rc-52ii vrs rc-62ii - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-27-2012, 03:06 AM - Thread Starter
Thomas 1966's Avatar
is the rc-62ii worth the big price increase over the rc-52ii
the rc-52ii would have a much better WAF
but I would rather be sure to have a speaker i will not need to up grade again
I now have a jbl es center I am guessing both would be a much better center over what I have now
my mains are polk m70s I am interested in having klipsch front three having rf-82ii fronts but thought I would buy the center first to see if I like the klipcsh sound and do not have the money now to replace the fronts and cannot hear before I buy
I have a denon 3312
the room is 18 x 20 x 8c
I will be crossing at 80htz or maybe 60htz at the lowest
would the rc-52ii be enough I do like to be a bit over the top having a little more than I need
movies/music 50/50
I want better highs than what i have now and to be louder with out adding more power
I am running 4 jbl es 250 subs at half gain sound good enough to me but need better louder highs and mids to keep up with the subs
I found my speakers a little lacking with blues playing brass
Thomas 1966 is offline
post #2 of 2 Old 12-27-2012, 06:51 AM
MAGHUNTER's Avatar
Quoted: 28 Post(s)
Yes it is worth it. I started with the 52 with the 82's and it sounded good but the 62 is the matching center. You mentioned 50/50 music/movies and the 62 makes the front stage more seamless than the 52. I cross the 62 at 60hz. That said the 52 is no slouch. I have it matched to rb51 bookshelves and the soundstage is also seamless on that system.
MAGHUNTER is offline
Reply Speakers
Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Black Each , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch R 5650 W In Wall System Rc 62ii Center , Klipsch R 5800 W In Wall System Rc 62ii Center Free Sub
