Is "Lepai LP-2020A+" and "Monitor Audio BX1" a good idea ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 12-17-2012, 05:10 PM - Thread Starter
thexecutioner15's Avatar
Hello people i am new here.
I made this thread because i need your advice about speakers, i am a big fan of Trance music (Psychedelic, Progressive) so i was thinking of buying something that plays music well.
do you believe this is a decent combination of amp and speakers ? :
Amplifier : "Lepai LP-2020A+" (20 Watt RMS per channel, 2-8ohm)
Speakers : "Monitor Audio BX1" (55hz-30khz, recommended requirements 15-70 Watt)
If not, please send me some ideas, i am a university student so keep in mind that i cant buy expensive gear (i can afford 300 euros or 400 MAX).
Thank you in advance =)
thexecutioner15 is offline
post #2 of 13 Old 12-17-2012, 05:32 PM
cyde01's Avatar
That amp will only push 6-7 watts at 8 ohms, but it may well in a very small room like a dorm or set up near field as PC speakers. If you are on a budget, check the classifieds (Ebay, Craigslist, Audiogon if that's an option) for used gear. It wouldn't be hard to find a great deal on an integrated amp or AV receiver to power those speakers. On a very tight budget, used is the way to go.
cyde01 is offline
post #3 of 13 Old 12-17-2012, 09:13 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
The Lepai does very well for producing enough volume for listening, and is a great choice for low budget. Just don't expect it to chase you out of your room smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #4 of 13 Old 12-18-2012, 06:11 PM - Thread Starter
Thank you for your advices...i believe i will start with the lepai or maybe a greater used amp.
And in the future, maybe i will buy an amplified subwoofer to power these speakers, for the finishing touch.
post #5 of 13 Old 12-18-2012, 06:24 PM
afrogt's Avatar
Quoted: 1437 Post(s)
Liked: 982
An amplified subwoofer won't power your bookshelf speakers, it'll just power the sub.
Afro GT
afrogt is offline
post #6 of 13 Old 12-18-2012, 07:26 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
I've had a Lepai amp for about a year now. While it probably doesn't push the 20wpc its advertised at it does work fairly well as long as you don't expect ear shattering sound levels - it will disappoint you. With the speakers I've used it with cranking it up to the one or two o'clock position maxes it out. Any more and clipping sets in pretty severely.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #7 of 13 Old 12-19-2012, 04:11 AM - Thread Starter
Afrogt, sorry i dont remember how i quote in forums..
http://velodyne.com/vx-11.html
if i use an RCA/TRS cable to connect my music with the subwoofer, and connect the subwoofer with the speakers, i wont have any possitive results ?
post #8 of 13 Old 12-19-2012, 04:36 AM - Thread Starter
Do you believe that at these positions the music is well played?
I don't expect amazing results from a humble amplifier like lepai, but the only thing that i fear, is that he won't be able to give me a "Standard yet enjoyfull" music experience.
Examples :
1) If volume is too low -> bass is poor and unnoticed
2) If volume is somewhat high -> You just hear noise and bizarre sounds and cranky bass
post #9 of 13 Old 12-19-2012, 07:17 AM
cel4145's Avatar
Liked: 3002
Nope. Not meant for what you are thinking. Those speaker level connections are for running speaker level connections in from an amp, and then out to the speakers.
cel4145 is offline
post #10 of 13 Old 12-19-2012, 08:55 AM - Thread Starter
So theoretically even if i buy this subwoofer, it would cooperate with the speakers only if i buy an amp that will power all three together ?
If what i wrote is correct, why somebody would buy an amped subwoofer and not a passive one.
post #11 of 13 Old 12-19-2012, 09:55 AM
cel4145's Avatar
Liked: 3002
No. The amp is not powering the subwoofer. It's a way to send the audio signal to the subwoofer using the speaker connections instead of an RCA cable.
cel4145 is offline
post #12 of 13 Old 12-19-2012, 11:29 AM
afrogt's Avatar
Liked: 982
No, not quite right. The receiver will only send redirected low frequencies to a powered sub from a dedicated subwoofer channel. It doesn't take any power from the receiver.
You buy a powered sub to save your receiver from producing the lowest frequencies. When your use your receiver to produce only the mid bass, midrange and higher frequencies it takes a strain off the amps. You'll get cleaner sound that way. Plus the amp in a powered sub is much more powerful than the amp in your receiver. You see amps in a subwoofer that are 150-500w for a single channel. You don't find receivers with that kind of power, especially when they have to drive 5-7 other speaker channels simultaneously.
Afro GT
afrogt is offline
post #13 of 13 Old 12-19-2012, 12:05 PM - Thread Starter
Afrogt my mind is blown after i read this, i thought that i knew some things about speakers ,subs and amps. But now i see that i have lots of things to learn. Thank you
Reply Speakers
