Banana Plug Female plug for wall plate, for SOLID wire? - AVS Forum | Home Theater Discussions And Reviews
Old 12-21-2012, 01:14 PM - Thread Starter
Jeremiahm's Avatar
Quoted: 14 Post(s)
I have a home theater that was wired with SOLID 12 awg wire for 5.1. The wires just come out of holes behind permanent speaker locations, but I want to be able to put my fronts and center away when not in use. So, I'd like to terminate these wires at a wallplate that will accept banana plugs. So, I need to figure out which plug is best to use with solid wire. Any ideas?
Once I upgrade my bookshelfs with towers, then the towers will stay put, but until then, I'm not leaving my bookshelfs tetering on stands for every day living with two small kids in the house.
Thanks for the help.
Jeremiahm is offline
Old 12-21-2012, 01:24 PM
commsysman's Avatar
Quoted: 1004 Post(s)
Liked: 529
Wall plates are available with one or more pairs of banana jacks.
They should be gold-plated jacks to eliminate corrosion and you should solder the in-wall wire to them.
The best banana plugs are made by Pomona Electronics. Many are very cheap and lose spring tension in time.
Monoprice 3324 wall plate.
commsysman is offline
Old 12-21-2012, 01:36 PM
Quoted: 925 Post(s)
Liked: 492
Use Speakons, not bananas.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Old 12-21-2012, 01:38 PM - Thread Starter
Jeremiahm's Avatar
Quoted: 14 Post(s)
So the binding post type of plug that has the horizontal hole that you slide the wire throught then clamp the top down is what I need, and those work well with SOLID wire, but I should solder that connection? Or, am I not following about the inwall wire hookup?
Old 12-21-2012, 05:43 PM - Thread Starter
Jeremiahm's Avatar
Quoted: 14 Post(s)
Whats a speakon and why are they superior to bananas?
