feed back through speakers driving me nuts please help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 12-21-2012, 03:36 PM - Thread Starter
turbov6camaro's Avatar
hello I have a high pitch feed back through my speakers, The set is a remote avr closet,
I was very careful to keep power away from the speaker wires as i could, right now only the FR FL Center and SUB channle are hooked up
turbov6camaro is offline
post #2 of 10 Old 12-21-2012, 07:24 PM
duc135's Avatar
Quoted: 162 Post(s)
Liked: 226
Unplug one device from the receiver at a time until the noise goes away.
Is this a new setup? If so, what speakers do you have? You may just have VERY sensitive speakers and the noise floor of your equipment is high. If this is an old setup and it just started happening, what changed?
duc135 is online now
post #3 of 10 Old 12-21-2012, 10:30 PM
Roger Dressler's Avatar
Quoted: 1745 Post(s)
Liked: 885
What do you mean by feedback? You'll need to describe the symptoms better. Just because there is a high frequency noise does not mean it is feedback. It can be feedback if you are feeding a preamp output back into an input. Does the problem exist with digital sources? At all volume settings? With speakers off using headphones? All the speakers?
Deadwood II Theater
Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #4 of 10 Old 02-18-2013, 05:10 PM - Thread Starter
hi all im sorry i didn't get an email
I notice the issue after i moved
it happens on any input source ( i only have 2 HDMI the DTV and blue ray)
I just hooked up the systtem from 3.1 to 7.1 and it is in all speakers and the same same sound in each
I have tried it pluged into my UPS (bother battery backup and surge) and into wall and into that will with a filter on it, I have tried different plugs also
it seems to get worse since i hooked up the 7.1
it does not change with volume
its high pitch and varys up and down a little
i hear it if i mute also
post #5 of 10 Old 02-18-2013, 05:32 PM
afrogt's Avatar
Quoted: 1364 Post(s)
Liked: 947
What speakers do you have? What receiver?
Afro GT
afrogt is online now
post #6 of 10 Old 02-18-2013, 06:21 PM
Liked: 885
That's a bad sign.
Deadwood II Theater
post #7 of 10 Old 02-19-2013, 11:18 AM - Thread Starter
i have an HK 245 AVR (or 235) ( older model i have had it 5-6 years)
i have Infinity TSS-1200 speakers for the surround and center, Polk PSW505 for the sub, and 2x MartinLogan Motion 10's for the FR and FL
Originally Posted by Roger Dressler View Post
That's a bad sign.
post #8 of 10 Old 02-19-2013, 05:18 PM
Liked: 885
If you hear spurious HF tones with the AVR muted, it suggests a failure inside the AVR. If you disconnect every source cable, and every speaker but one, and the noise remains, it's time for a trip to the service shop.
Deadwood II Theater
post #9 of 10 Old 02-19-2013, 05:51 PM - Thread Starter
on a good note if it is bad i get to upgrade, but it seem HK AVR's are not as good these days? i seen they have 3600 on there ebay store for $400
post #10 of 10 Old 02-20-2013, 10:05 AM - Thread Starter
well i un plugged every thing and it mostly goes away but then i did the test again and i still got the same result some sound coming from speakers,
any recommendation for a new AVR ?
Reply Speakers
