Need help with a slim center channel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-22-2012, 10:40 PM - Thread Starter
Fujiwara86's Avatar
Hey guys,
I'm new and looking to build out my 5.1 system. In my living room I've mounted the TV above the fireplace. But since the fireplace is already tall, I only have about 4" max between the top of the mantle and the bottom of the TV. So I need to find a slim center channel that can deliver the best sound.
Does anyone have any recommendation?
Fujiwara86 is offline
post #2 of 8 Old 12-22-2012, 11:34 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Move your TV up another 4-6" so you can fit a typical center speaker?
Jay1 is offline
post #3 of 8 Old 12-22-2012, 11:38 PM
cconner's Avatar
cconner is offline
post #4 of 8 Old 12-23-2012, 07:57 AM - Thread Starter
Fujiwara86's Avatar
I can't move it up another 4-6" because the tv is already at a high height. Thanks for the recommendation cconner, but those centers are about 5.5". I need to find one less than 4"
post #5 of 8 Old 12-23-2012, 08:19 AM
cconner's Avatar
I figured let it slip behind the TV 1.5"
cconner is offline
post #6 of 8 Old 12-23-2012, 08:21 AM
cconner's Avatar
cconner is offline
post #7 of 8 Old 12-23-2012, 08:29 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
The Cambridge Audio S50 is just over 4 inches tall and is excellent.
Maybe you can put the TV on something 3/4 inch thick; a piece of oak shelving or ??
commsysman is offline
post #8 of 8 Old 12-23-2012, 10:17 AM
Kini62's Avatar
Quoted: 1410 Post(s)
Liked: 1293
Take a look
http://www.amazon.com/Yamaha-NS-C310BL-Bass-Reflex-Center-Speaker/dp/B001PZ674C/ref=sr_1_1?ie=UTF8&qid=1356282996&sr=8-1&keywords=yamaha+ns-c310
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Reply Speakers
