1268 Post(s)
Liked: 1564
I use 28-30" stands myself.
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is offline
Old 12-16-2012, 04:06 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
I try to keep the tweeters of the LCR speakers as close to the same height as possible. Curious what others think.
sdg4vfx is offline
Old 12-16-2012, 04:35 PM
Bill Fitzmaurice's Avatar
Liked: 4631
There's no need. Your visual cues over-ride audio cues, so when you see the screen your brain tells your ears that's where the center is located, even though it's not.
Not if the tweeters are 10" from the bottom of the cabinet.
Bill Fitzmaurice is offline
Old 12-16-2012, 05:08 PM - Thread Starter
belfert's Avatar
The tweeters are about 10" from the bottom of the cabinet so I guess the 31" stands would work. I'm just wondering if they would be too high and look ridiculous or something?
belfert is offline
Old 12-16-2012, 07:17 PM
Liked: 4631
The Fernando placement: "I don't care if they sound good, just as long as they look good."
