No room for a center channel! Pics inside... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 12-17-2012, 05:21 PM - Thread Starter
Turick's Avatar
Hi all...
I don't have room for a center channel speaker!
I'm not sure what to do... Is it possible to put two speakers on either side of the TV and run them both through the center channel? Am I going to be stuck with running a phantom center? Any advice would be appreciated!
Turick is offline
post #2 of 17 Old 12-17-2012, 07:05 PM
hashey's Avatar
Could you mount one flush with the ceiling above the tv? The t. Already looks obstructed so below isn't an option...
hashey is offline
post #3 of 17 Old 12-17-2012, 10:12 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Wow! I cant believe you have to watch football with all that stuff blocking the tv...
Anyway, I would mount a pair of monitor speakers on the wood pillar trim on each side of the fireplace, using mounts like this
http://www.amazon.com/VideoSecu-Clamping-Mounting-Surrounding-3LH/dp/B000X9O8SI/ref=sr_1_10?s=electronics&ie=UTF8&qid=1355807161&sr=1-10&keywords=speaker+wall+mounts
That pushes the speakers out from the wall, and allows you to angle them in for better imaging. You should be able to get solid stereo imaging, which will make the lack of a center less of an issue. Yes your receiver will down mix the center to the L/R, but it will only sound good if you have good imaging from your stereo pair.
If you cant place speakers on the floor, you really dont have any other options for decent sound...
Jay1 is offline
post #4 of 17 Old 12-18-2012, 06:46 AM - Thread Starter
Turick's Avatar
I always thought that the distance between the left and right speakers should be the same as the distance from the primary listening location to the TV. If that is true, then the speakers end up being quite a bit further apart than the wood trim on either side of the fireplace. I would have to put them on the ledge that runs the length of the wall, probably angled down a little bit. They would probably be more or less centered in the little arched alcoves.
At that point, is it possible to put two more speakers directly on either side of the TV and run dual center channels? Or is it better to just not have the center at all?
Turick is offline
post #5 of 17 Old 12-18-2012, 08:55 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Is there not another wall that you could put the TV on?
That way you could lower the TV to a better viewing angle, have a centre speaker, and have the fireplace on while watching TV and not be staring at a fire being blinded...
Nothing wrong with looking one direction to see the TV and looking a different direction to see the fire (although you probably have the 2 directions for viewing as fire and window frown.gif).
rick240 is offline
post #6 of 17 Old 12-18-2012, 09:53 AM
Kini62's Avatar
Quoted: 1414 Post(s)
Liked: 1296
Looks like you sit pretty far from the TV. I don't think you need a center channel. Try it without.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #7 of 17 Old 12-18-2012, 10:11 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
I would abandon all hope for that room. Keep the TV and use it as a backup TV viewing room and find another room.
It's a very nice looking room. Putting up speakers anywhere will stick out like a sore thumb. Let your wife have the room.
KidHorn is offline
post #8 of 17 Old 12-18-2012, 10:34 AM
Bill Fitzmaurice's Avatar
Liked: 4630
You can, but there will be some comb filtering. It won't be severe, but it will be there. I'd start with a single speaker on one side and see how that works. With your eyes closed you'd hear the sound coming from that side, but with eyes open your visual cues will over-ride your audio cues and the sound will seem to come from the center of the screen. Our brains are hard-wired to do that.
Bill Fitzmaurice is online now
post #9 of 17 Old 12-18-2012, 10:39 AM
XStanleyX's Avatar
Liked: 1269
Since you only need a center channel when watching a movie I would put one on a stand right in front of the fireplace and move it out of the way when not in use.
Course I have no wife to keep happy. My son does that. He's not married either.
Banana plugs, quick and easy hookup.
XStanleyX is offline
post #10 of 17 Old 12-18-2012, 11:17 AM
Bazzy's Avatar
Quoted: 57 Post(s)
Liked: 37
Hi!
I have a set of brand new speakers that might work in your set up & space constraints - only problem is , I am in England! Can look into shipping them out to you if need be? They are the Celestion AVS-501's. Just trying to help!
Bazzy!
Bazzy is offline
post #11 of 17 Old 12-18-2012, 02:16 PM
Liked: 4630
I won't even watch the weather listening to the TVs internal speakers. For that matter I've never even heard those in my current TV, and I've had it for two years.
post #12 of 17 Old 12-18-2012, 02:27 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
That is sound advise and I'm not even married. LOL I cringe whenever I see a TV above a fireplace. If this room is your only option then maybe on-wall speakers. Those generally are designed to blend in with a flat panel TV and, while not the best solution, would sound better than the TV's speakers.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #13 of 17 Old 12-18-2012, 02:42 PM
Brennan.OSD's Avatar
I would do an angled in-ceiling speaker as your center channel. Probably an 8-inch.
- Brennan, OSD Audio
Brennan.OSD is offline
post #14 of 17 Old 12-18-2012, 05:24 PM
mtrot's Avatar
Quoted: 197 Post(s)
Liked: 65
Maybe I'm going blind, but where are your front L/R speakers? I can't see them in the picture.
FAMILY ROOM SYSTEM--Legacy Signature II tower speakers, PSB Image 5T tower speakers, Denon AVR-X5200W, Krell FPB 400cx, Oppo BDP-83 universal disc player, RCA HD-DVD player, Samsung HL67A 750A TV
MASTER BEDROOM--Dynaudio Audience 82 tower speakers, Outlaw LFM-1 sub, Yamaha RX-V1800 receiver, Sherbourn 5/1500A 5-channel amp, Oppo DV 980H DVD player, Panasonic DMP DT210 Blu-ray player, Panasonic 60-ST60 plasma TV.
mtrot is offline
post #15 of 17 Old 12-18-2012, 06:20 PM
Maybe inside those wreathes? Haha
post #16 of 17 Old 12-18-2012, 07:10 PM
wes182's Avatar
Quoted: 51 Post(s)
Liked: 26
You can try phantom. I messed around with it a little. Wasn't that disappointed when sitting directly in front of TV equal distance between the mains. Put the mains in the cabinet for WAF. Now, if you sit on one side of the other you may have issues as that scenario was disturbing to me.
wes182 is offline
post #17 of 17 Old 12-20-2012, 07:20 AM - Thread Starter
Turick's Avatar
This actually isn't my living room, it's a friends. They heard my audio set up (which isn't all that amazing -- some decent in wall speakers and an Outlaw LFM1-plus sub) and wanted a 5.1 set up too. But they really don't watch a terribly large amount of movies in that room -- lots of sports & news. I'm starting to think that they'll just have to run 4.1.
That being said, the budget for the LCR was originally $200 for a center and $200 for some bookshelves. So if I roll the center channel budget into the LR budget, I can spend $400 on the bookshelves... does anybody have any good recommendations at that price point?
Also, I meant to get pictures of the back walls. There isn't a lot of room to mount the rears and running audio cable is going to be a real pain. They asked if there was a wireless option, but I'm not sure. All the wireless speakers I've seen came bundled with a receiver that had a built in transmitter. Is there some external wireless transmitter I can hook up to the receiver to run the rears?
Turick is offline
Reply Speakers
