Help Please! Which one is the better choice here? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 12-25-2012, 01:45 PM - Thread Starter
Jennifer West's Avatar
I have a Pioneer VSX1022k and need to get some speakers tomorrow on boxing day so I can watch TV and Projection movies.
My 3 options are:
Klipsch HDT 500 5.1 $349
Polk TL1600 $299
JBL package 5.0
http://www.bestbuy.ca/en-CA/product/-/b0000073.aspx?path=9cbb0a0c23372f74bbf52d954fc1264cen02
OR
Jamo 5.0 S606HCS3HG $499
http://www.bestbuy.ca/en-CA/product/jamo-jamo-5-0-surround-speaker-system-s606hcs3hg-s606hcs3hg/10199606.aspx?path=3d5877e38d3cd468e8b52d9e7e4c26eaen02
(If i go with a 5.0 system I will use my Polk PSW10 sub, if not I can still return this sub)
Any imput / suggestions? Highly appreciated! Thanks!
Jennifer West is offline
post #2 of 22 Old 12-25-2012, 01:48 PM - Thread Starter
post #3 of 22 Old 12-25-2012, 01:51 PM - Thread Starter
Right now I'm leaning towards the JBL set...
post #4 of 22 Old 12-25-2012, 06:52 PM - Thread Starter
anyone?
post #5 of 22 Old 12-25-2012, 07:33 PM
Elihawk's Avatar
Quoted: 1016 Post(s)
Liked: 860
The jamo set has the biggest drivers in the front towers...which is just one component to a good speaker set!
The Polk and Kilpsch sets have very small drivers and are designed for small rooms!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #6 of 22 Old 12-26-2012, 12:57 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
I had the Jamo set (they were my back-up system while I auditioned other speakers) and at that price point they had a surprisingly good sound for both music and HT. Also they will easily fill a large space, esp. compared to the satellite systems in your list.
I haven't heard the JBL's.
sdg4vfx is offline
post #7 of 22 Old 12-26-2012, 01:10 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
I would definitely suggest the Jamo system, in comparison to the others mentioned.
Actually, Amazon has the Jamo S426 HCS3 5.0 system for the incredible low price of $137. It is quite good, and the price is crazy good at the moment.
I would suggest that you return the PSW10 sub, unless you have a very small room and intend to keep the volume very low.
IMO it does not have adequate size or power for most situations.
The Polk PSW505 is much more capable IMO and you should be able to get it for around $220.
commsysman is offline
post #8 of 22 Old 12-26-2012, 02:45 PM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 898
The HK is essentially a bigger and better version of this JBL set I bought ~10yrs ago. The HKs have double the drivers mine do. It's been an excellent little system for the $350 I spent on it. I've upgraded the front three slowly over the years but still use the surrounds for the rest in 7.1.
http://www.retrevo.com/s/JBL-SCS-135-Speaker-Systems-review-manual/id/597ci676/t/1-2/
That said, for the small difference in price I think I'd get the Jamos. Much bigger and capable system.
ambesolman is offline
post #9 of 22 Old 12-27-2012, 09:15 AM - Thread Starter
Ended up buying the JBL set with a JBL 10'' 150watt sub. I read somewhere that the JAMO tweeter were bad, made of very cheap materials.
raver4444 likes this.
post #10 of 22 Old 12-27-2012, 02:28 PM
uncola's Avatar
Quoted: 43 Post(s)
Liked: 37
I'd love to see some pictures or hear your impressions on the JBL Loft 50 set.. on paper it sounds very good and it seems to be the top deal at best buy canada right now but I haven't found any real reviews.
Gear list: Main setup - Kef Q900, Svs sb12-nsd subwoofer, onkyo 609 receiver, epson 8350 projector, elitescreens sable 92" screen, mac mini htpc
Bedroom setup: Philharmonic Audio New Philharmonitors, Odyssey Kismet Monoblocks, Soekris Dac, Hattor active preamp
uncola is offline
post #11 of 22 Old 12-30-2012, 07:25 AM
KroniK1's Avatar
Both are nice, but the Jamo is the better set....don't worry about the tweeter.....stuff happens.....and thats usually when people complain + post pictures......tweeters are replaceable
I went and looked at them in the store.....the JBL's looked nice but they were extremely light, even with the extra drivers.....could be attributed to the cabinet size but each tower weighs about 1/2 as much as the Jamo tower
The Jamo also has larger drivers, which is usually found on higher-end systems......dual 5" for mids is better than triple 4" drivers IMO
Also the Jamo has 8" woofers for lows....the JBL has dual 6.5's.......but the cabinets they are housed in are so small....usually bigger enclosure's = bigger sound
In conclusion....the Jamo was the better choice for me, and others who want big sound.....if you have a smaller room and will mostly be using it for movies, then the JBL set should be fine....and the slim towers look pretty nice I have to admit
Spend the extra $100 and get this sub no matter what set you go with: http://www.visions.ca/Catalogue/Category/Details.aspx?categoryId=162&productId=587&sku=PSW505
Twice the power....and it can almost hit 20Hz....you will be able to feel the bass rather than just hear it....it will blow that JBL or that other Polk sub away
I also looked at this set:: http://www.bestbuy.ca/en-CA/product/-/b0000946.aspx?path=731c5d5d081da1952578a5dc51ff94daen02 .....but I wasn't a fan of the sound....and I still think Jamo is better quality
KroniK1 is offline
post #13 of 22 Old 01-06-2013, 04:46 PM
raver4444's Avatar
SO ? happy with your choice?
raver4444 is offline
post #14 of 22 Old 01-07-2013, 05:05 PM
KroniK1's Avatar
I didn't like the Klipsch sound.....the JBL sounded better in my opinion......my Jamo set arrived today and I couldn't be happier.....the pics on the site don't do them justice.....they are the "High Gloss Black" ones....the website picture is of the "Black Ash" version.....the glossy black is very sleek looking
Also scored a pair of Polk RTI10's on clearance for $250/each.....gonna hook those up in the basement with a 2-channel amp smile.gif
KroniK1 is offline
post #15 of 22 Old 01-07-2013, 05:17 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 756
Good choice, glad you like the Jamo.
Afro GT
afrogt is offline
post #16 of 22 Old 01-07-2013, 06:02 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Congrats - enjoy!
sdg4vfx is offline
post #17 of 22 Old 01-13-2013, 08:31 PM
raver4444's Avatar
So I went and exchanged my JBL for the Jamo. None of them was on display so I couldn't listen too but I listened to your opinion guys and went with Jamo.
Now, time to look for a nice sub ...
post #18 of 22 Old 01-13-2013, 08:35 PM
iamwardicus's Avatar
I love my Jamo set, and I was lucky enough to snag a Jamo 650 sub from Vanns before they ran out. What is your subwoofer budget?
iamwardicus is offline
post #19 of 22 Old 01-13-2013, 09:23 PM
raver4444's Avatar
It depends...but let's say ...around $400.
post #20 of 22 Old 01-15-2013, 06:02 AM
KroniK1's Avatar
like I said before the Polk PSW505 from Visions is a good deal at $300.....but now the price is up to $350
Visions has a Cerwin Vega 12" 300W for the same price too....but I like the Polk better.....check out the frequency range wink.gif
IMO the subs at Visions are better....Futureshop/Bestbuy don't have anything comparable for the price
here's a list of subs Visions has right now: http://www.visions.ca/Catalogue/Category/ProductResults.aspx?categoryId=162&brandid=0&start_price=0&end_price=0&menuClickCatID=155&category_name=Subwoofers
KroniK1 is offline
post #21 of 22 Old 01-16-2013, 06:20 AM
raver4444's Avatar
post #22 of 22 Old 01-17-2013, 01:18 AM
KroniK1's Avatar
yeah I like it....hard to beat for the price
those are good prices if you know someone or live close to the border and can go pick it up.....
Newegg.com doesn't ship to Canada (have to use Newegg.ca)....and that promo code expired on Dec 23
Amazon.com won't ship that particular item to Canada either
even for $350 it's the best sub for the price IMO
KroniK1 is offline
Reply Speakers
