5.0 for $2500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 12-29-2012, 11:03 PM - Thread Starter
soggyfish's Avatar
Reposting with a much clearer idea of what I want:
Looking for a 5.0 setup for 70% movies, 30% classical, opera, jazz music
Layout:
6.5 ft ceilings, carpeted
Budget is $2500.
Can't do auditions due to work hours not aligning with when stores are open, so kind of have to go with reviews.
Prefer to spend more money on front, since a lot of music listening will be done from the desk (movies watched from couch).
I will be purchasing a denon 1713 and hsu vtf-15h outside of the $2.5k budget.
Need the front speakers to look like towers, wife's orders. bookshelves with matching boxy stands that make them look like towers are fine (like sierra 1s + tp-24 stands)
Getting so confused between all the different brands and models
  • Deftechs - Read these aren't so great for music
  • MA RX - ?
  • kef q900/600/100 - ?
  • paradigm mon 9 , maybe mon 7 - ?
  • swan t200 - ?
  • ascend sierra-1s - ?
  • songtowers - without ribbon upgrade?
  • philharmonic - ?
  • nht classic 4 - ?
  • jbl studio - ?
  • klipsh rf-82 ii - ?
  • focal chorus - ?
Any more suggestions, or opinions on which of these?
soggyfish is offline
post #2 of 15 Old 12-29-2012, 11:11 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Sounds like those JBL Studio 590's arent so out of your budget anymore tongue.gif Small monitors like the Sierra 1 are going to completely fall apart trying to play from 25' away... I think those JBL's are the ticket for your budget and situation.
Every time you double the distance from your speakers you loose 6 db (4x power) of spl. This is what I was getting at in the other thread. Dont let the audiphoolery confuse you too much, the basics are well, basic.
Jay1 is offline
post #3 of 15 Old 12-29-2012, 11:16 PM - Thread Starter
soggyfish's Avatar
Yeah, after reading a ton, my budget exploded. But I'm pretty firm at $2.5k, don't have much more than that!
Figured that monitors wouldn't really work, hence why the sierras are the only ones on there.
What surrounds would you pair with the jbls?
post #4 of 15 Old 12-30-2012, 01:26 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
These would be the true match
http://www.amazon.com/JBL-Studio-530-Bookshelf-Loudspeakers/dp/B00622STI0/ref=sr_1_1?ie=UTF8&qid=1356855780&sr=8-1&keywords=studio+530
Putting you at $2550 with the 590's and 520C.
You could also go with these if you intend on wall mounting, and save $100
http://www.bhphotovideo.com/c/product/638082-REG/JBL_8320_8320_Compact_Cinema_Surround.html
Or you could go even cheaper with any variety of speakers. Surrounds are far less critical then the front 3 as far as matching goes
Jay1 is offline
post #5 of 15 Old 12-30-2012, 09:25 AM
psycholis's Avatar
Quoted: 64 Post(s)
Liked: 67
For that size room, what about Klipsch? The high sensitivity means you can get to the same volume with less receiver power.
Marantz SR-5007 Klipsch WF-35, RP-450C, WB-14 theater
Marantz 2325 Klipsch Forte ii stereo
SVS PB-2000
LG 55LN5600
Sony PS3, Xbox 360, Wii U
psycholis is offline
post #6 of 15 Old 12-30-2012, 09:40 AM
commsysman's Avatar
Quoted: 973 Post(s)
Liked: 523
!) A pair of PSB Image T6 speakers for the front, with a pair of Image B4 speakers for the rear and a C4 center. Those should run around $2000 or so total. I think the Image T6 is the best-sounding speaker you can get for under $1500. I had them for 2 years and they were great.
2) A pair of Monitor Audio Silver RX-6 speakers with a pair of BX-1 speakers and a Bronze BX center; around $2000 or so.
commsysman is online now
post #7 of 15 Old 12-30-2012, 12:44 PM - Thread Starter
soggyfish's Avatar
any reasons why you don't recommend the c5 center and the rx center? it seems like it would come under $2500
post #8 of 15 Old 12-30-2012, 01:04 PM
zieglj01's Avatar
Quoted: 939 Post(s)
Liked: 846
With the Monitor Audio RX Silver - go with the RX Silver center.
Also put Focal on your list - they are good with Movies and Music
Good price for new in the box
http://www.accessories4less.com/make-a-store/brand/focal/results/1.html
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #9 of 15 Old 12-30-2012, 01:28 PM
justindo's Avatar
Since acoustic music is a big part of your listening, you definitely want good mains with a matching center. Unfortunately, your budget isn't huge and you'll be powering the speakers with a receiver in a large room, so the speakers need to be easy to drive. I'd recommended the Focal Chorus 726V, CC700V Center, and 706V rears. You should be able to get these five speakers for $2500 or less. I've heard good things about the Salk Song Tower and center too. The three Salks would be around your budget and you could get some cheap rears.
justindo is offline
post #10 of 15 Old 12-30-2012, 09:40 PM - Thread Starter
soggyfish's Avatar
Pricing out the Focal Chorus set at the local retailer brought it to $3000 before tax. Where is it < $2500?
And the Salk Songtowers are only recommended with the RAAL tweeter, which brings it to $2k + $700 for the towers and $800 + $400 for the center, a bit too expensive.
post #11 of 15 Old 12-30-2012, 09:50 PM
zieglj01's Avatar
Quoted: 939 Post(s)
Liked: 846
This is an option:
In Post #8 - you can get Focal towers and center for $1100. Plus, you can get the 705V for
surrounds here > http://www.dedicatedaudio.com/inc/sdetail/34398
That still leaves you with $1000
Who AM I
post #12 of 15 Old 12-30-2012, 10:13 PM
justindo's Avatar
You should be able to get a 30% discount pretty easily from an authorized dealer. If not, find another dealer.
justindo is offline
post #13 of 15 Old 01-02-2013, 08:41 AM - Thread Starter
soggyfish's Avatar
Well, wife stopped by the local dealer and approved the Focal Chorus set that was recommended here, so that's what we ended up with. Ended up getting a decent discount, so only a little overbudget smile.gif
I haven't heard the speakers yet, since the speaker cable hasn't gotten here yet, but the wife heard them in store and said they were great.
Thanks for all the help!
post #14 of 15 Old 01-02-2013, 11:11 AM
zieglj01's Avatar
Quoted: 939 Post(s)
Liked: 846
Have Fun and Enjoy
Who AM I
post #15 of 15 Old 01-04-2013, 01:54 AM
justindo's Avatar
Glad it worked out for you and I hope you like your new system. Congratulations.
justindo is offline
Reply Speakers
