New to home theater audio, need assistance. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 12-28-2012, 09:09 AM
UGAd13's Avatar
Quoted: 100 Post(s)
Liked: 121
Originally Posted by rschuler313 View Post
Looking at also picking up a set of the monitor 30s for rear sorrounds.
Now onto cables.
1) Do i need the piece below for my subwoofer, or can I run the single subwoofer cable into it?
http://www.amazon.com/gp/product/B004EBX5GW/ref=ox_sc_act_title_7?ie=UTF8&smid=A1DCPNQKKEISZB
Looking at using 14 gauge speaker wire, removing the base board and running it behind the baseboard. My receiver and speakers are 8 Ohms and the run will be between 35-40 feet,
2) is that a good fit for wire?
3) Also looking at getting banana clips. Do i terminate both ends, I.e. at the receiver side and the speaker side, with the clips?
Remember I'm not an audiophile and this is also a budget build so if anything above is unnecesary that is a plus.
1) No, get a single 'sub' cable and use the LFE input on the back of your sub.
2) Yes
3) You can, but you can also just use the bare wire.
Monoprice is a great place to buy cables - you can save $ here.
6ft 'sub' cable - $3.88
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2680&seq=1&format=2
100 ft 14 AWG - $25.20
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023902&p_id=2791&seq=1&format=2
Do you have HDMI cables? Get them from there too.
My living room budget build: Samsung PN51E530 / Denon AVR1613 / DefTech PC1000 / DefTech PM60 / DefTech ProSub 60 / Dayton Sub1200
UGAd13 is offline
post #32 of 33 Old 12-30-2012, 12:39 PM - Thread Starter
rschuler313's Avatar
Everything is all ordered. Thanks for all the help, now the waiting game begins.
Got the sub from amazon, as well as cables. 45B, CS2, and 30 from newegg. with gift cards I paid about 230 out of pocket.
rschuler313 is offline
post #33 of 33 Old 01-09-2013, 04:33 AM - Thread Starter
Everything has arrived and is hooked up. I am extremly happy with the sound quality. My wife thinks our neighbors are going to hate us.
Reply Speakers
