Speaker Stands for Definitive Technology Studio Monitors 350 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-23-2012, 07:51 PM - Thread Starter
andyboy's Avatar
Hello there,
I'm looking for some speaker stands to be behind my couch that will fit the Studiomonitors 350. I looked at the Definitive stands that are made for these speakers but they are a bit short. I would need something that's at least 30" in height. Anyone have any suggestions? Not looking to spend too much on these.
andyboy is offline
post #2 of 6 Old 11-21-2013, 07:43 AM
npradeepkumar's Avatar
Hi,
I have the same question as yours. Were you able to find something to meet your requirement. If yes, what did you get.
npradeepkumar is offline
post #3 of 6 Old 11-21-2013, 07:47 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
Originally Posted by npradeepkumar View Post
Hi,
Something like this would work well: http://www.amazon.com/Sanus-Systems-Natural-Foundations-Black/dp/B00005USAY/ref=sr_1_4?ie=UTF8&qid=1385048760&sr=8-4&keywords=sanus+stands
I would recommend some blu-tac to help secure them to the surface if you have pets/kids/clumsy friends.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #4 of 6 Old 11-21-2013, 09:41 AM
boondongle's Avatar
Quoted: 12 Post(s)
I'm planning to get these for my SM350s. The top plate is a little smaller than I'd like (7.1" x 7.1") , but I don't think ti will be a big issue. Other than blue tac it doesn't seem it would be too difficult to fab up a slight larger top plate and affix it to the existing one somehow.
I just don't like the look/feel of the wood ones for where they'd be going in my house.
http://www.amazon.com/TransDeco-TD32BA-Speaker-Stands-32-Inch/dp/B001PYV7LQ
If you get them, let us know how you like them!
boondongle is offline
post #5 of 6 Old 11-21-2013, 09:47 AM
Liked: 1394
VTI makes some really nice stands also, I have a pair of their 36" DF stands for my surrounds, and they work very well. They are made of cast iron and are very study, with space for cable management and adjustable feet. They obviously cost a little more than the wood offerings, but just throwing out some options.
http://www.standsandmounts.com/vtidfseriescastiron29inchspeakerstandsdf29.aspx
http://www.standsandmounts.com/vtirfseriescastiron29inchspeakerstandsrf29.aspx
post #6 of 6 Old 11-21-2013, 10:14 AM
Thanks for the different suggestions. I will have to measure the height once again to make sure I get the stand with the correct height. But these do give me some options to think about.
Reply Speakers
Definitive Technology Studiomonitor 350 Speakers
