Center channel speaker stand. Where to buy? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Jay1
post #1 of 26 Old 12-17-2012, 10:04 PM - Thread Starter
srg775's Avatar
I am looking for a speaker stand for my center channel. It is an RBH MC-616C (approx 20" wide / 8" height / 9" depth and weighs 24 lbs). A simple yet good looking 12"-18" high stand would be perfect. I am having a tough time finding anywhere to buy a decent stand for less than $200.
Any recommendations on where to look would be appreciated.
srg775 is offline
post #2 of 26 Old 12-18-2012, 12:27 AM
tractng's Avatar
Quoted: 144 Post(s)
Liked: 31
I use a shelve that you buy pieces from lowes. It is a glass piece with four chrome legs.
tractng is offline
post #3 of 26 Old 12-18-2012, 12:45 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 221
Jay1 is offline
post #4 of 26 Old 12-18-2012, 04:26 AM
jeffw69's Avatar
I got mine from Crutchfield, it's a Sanus, specifically for center channel.
http://www.crutchfield.com/p_051NFC18B/Sanus-NFC18-Black.html
jeffw69 is offline
post #5 of 26 Old 12-18-2012, 05:40 AM
madhuski's Avatar
Quoted: 648 Post(s)
Liked: 351
Not to hijack the thread, but anyone know of any products designed to simply angle up a center channel?
I'm using some $1.99 doorstops from Home Depot, but looking for something classier.
thanks!
Selling in AVS Classifieds
Salk Songtower RT (RAAL)
URC MX-880 Remotes
madhuski is online now
post #6 of 26 Old 12-18-2012, 08:56 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
I suggest that you get a small bookshelf unit which can hold CDs or LPs and put it on the top.
commsysman is offline
post #7 of 26 Old 12-31-2012, 12:56 PM
havok2022's Avatar
thanks!
Auralex has some pads to angle and isolate. About $45 though.
LG 55EC9300 - MartinLogan Ethos - MartinLogan Motif X - B&W 685 S2 - B&W AWS610 - Anthem AVM60 - Parasound A31 - Parasound Zamp v3 - Oppo UDP-203
havok2022 is offline
post #8 of 26 Old 12-31-2012, 02:26 PM
commsysman's Avatar
Liked: 569
I suggest that you look at a simple bookshelf unit that can store CDs, LPs, or whatever.
post #9 of 26 Old 12-31-2012, 03:17 PM
eljaycanuck's Avatar
Quoted: 1351 Post(s)
Liked: 1964
My Paradigm CC-690 (37-1/4" (w) x 10" (h) x 16-1/2" (d), 70lbs.) sits securely on a Plateau ST-CC-17 stand, which a quick Google shows as retailing for ~$100. It should work very well for your CC speaker.
eljaycanuck is offline
post #10 of 26 Old 01-06-2013, 01:29 PM
holyindian's Avatar
Quoted: 123 Post(s)
Liked: 50
Thanks for the tip. I am looking for a center channel stand for my Definitive Technology Mythos 10. Is there a way to attach the speaker to this stand you mentioned above? Wont it tip over? I believe you just gently place the speaker on the stand, and there is no edges on the stand, or tilt to hold the speaker in one place.
holyindian is offline
post #11 of 26 Old 01-06-2013, 02:38 PM
Liked: 1964
Not that I know of.
Wont it tip over?
I have no doubt that if I were to push firmly on the speaker or the stand, they would tip over. But I have no intention of doing that. wink.gif
I put grippy shelf liner - similar to this stuff - on the top plate to help prevent any slippage. Many months later, still no slippage. smile.gif
post #12 of 26 Old 01-06-2013, 03:30 PM
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
While I don't have the center channel stand, I'm very happy with my stands from VTI. They are very sturdy/stable, look good (IMO) and reasonably priced.
http://www.vtimanufacturing.com/Central%20channel%20speaker%20stand.htm
You can probably find them on amazon. I bought mine from wayfair.com.
Saturn94 is offline
post #13 of 26 Old 01-06-2013, 03:33 PM
Saturn94's Avatar
Quoted: 139 Post(s)
Liked: 468
I use the stuff your place under area rugs to keep them from slipping; works very well.
Saturn94 is offline
post #14 of 26 Old 01-06-2013, 11:23 PM
holyindian's Avatar
Quoted: 123 Post(s)
Liked: 50
Anyone thought about an Ikea Lack TV unit stand for their center channel speakers if they are huge?
something like this...
http://www.ikea.com/us/en/catalog/products/40105340/#/20105341
post #15 of 26 Old 01-07-2013, 04:47 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
Why not go to your local muffler shop and have them cut down a 3" pipe welded to a piece of sheet meter at the bottom for the base, then a smaller piece of metal that is big enough to support the speaker on the top end made out of a thin piece of sheet metal as well. Total price should be no more than $80 bucks for a speaker stand that absolutely will not tip over, and can keep the cabinet vibrations to a minimum. I will try and post pics of mine later on.
Martycool007 is offline
post #16 of 26 Old 01-07-2013, 04:55 AM
Liked: 1964
Lack: 58-5/8" (w) x 21-5/8" (d) x 13-3/4" (h)
IMO, it's too wide (21" wider than my CC-690!), too deep and too short.
post #17 of 26 Old 01-07-2013, 07:21 PM - Thread Starter
srg775's Avatar
Thanks everyone for the info.
I have decided to go with a VTI DFC center channel stand.
Lots of nice stands out there but the max height I could work with was 13" (most stands were 18" high). Hopefully not a bad stand for 50 bucks. Reviews seem good for it.
srg775 is offline
post #18 of 26 Old 01-08-2013, 04:56 AM
Liked: 1964
I have decided to go with a VTI DFC center channel stand. ... Hopefully not a bad stand for 50 bucks.
VTI makes sturdy stands. I used to own a pair of VTI speaker stands for the surrounds in a previous HT set-up of mine, and they were very solid.
post #19 of 26 Old 03-18-2013, 04:08 PM
saprano's Avatar
Quoted: 552 Post(s)
Liked: 547
What stand would be perfect for these?
http://www.dynaudio.com/int/home_loudspeaker_systems/excite/excite_x22.php
http://www.bowers-wilkins.com/Speakers/Home_Audio/CM_Series/CM-Centre-2.html
It needs to be 24" to 25" high. Maby adjustable?
The CMC2 is huge, so i would need the right width and weight support.
I looked here- http://www.standsandmounts.com/centerchannelspeakerstands.aspx
But can't find anything 25" high?
home theater addict
saprano is offline
post #20 of 26 Old 05-05-2013, 05:22 PM
amairphoto's Avatar
Quoted: 64 Post(s)
thanks!
did you ever find a product for this problem, im looking for the same thing
amairphoto is offline
post #22 of 26 Old 05-05-2013, 09:30 PM
amairphoto's Avatar
Quoted: 64 Post(s)
post #23 of 26 Old 05-10-2013, 10:26 AM
amairphoto's Avatar
Quoted: 64 Post(s)
thanks!
i just got these, i like the way they look
post #24 of 26 Old 05-10-2013, 10:44 AM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
thanks!
SAME here i used door stopper to from home depot.
caloyzki is offline
post #25 of 26 Old 04-09-2014, 04:14 PM
bnl107's Avatar
Yes, I tried that exact piece with my large, Definitive Technology CLR3000 center channel. It fit well and looked good, BUT the construction is cheap, thin, and hollow. The hollowness gave it a very strange resonance, and the weight of the speaker eventually made the top of the table crack. I like some Ikea stuff, but I wouldn't recommend this.
Sony HW50ES Projector (120" Screen)
Pioneer Elite SC-75
Emotiva XPA-5 Gen 2
Definitive Technology BP7001SC (Front)
Definitive Technology CLR3000 (Center)
Definitive Technology StudioMonitor 450 (Front Wide)
Definitive Technology PowerMonitor 900 (Surround)
Definitive Technology BP30 (Rear)
bnl107 is offline
post #26 of 26 Old 11-08-2016, 10:59 AM
Quoted: 12 Post(s)
Liked: 0
Center channel stand: B&W CM Centre 2
http://www.bowers-wilkins.com/Speake...-Centre-2.html
I looked here- http://www.standsandmounts.com/cente...kerstands.aspx
Did you ever find a suitable stand for the B&W CMC2? I have the same speaker but can't find much. There is one guy that makes custom stands that looks promising:
http://www.gwizpro.com/stands/index.php
mrp7avs is offline
Reply Speakers
