External Amp Speaker advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-19-2012, 07:52 AM - Thread Starter
spdracer3's Avatar
Looking for advice. I recently upgraded my receiver formerly a Sony DA3000ES and was running an external Crown XLS402 to power the mains in a 7.1 speaker setup. My main front speakers are Polk RTi10's. My new AVR is a Marantz 7005. Main use of system is Blue Ray/3D. Using the 7.1 config would it be better to just utilize the AVR's amp to power the fronts and remaining speakers and do away with the Crown Amp or use the Marantz Pre-amp L/R outs to go to the Crown 402 to power the mains? Again this is mainly used for video/Blue Ray. Looking to get the most out of a 7.1 speaker conifg for movies. Thanks for the advice.
spdracer3 is offline
post #2 of 4 Old 12-19-2012, 08:05 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
I would just say that if the sound quality of your speakers is awesome to you at all the volumes your heart desires, then don't worry so much about the "measurements and specs" of the amps. biggrin.gif
IOW, try it out and see for yourself. If the Marantz alone sounds awesome, that's all you need. If not, then use the Crown amp to power the fronts.
AcuDefTechGuy is offline
post #3 of 4 Old 12-19-2012, 08:07 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
You have it - try it both ways and leave it the way you like best.
rick240 is offline
post #4 of 4 Old 12-19-2012, 08:13 AM
Paraneer's Avatar
Quoted: 32 Post(s)
Liked: 87
I agree with Rick. You already have the stuff so try it and keep the configuration that sounds best to you. Don't worry about what we think.
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is offline
Reply Speakers
