Where to go for bedroom HTPC? - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: How does my setup sound?
You found an excellent balance of value/performance for the bedroom. 0 0%
You failed at selecting the components for your stated needs and should kill yourself. 0 0%
Voters: 0. You may not vote on this poll
post #1 of 1 Old 12-18-2012, 01:10 PM - Thread Starter
rxtek's Avatar
Just bought these Energy Take 5 Pack 5CH for my bedroom HTPC.
GOAL
Need to decide on a subwoofer and receiver to achieve the following for a 14x12 bedroom:
- Cost effective surround system - That sweet spot for what is considered excellent price/performance on a budget. I don't want to spend 2-4x the price to have a small incremental improvement.
- Acceptable performance for movies
FUN FACTS
- Speakers will surround a queen sized bed
- Front speakers will be maybe a foot from the bottom of the bed
Receivers considered:
- Thinking $150-$200 price range unless there's a damn good reason to drop more $$$.
- Don't need bells and whistles
Yamaha RX-V371BL 5.1-Channel
Top seller on Amazon. Under $200
Subwoofers considered:
- Thinking 8" for a bedroom; $100 max
- Don't need to rumble the house
Pioneer SW-8 100 Watt RMS
Currently my top choice for bedroom setup. Many compare its performance to a 10" woofer.
Polk Audio PSW10 10-Inch
Second choice. Top seller on Amazon.
Again, I'm just looking for a simple audio setup that will suffice for blasting electro and the casual movie from time to time in my bedroom.
Many thanks.
rxtek is offline
Reply Speakers
