Need help selecting amazing bookshelf speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 34 Old 12-19-2012, 06:21 PM - Thread Starter
sevendustweb's Avatar
I have been using the Axiom Audio M60s for 2 years. I recently bought a new house, and there is not enough room in the den (damn bookshelves) for the M60s. I need to find some serious bookshelf speakers. I want a speaker that provides the same or better sound than the M60s. I am trying to avoid downgrading because I am being forced into bookshelf speakers. My budget would be roughly $1,200.00.
I will use them for a mixture of TV, movies (Blu-Ray mostly) and music. I would put an emphasis on movies first. If you know of a jaw dropping bookshelf speaker, please let me know.
Yes, I feel like I got kicked five times in the nuts for losing my M60s.
sevendustweb is offline
post #2 of 34 Old 12-19-2012, 06:36 PM
gtpsuper24's Avatar
Liked: 99
First bookshelf that comes to mind is the Ascend Sierra bookshelf http://www.ascendacoustics.com/pages/products/speakers/SRM1/srm1.html
I had Axioms before too and went from Axiom M22 V2s to Arx A1 bookshelfs (although later upgraded to larger Arx towers). If you can get out and audition speakers at a local retailer, if you like the Axiom sound you probably want to look at some Paradigms or PSB. Seems like all the Canadian speakers have kind of a sizzle in the top end, like Axiom has (at least to me and alot of other AVSers)
gtpsuper24 is offline
post #3 of 34 Old 12-19-2012, 07:03 PM
Yosh70's Avatar
Quoted: 172 Post(s)
Liked: 126
Considering you put an emphasis on movies, are you running a CC or are we talking just 2 channel here?
Yosh70 is offline
post #4 of 34 Old 12-19-2012, 07:26 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 463
dynaudio, focal, monitor audio, ascend, salk, dali, paradigm, psb, kef, b&w, aperion will all have speakers in your price range that would meet your needs.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is online now
post #5 of 34 Old 12-19-2012, 07:30 PM
JerryLove's Avatar
Liked: 79
^^^ +1
JerryLove is offline
post #6 of 34 Old 12-19-2012, 08:32 PM - Thread Starter
I am running the speakers through an Onkyo TX-NR806 receiver. I would like to move up to an amp one day. I am running a 5.2 setup through an HTPC. I like the idea of Paradigms or B&Ws. Do you recommend certain models?
Can bookshelf speakers actually sound as good or better than the M60s?
post #7 of 34 Old 12-19-2012, 08:44 PM
JerryLove's Avatar
Liked: 79
With a sub? Yes.
post #8 of 34 Old 12-19-2012, 08:45 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 463
paradigm studio 10s or b&w CM1
However I do prefer the Dynaudio DM2/7(very good bass) or Excites X12 and Dali Ikon 1 and Focal 807v more then either of those 2 speakers. I like the Monitor Audio RX2 a lot as well.
post #9 of 34 Old 12-19-2012, 10:18 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
NHT Classic Two's or Three's should also be considered.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #10 of 34 Old 12-20-2012, 02:36 AM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15621
fwiw, just a few great speakers on audiogon in your price range;
kef ls50
usher be-718 tiny dancers
totem acoustics model 1
revel performa m22
reference 3a de capo i
psb platinum m2
dynaudio focus 140
i'm so laid back,i'm laid out
smasher50 is online now
post #11 of 34 Old 12-20-2012, 09:16 AM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1300
+1
Especially if you're putting them in an actual bookshelf. You want something sealed or at least front ported and designed to work with close boundaries.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #12 of 34 Old 12-20-2012, 10:29 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
You want to keep your big speaker sound, and you need a speaker that's actually designed to be stuffed in a shelf/cabinet. This Boston BT1 is going to be hard to beat
http://www.digitalcraze.com/Speakers-Subs/Center-Channel/Boston-Acoustics-163/Boston-Acoustics-Bt1
Jay1 is offline
post #13 of 34 Old 12-20-2012, 11:30 AM
gtpsuper24's Avatar
Liked: 99
Awesome theater speakers. Demo'd a pair several years ago and they have huge dynamics and output. A4less has them come up factory refurb sometimes. http://www.accessories4less.com/make-a-store/item/BOSBT1/BOSTON-ACOUSTICS-BT1-LCR-Loudspeaker-Each/1.html
Nice thing about them is that tweeter/mid can rotate so you can use it as a horizontal center.
post #14 of 34 Old 12-20-2012, 11:39 AM
Quoted: 20 Post(s)
I recently had to downgrade from mirage omd28s and wanted to get as much sound as I could without annoying the neighbors, something the mirage were exceedingly good at doing and is why I had to move them to my parents house. I ended up with monitor audio silver rx2. they have an 8" woofer so go pretty low still.
they sound fantastic, and are good enough that I don't constantly miss my omd28s.
I filled some b&w stands with sand and put them on them.
I use them mostly for movies and tv. and they are powered by a much too powerful 220w per channel peachtree amp left over from the omd28 speakers, and a nova for preamp/dac via usb from a htpc.
nycmtber is offline
post #15 of 34 Old 12-20-2012, 05:04 PM
Yosh70's Avatar
Quoted: 172 Post(s)
Liked: 126
No one has concerns about the CC not matching the LR?
Unless the OP is planning on purchasing a CC from whichever speaker company he's buying confused.gif
Yosh70 is offline
post #16 of 34 Old 12-20-2012, 08:30 PM - Thread Starter
You bring up a great point. I was hoping I would not need to purchase a matching center channel. Then again, that's why I'm posting because I have no idea. The Axiom center channel I have sounds great. Help?
post #17 of 34 Old 12-20-2012, 08:58 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
How big of a space do you have for the center? The Boston BT1's tweeter/mid array can be rotated and the speaker placed on its side for a center, so you get a perfect matched LCR.
Jay1 is offline
post #18 of 34 Old 12-20-2012, 09:08 PM
gtpsuper24's Avatar
Liked: 99
While IMO its not a jaw dropping bookshelf, If you want to keep the Axiom center and are happy with the Axiom sound then just get the M22s. Honestly though IMO having experience with Axiom products, you can do much better than their current center channel offerings, especially the VP150.
post #19 of 34 Old 12-21-2012, 05:46 AM - Thread Starter
If keeping the Axiom center channel means I have to downgrade to Axiom bookshelves, then I need to get another center channel. Would you select the Boston Acoustics BT1 / BT2 over The Dynaudios, Dalis and B&W's? I tend to agree, because these speakers will be sitting on a shelf, they may as well be built into the shelf.
post #20 of 34 Old 12-21-2012, 05:49 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3514
just went from reference Klipsch towers to PSB B6 with c5 center. I cannot express how incredible these speakers are!! blow away the top of the line klipshc towers. you will not be disappointed!!
btw I am 90% movies 10% music
Brian Fineberg is offline
post #21 of 34 Old 12-21-2012, 08:08 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Unless you're looking at on-wall/in-cabinet specific models from those brands, none of their standard speakers are designed to be stuffed in a bookshelf.
Jay1 is offline
post #22 of 34 Old 12-21-2012, 08:16 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
One of the best bookshelf/monitor speakers I know of is the Monitor Audio Silver RX-2. They have excellent sound quality, and also they have an 8-inch bass driver, which will give you a lot more and lower bass than speakers with smaller drivers.
They run from $850 to $1000 per pair depending on which wood veneeer or gloss finish you choose.
They are rear-ported, however, which could be a problem if the rear will be very close to a wall.
In that case, front-ported speakers will be mandatory. The KEF Q300 has very good bass and run $650 per pair at KEF Direct.
commsysman is offline
post #23 of 34 Old 12-21-2012, 10:30 AM
gtpsuper24's Avatar
Liked: 99
Although no experience with Dynaudio (car speaker only) or Dalis I would say the Bostons would be the way to go. Especially since your leaning toward mostly movies. The Bostons will play louder, have better dynamics and are more efficient than your current Axioms. They will lack the bass that the M60s have but if your going to use subwoofer than thats not a big deal. If you can I would go with BT2 L/R and a BT1 center.
As far as what your after, in cabinet/on shelf speakers the BA's will be tough to beat.
I would get the measurements and make sure you can fit these in the location you need. Depth, width, ect. I would cut a piece of cardboard to the size and see if they would work.
post #24 of 34 Old 12-21-2012, 11:15 AM
ex-labdriver's Avatar
Quoted: 25 Post(s)
Liked: 32
7dustweb:
I have 3 Axiom bookshelf systems:
HT - Two M22v3s with twin Velodyne subs (used as stands for the 22s) with QS4s for the rears. I use a Sony tiltable CC due to space limitations & I find that in real-world movie watching, the slight timbre difference is inconsequential & not detrimental in any way. I only notice the timbre difference on pink noise. Overall a great medium size HT that effortlessly shakes my house.
Audio SS System - Two M3v3s on Axiom Stands that I use as an ambiance for wonderful room filling sound without the need for a sub; and
Audio Tube Amp System -Two M2v3s on Axiom Stands paired with a single EP-400 sub that I use exclusively for SACDs. This is a killer little system with a small footprint that reproduces exceptionally pleasing & accurate music at more than adequate levels in a fairly large room.
According to several decades of positive reviews, both from the pros & a myriad of more than satisfied customers, it would not be a downgrade to Axiom bookshelves. They are rear ported though, so that would be a factor in placing them...
TAM
ex-labdriver is offline
post #25 of 34 Old 12-21-2012, 03:52 PM - Thread Starter
My wife shot down the idea for the Boston Acoustics as she does not want the speakers to be "built in" to the book shelves. From what I have been reading, I guess I need to look into bookshelf front ported speakers.
post #26 of 34 Old 12-21-2012, 04:24 PM
JerryLove's Avatar
Liked: 79
Do you understand what a baffle diffraction step is and why it's the source of your problem?
Have someone cup their hands around their mouth (like a bullhorn) and talk to you. Got louder didn't it?
That's because the same amount of sonic energy is now radiating in a smaller cone. If you were standing off to their side, it would have gotten quieter, not louder.
If they could talk in really low frequencies, this trick would not work. Why? Because the baffle (their hands) wouldn't be big enough for the sound to interact with it. There would be no change in volume from the front or the side from them holding their hands up... unless they grew much bigger hands.
Same thing happens on a speaker. High frequencies project almost entirely forward and so are 6db higher than low frequencies which project in all directions.
But when you embed a speaker in a bookshelf, or wall, or the ground: you make a bigger baffle. Suddenly all of the sound is being projected forward instead of only high frequencies. All frequencies become +6db relative to what the bottom frequencies were doing before.
There is no speaker that, without adjustment, will perform properly both embedded in a wall/bookshelf/ground and also sitting on a stand in a room. The only possible exception would be one that, by virtue of a really big baffle or really limited LF response was already functionally an infinite baffle. Physics doesn't allow it.
On the upside: DSP room correction may adjust this for you.
(and yes, you don't want to use a rear-port that's blocked. That would make the mass in the tube functionally heavier (and spl dependant) and ruin your sound.
post #27 of 34 Old 12-25-2012, 07:39 AM
pgaiduk's Avatar
I'm in the same predicament.
My front stage is a huge wall to wall, floor to ceiling bookshelf.
The room is a 15x22 sunken living room with one wall open to the rest of the house. 12 foot ceiling.
I have Klipsch RB-61lls for L/R, a RC-52 center, Klipsch ceiling surrounds and a Paradigm dsp-3400 sub.
I was looking at the Klipsch KL-650-THX or the Klipsch KL-525-THX to replace my front left and right RB-61lls. I was thinking of keeping the RC-52ll as the center.
I'm surprised nobody talks about this speaker.
Am I missing something?
How would these compare to the previously mentioned Boston built ins?
Opinions?
pgaiduk is offline
post #28 of 34 Old 03-11-2013, 06:03 AM
nyaudio98's Avatar
How about tekton m lores
nyaudio98 is offline
post #29 of 34 Old 03-11-2013, 09:22 PM
guteLaune's Avatar
I auditioned a ton of bookshelf speakers in my search for a good all-around 2-channel setup for movies and music. If you're talking new, Goldenear Aon 3's for sure (they might not pass the WAF though). The Aon's absolutely go low. Not subwoofer low, but certainly a bookshelf-shouldn't-go-that-low low.
They're ugly, though. Damn ugly.
KEF R-100 is sexier, as is the new Venere series from Sonus Faber, but I'm not sure if either will go as low as you'd like.
Is there no room for a sub in the den (maybe I missed this in previous posts)? If you're using this mostly for movies, I would think you'd be overall happier with less expensive bookshelves and a sub than trying to pull a lot of low end from bookshelves alone.
guteLaune is offline
post #30 of 34 Old 03-11-2013, 10:14 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
GoldenEar Aon 2/3 are getting good reviews here. All the ones already mentioned as well... Arx, Ascend, Aperion, SVS, HSU, PhilMonitors, Sulk, EMP Tek
All good smile.gif If you liked Axiom I think I would recommend the Aperion and since it is free 2 way shipping..you can't loose there.
Newbie01 is offline
Reply Speakers
