Best 2.0 setup less than $200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-16-2012, 10:40 PM - Thread Starter
Syncho's Avatar
I'm planning to hook it up to my PC. I also live in Canada, so it may be harder for me to acquire certain speakers and amps.
Syncho is offline
post #2 of 6 Old 12-17-2012, 12:21 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
Ouch, tight budget. If I were you I would be looking at powered monitors, maybe some used ones. I would give Ebay a close look, and, if you are near a city, craigslist too. Behringer, Mackie, KRK, M-Audio, Alesis, some brands to keep an eye open for. If you have patience you can also snag a great deal.
shadyJ is offline
post #3 of 6 Old 12-17-2012, 08:21 AM
bjaurelio's Avatar
I second the powered monitors suggestion for a 2.0 setup connected to a computer.
bjaurelio is offline
post #4 of 6 Old 12-18-2012, 10:04 PM - Thread Starter
Syncho's Avatar
Do you guys consider Audioengine A2s to be better than the M-Audio AV40?
Syncho is offline
post #5 of 6 Old 12-18-2012, 10:42 PM
All-Or-Nothing's Avatar
All-Or-Nothing is offline
post #6 of 6 Old 12-19-2012, 07:25 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Find something used at Canuck Audio Mart...
...that (or kijiji) is where you will find the best value for $200.
rick240 is offline
Reply Speakers
