active monitors for computer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-28-2012, 01:15 PM - Thread Starter
bjaurelio's Avatar
Since selling my desktop and getting a laptop, I've had in the back of my head that I would need something for better sound in my room at my desk. Most music listening is in my living room, but there's a huge disparity between def tech sm350s with a sub and laptop speakers.
I was browsing craigslist for active monitors as likely the best value for a 2.0 setup and found a pair of KRK Rokit 6 (not meet g2) for $175. Is this a good deal? It's a little more than I was looking to spend, but my other option is Behringer ms40 on eBay for $130. This seems like a big upgrade for just $45.
bjaurelio is offline
post #2 of 5 Old 12-28-2012, 01:52 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
I had M-Audio BX5's in the past and thought they were good for the money.
http://www.amazon.com/Avid-9900-65174-09-M-Audio-BX5-D2/dp/B005F3H6Q8
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
post #3 of 5 Old 12-28-2012, 02:03 PM - Thread Starter
bjaurelio's Avatar
Thanks for the suggestion, but with $175 being more than I wanted to spend, these are definitely out of my price range.
Most of my limited audio budget goes into my living room. I just need something that does better than the approx 125hz-12khz of the laptop internal speakers.
post #4 of 5 Old 12-28-2012, 02:09 PM
drewTT's Avatar
Quoted: 574 Post(s)
Liked: 602
M-Audio also has a lower end Studiophile line. I have zero experience with those but they do have pretty good reviews.
http://www.amazon.com/M-Audio-Studiophile-Powered-Speakers-Previous/dp/B000MUXJCO
http://www.amazon.com/M-Audio-Studiophile-Professional-Reference-Speakers/dp/B000SDLNKA
drewTT is offline
post #5 of 5 Old 01-02-2013, 09:55 AM - Thread Starter
bjaurelio's Avatar
I want able to catch the guy with the krk's at the right time, but that's fine since I managed to get behringer 2031A's for $100.
Reply Speakers
