Micro speakers vs bookshelf vs towers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-17-2012, 02:40 PM - Thread Starter
IHaveAMullet's Avatar
Hi Guys, extremely newb question here.
Assuming all three are paired with a sub:
What makes one choice better than the others? Is it simply that a larger driver will play lower? If the sub is placed properly this would be a moot point wouldn't it?
The reason I ask is that for room aesthetics I'm drawn towards the micro systems (Kef 5005.2, klipsch quintet, etc), but these alone only play down to ~100Hz while larger bookshelfs & towers will play down to 40Hz.
With a properly placed sub & crossover won't both options sound equally as good? Trying to wrap my head around why the towers are a better option for pure audiophiles.
IHaveAMullet is offline
post #2 of 14 Old 12-17-2012, 02:43 PM
Dave1027's Avatar
Quoted: 12 Post(s)
It's much harder to make micro speakers properly cover the ranges not covered by the sub such as the mid-bass. Often what you end up with is a thin sound with a pronounced bump on the bottom from the sub.
I like the compromise of the bookshelf that has a decent size woofer coupled with the sub.
BIC DV62si speaker mod for warm musical sound. PM me for info.
Dave1027 is offline
post #3 of 14 Old 12-17-2012, 02:47 PM - Thread Starter
Ok that makes sense. So what is the difference between a bookshelf with a single 6.5" driver vs a tower with 3 - 6.5" drivers (for example)?
post #4 of 14 Old 12-17-2012, 03:40 PM
Dave1027's Avatar
Quoted: 12 Post(s)
Bigger box usually means better bass. More woofers means more low frequency air can be moved.
Dave1027 is offline
post #5 of 14 Old 12-17-2012, 04:06 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Read this post: http://www.avsforum.com/t/1426842/cross-over-freq-with-sat-sub#post_22354745
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #6 of 14 Old 12-17-2012, 05:13 PM
noisebeam's Avatar
Quoted: 16 Post(s)
For me I'd ask the question differently.
For a home sized 2.1 system crossed at 80hz to a capable sub what is the smallest L/R speaker cabinet size beyond which moving to a larger size has diminishing results in system performance? What are the tradeoffs?
noisebeam is offline
post #7 of 14 Old 12-17-2012, 05:41 PM
JerryLove's Avatar
Liked: 79
A potential down-side of a large-drive 2-way design can be resolution near the crossover with the tweeter.
If we compare the Infinity P363 to the P163 to the P143 we find the following.
The P363 , though still needing a sub, is the best of all worlds (when looking at these 3 speakers).
The P143, using the same tweeter and midrange as the 363, requires an unfortunately high crossover with the sub (it's only rated to 100Hz).
The P163 brings the sub crossover point down where we'd like to see it (though obviously not as low as the 363), but sacrifices midrange clarity for this extension, because of the large size of the midrange cone.
In this case: the argument for the P363 is the best combination of midrange and sub-integration.
JerryLove is offline
post #8 of 14 Old 12-17-2012, 08:21 PM
noisebeam's Avatar
Quoted: 16 Post(s)
Seems the P153 would fit nicely between too small 4" driver of the 143 and the too large 6" driver of the 163
post #9 of 14 Old 12-17-2012, 08:46 PM
JerryLove's Avatar
Liked: 79
Yes.
Though in the end: I'm a fan of the 163 out of the 1 series... but it's subjective.
post #10 of 14 Old 12-17-2012, 08:56 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #11 of 14 Old 12-17-2012, 09:07 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
It is not just about a cabinet - it comes down to design and engineering as a whole.
I have a so-called small bookshelf speaker, that can crossover at 80 hz.
I have owned bookshelf speakers, with a bigger 5 1/4 and 6 inch woofer, that would
have trouble with that.
Who AM I
zieglj01 is offline
post #12 of 14 Old 12-17-2012, 09:25 PM
noisebeam's Avatar
Quoted: 16 Post(s)
Of course, but there are limits, there is a too small.
What is this 'so called small bookshelf'?
post #13 of 14 Old 12-17-2012, 09:37 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Cambridge Audio S30
Who AM I
zieglj01 is offline
post #14 of 14 Old 12-17-2012, 09:40 PM
JerryLove's Avatar
Liked: 79
You can cross a pair of Altec Lansing computer speakers at 80Hz as long as you keep the SPL low enough.
Given a driver surface, a driver technology (cone vs horn vs ribbon; closed vs ported vs TL, vs MWTL (and knowing box tuning)) frequency and SPL we can determine an X-Max. (given all but one you can determine the missing one).
As such: though a 1" driver can be vibrated at 20Hz, getting real SPL would require that it move linear feet to accomplish it.
So yes. A JL 10W7 will get lower, louder than say you average HK 10" because it has a higher excursion. And a Salk H2-TL will go lower than an H2 because of the MWTL boosting the low end. But there are still practical limits; and generally the drivers that will perform better at a given size also cost more.
Reply Speakers
