Best way to clean a speaker grille cloth? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-18-2012, 05:25 PM - Thread Starter
BestInTheWorld's Avatar
I have noticed dust and likely dead skin cells on my speaker grilles, and I vacuum once a week.
Is the best way to remove this stuff without damaging the grilles to use a microfibre cloth, feather duster or a hand vacuum?
Do any of you go further, and even handwash with a detergent/soap?
BestInTheWorld is offline
post #2 of 11 Old 12-18-2012, 07:26 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
Never thought about it, might vaccum them once in a while, dust is likely composed of dead skin in any case. Or just remove the grills and free the frequencies! smile.gif
lovinthehd is offline
post #3 of 11 Old 12-18-2012, 07:47 PM
DonH50's Avatar
Quoted: 2224 Post(s)
Liked: 1832
Vacuum if the grills come off. Lint roller (like used for clothes) if not.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #4 of 11 Old 12-18-2012, 09:22 PM - Thread Starter
The grills come off and people have suggested using a dry cloth to clean them. Microfibre clothes I had are static-y and "sticky" when i touch them. Would this be effective you think in removing stuff like lint and dust?
I'm just afraid of the cloths being too static, and causing inadvertent damage to the speakers themselves (E.g. once I put the grilles back on, after removing them)
And which vacuum type is good? Will the suction be too strong--which hose attachment, if any?
post #5 of 11 Old 12-18-2012, 09:26 PM
lovinthehd's Avatar
Liked: 4783
I think a vacuum cleaner is your best bet. Wiping a fabric surface with a cloth seems strange to me at least. Maybe a lint roller as was suggested. I think you're overthinking this in general. Just use a vacuum attachment for either fabrics or crevices or the basic hose...your pleasure.
post #6 of 11 Old 12-18-2012, 09:33 PM
cyde01's Avatar
Compressed air, vacuum with soft bristle attachment, or a lint roller will get the job done.
cyde01 is offline
post #7 of 11 Old 12-18-2012, 09:58 PM
KenBBaker's Avatar
Some said to use the K2R for stubborn spots, in the section on Acoustat speakers I think.
KenBBaker is offline
post #8 of 11 Old 12-18-2012, 10:07 PM - Thread Starter
I have OCD (now I'm embarrassed), and so I don't know the "right" way or proper way of cleaning speaker grilles. I'm very particular, and when there is a "best" way, I will always use this way. So I will be trying the vacuum w/soft bristle attachment.
Last question, but will the hose suction be too strong or would it be good without warping the grille/cloth?
post #9 of 11 Old 12-18-2012, 10:23 PM
lovinthehd's Avatar
Liked: 4783
Unless your speaker grills are of very low quality I wouldn't worry about the vacuum. Don't press the nozzle/head/attachment into the speaker so as to press into the tweeter dome or driver, etc. OCD isn't so bad, there's worse.
post #10 of 11 Old 12-19-2012, 08:56 AM
Espo77's Avatar
Quoted: 183 Post(s)
Liked: 85
I use a vac with the soft brush attachment. I also use a soft shoe brush on speaker grills. It also works wonders on remote controls and face plates.
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #11 of 11 Old 12-19-2012, 09:12 AM
ousooner2's Avatar
Quoted: 291 Post(s)
Liked: 179
try running a dryer sheet over them...
Currently Auditioning: Klipsch RP-150M
SOLD: EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
FOR SALE --- 1 EMP Tek/RBH Sound e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
Reply Speakers
