wharfedale going from 2.1 to 5.1 oppinion please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-29-2012, 11:30 AM - Thread Starter
sivallakos's Avatar
hi guys! a year ago i decided to setup an acceptable audio system for my room and so after some research i bought
the wharfedale diamond 10.7 (pair), a pioneer vsx-821k, and a mirage omni s10. i have to say that i am very pleased with this setup
but i read that the diamond 10 series has been discontinued due to the launch of the diamond 100. so i decided to make my move
and complete the surround setup before they go out of stock and their price goes sky-high. after some consideration it came down to
this (i'll buy a center and 2 rear speakers) :
front: 2x wharfedale diamond 10.7
center: wharfedale diamond 10CM
rear: 2x wharfedale diamond 10.5
sub: mirage omni s10
did i choose the correct speakers to buy or should i consider a different setup?
sivallakos is offline
post #2 of 4 Old 12-29-2012, 01:06 PM
Paraneer's Avatar
Quoted: 32 Post(s)
Liked: 87
Sounds like you already bought them but are second guessing yourself. Why? I think you did great. You already had the flagship Diamond 10.7's so the proper center would be the 10CM. And while some may consider the 10.5's (a tower) as overkill or rear surrounds, they will more than work and save the cost of stands if you had gone to a monitor type. So I say bravo!
I once had a full 5.0 set of Diamond 9's anchored by the top of the range 9.6 and really enjoyed them so I am very well familar with their capabilities. Best of luck and have fun listening to them.
Marantz PM15S2 LE, Oppo BDP-103, Simaudio Moon 100D DAC
VPI Traveler V2 with an Ortofon Rondo Blue and Simaudio Moon 110LP, Technics SL-1400 with an Audio Technica AT-14sa and Pro-ject Phono Box S
Dynaudio Focus 260's, Rel T-1 and a Panasonic TC-P54S1.
Paraneer is online now
post #3 of 4 Old 12-30-2012, 08:11 AM - Thread Starter
sivallakos's Avatar
LOL, no i haven't bought them yet and if i had believe me i wouldn't second guess it!
as a beginner that i am in the speakers section i was just making sure that i was
going for the correct model of speakers. thanks for the reply.
ps: what did you get after the diamond 9's?
post #4 of 4 Old 12-30-2012, 09:10 AM
Paraneer's Avatar
Quoted: 32 Post(s)
Liked: 87
Vienna Acoustics Bach Grands and Theatro center. I kept a pair of Wharfedale Diamond 9.2's that I still use as my rear surrounds.
Reply Speakers
