Aperion or Ascends? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 12-30-2012, 12:30 PM - Thread Starter
Ryder125's Avatar
I'm looking at the Ascends Sierra-1 with the centre for my fronts which comes to $1200 or the Aperion Intimus 5T and 5C which comes to $1300, kinda undecided on which to go for, this is for TV/Moives right now it'll be in a smaller room but don't want to limit the speakers I buy from not sounding good in a bigger room in the near future. My logical brain is telling me to go with the Aperion for the towers and bigger 3-way centre but the reviews I hear on the Sierras make this much tougher, can those book shelves Seirras and the book shelve centre the Seirra complete with towers and 3-way centres? What I want is a solid movie performance, the kind that gives that feel that your there. Any feed back?
Ryder125 is offline
post #2 of 33 Old 12-30-2012, 03:27 PM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
How big is the room and is $1,200 your overall budget for now or are you stopping after this $1,200 for awhile?
Panny 65st60 / Denon X1000 / EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
Selling 1 e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is online now
post #3 of 33 Old 12-30-2012, 04:14 PM - Thread Starter
Ryder125's Avatar
Right now the room is small but I might be putting it in a bigger room about 20ft by 20ft and 15ft ceilings and if I put it in that room the seat will be about 18ft away. $1200 is for the LCR I have crappy rears for now then I'll upgrade that and the sub later, by summer. Kinda leaning towards the Sierras as their upgradeible and looks like a raal tweeter kit is on its way but not sure if they can fill that room with amazing sound from movies?.
Ryder125 is offline
post #4 of 33 Old 12-30-2012, 04:20 PM
gtpsuper24's Avatar
Liked: 99
The Aperions will probably offer more output for movies. But the Sierra's will probably sound alittle better, but that doesn't mean much if a speaker might not be able to keep up output wise.
Some other options to consider would be the Arx A5 tower, 3 way. http://www.theaudioinsider.com/product_info.php?p=arx-a5-floorstanding-loudspeaker&products_id=227&
I'm using a pair right now and they sound great.
I'd also look at HTD level 3 http://www.htd.com/Products/level-three-speakers
gtpsuper24 is offline
post #5 of 33 Old 12-30-2012, 04:39 PM
vardo's Avatar
Quoted: 41 Post(s)
Liked: 130
I've had those same exact Aperion speakers in an 1800cu ft room. They have a very good, easy to listen to sound. Well balanced,
and smooth sounding (somewhat warm sound signature). And the piano black I had were beautiful.
But I know the it's tough deciding because the Sierra's have had very good reviews. And both companies are great,
and have wonderful customer service.
Even though the Aperion's are rated at 6 ohm, they are still easy to drive. Maybe give them a try. The
Towers will surprise you, they look very small (but deeper than average). I believe they have a 30 day
trial period, and you can ship them back at their cost.
I think the Sierra's have a more neutral sound signature, with somewhat of an excellent mid range.
It's a tough decision to make, but if you do decide on the Sierra's, then by all means, do not
cheap out on the stands, and buy some wooden crap. Save up and buy some sturdy, well
built, metal stands....maybe something like these......http://www.parts-express.com/pe/showdetl.cfm?partnumber=240-750&utm_source=google&utm_medium=cpc&utm_campaign=pla&utm_term=%7Bkeyword%7D
Maybe someone with experience with the Sierra's can chime in with their opinion.
Good luck,
vardo
vardo is offline
post #6 of 33 Old 12-30-2012, 06:36 PM
gtpsuper24's Avatar
Liked: 99
Ryder just to clear things up alittle are you talking about the Sierra towers or bookshelfs compared to the Aperions?
post #7 of 33 Old 12-30-2012, 06:44 PM - Thread Starter
Ryder125's Avatar
Sierra book shelves, the towers are more then I want to spend when you add in the centre channel. Anyone know if the Sierra-1 can be wall mounted?
Ryder125 is offline
post #8 of 33 Old 12-30-2012, 06:54 PM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
You could take a look at EMP and HTD if you want to build a little quicker. Both are VERY solid from what I actually hear (emp) & what I read (htd). Both offer towers that match center so you could move the bookshelves to the rear if you move.
bitterwaste likes this.
post #9 of 33 Old 12-30-2012, 07:27 PM - Thread Starter
Ryder125's Avatar
Vardo,
Thank you for the feedback on the Aperions! it is kinda tough to pick, I hear that the sierras can run with towers and won't be a problem in large rooms, then I read a review and they say for them to be used in small to medium rooms, so that's kinda confusing. Aperions I'm sure would be a sick setup that will look good and will handle a bigger room no problem with the towers and bigger centre but part of me will always question if the sierras could match them in a larger room and if I'm missing out.... Errrrrrr. If I lived in the states I would order the Aperions and give that 30 day trail a go but I live in Canada and return shipping is something I'd have to pay for wish cuts into my budget a lot.
Do the Aperions throw down a big detail sound stage? I read a review on the older 5T and they said in the movie I am legend when the deer jumped in front of the mustang that it blew across the soundstage, do you notice this kinda performance with your 5T?
Ryder125 is offline
post #10 of 33 Old 12-30-2012, 07:38 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Wow. That is 6K cu sq ft. From 18ft away, I would probably open up my options to more sensitive higher SPL speakers. There is a whole thread dedicated to high SPL speakers, you may want to read through it and get some ideas.
ack_bk is offline
post #11 of 33 Old 12-30-2012, 08:53 PM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
Or multiple, larger drivers
post #12 of 33 Old 12-31-2012, 05:59 AM
uncola's Avatar
Quoted: 43 Post(s)
Liked: 37
I'd go with the aperion towers. The sierras with their single 5" driver definitely don't sound good for movies in a large room. I haven't heard either speakers though, just basing it off reading reviews. But I've read a lot, at least! hehe
Gear list: Main setup - Kef Q900, Svs sb12-nsd subwoofer, onkyo 609 receiver, epson 8350 projector, elitescreens sable 92" screen, mac mini htpc
Bedroom setup: Philharmonic Audio New Philharmonitors, Odyssey Kismet Monoblocks, Soekris Dac, Hattor active preamp
uncola is offline
post #13 of 33 Old 12-31-2012, 11:37 AM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
The 5t only has dual 5.25" drivers.....for $950. I'd be looking elsewhere as you're going to want to upgrade again if you're moving into a larger space.
HTD Lvl 3: dual 7" drivers, 2.5" midrange and horn loaded ribbon == $800/pr
EMP e55ti: triple 6.5" drivers, dual 5.25" midranges and 1" silk dome == $800/pr
Again I haven't heard the HTD, but most that have them seem to really like them. Same with the EMP. I love mine so far and I've heard my fair share of drivers, setups, etc. The e55ti's were measured +/- 2db, good off-axis response, easy to drive, nice aesthetics, ability to get extremely loud with low distortion (very nice for larger rooms!), etc etc. Not knocking on the Aperion stuff because I hear the V.G. stuff is great, but I'd think the 2 above will best the Intimus line fairly easily
post #14 of 33 Old 12-31-2012, 01:14 PM
gtpsuper24's Avatar
Liked: 99
+1
I would also add the Arx A5 tower to the list of $800 towers. Triple 5.5" XBL2 woofers, 5.25" midrange and neo planar tweeter.
post #15 of 33 Old 12-31-2012, 02:09 PM
NewHTbuyer's Avatar
Liked: 41
If the OP looks at high sensitivity designs due to his large room, I feel I should mention the Tekton Lore with sens of 98dB. I have not heard them, but they have gotten some great reviews.
http://www.tektondesign.com/lore.html
$999 per pair.
NewHTbuyer is offline
post #16 of 33 Old 12-31-2012, 03:14 PM
JEFFREY GTS's Avatar
I second for the Tektons. I have spoke to Eric a few different times and for what I am looking for. Both outstanding movie and music playback, he suggested the M-Lore. At only $649.
http://tektondesign.com/lore-m.html
I'm your Huckleberry
JEFFREY GTS is offline
post #17 of 33 Old 12-31-2012, 03:19 PM - Thread Starter
Ryder125's Avatar
Fo the 5.25 woofers in the Aperions really not enough for bigger rooms? I see the Sierra towers use the same sizes woofers so do the song towers.. The 5Ts have as many as the song towers and 1 less than the Sierra towers.. I know both of those towers are better but why can they fill the room but the 5Ts can't? I'm no expert on this so that doesn't make sense to me can someone explain that to me?
Ryder125 is offline
post #18 of 33 Old 12-31-2012, 03:49 PM
vardo's Avatar
Quoted: 41 Post(s)
Liked: 130
Ryder125,
If your gonna move into a 6,000 cu ft room, the 5T's are not going to be sufficient. I would recommend the 6T's, but they have discontinued
them, at least I don't find them on the web site. That's to bad, because they would work in a 6,000 cu ft room. The Sierra's won't work
either. Driver(s) are too small.
I've been doing audio for many years. I could recommend other speakers I've had, but I would need to know exactly what you are
looking for in a sound signature......warm, neutral, etc. And do you want the speakers to be used mainly for home theater?
Home Theater/music ratio?
I've had everything from Klipsch LaScallas to Axiom to Sonus Faber. Do you want a "dynamic" sound like a movie theater,
(by dynamic, I mean in you face, efficient speakers, maybe horn loaded, like Klipsch, or Chase Home theater speakers
(although they are going out of business, Craig Chase will still honer any warranties if a problem arises). Usually IMO
most, not all, dynamic speakers are not that great with music. But you can try to find the best of both worlds.
I myself like a warm sound signature, thus the present Sonus Faber's. They sound great for music, and still good IMO
for home theater. I have tons of concert DVD's, SACD's. But that line of speakers are out of your price range.
That 6,000 cu ft room is huge. You are gonna need a hell of a sub or dual subs, to fill up that area. I can recommend
that also. But so can others. You have been given a few good alternatives to the Aperion's and Sierra's, but I'm
not familiar with those suggestions. And if I come across as a know it all, I certainly don't. wink.gif. Just trying
to help.
vardo
vardo is offline
post #19 of 33 Old 12-31-2012, 04:08 PM
gtpsuper24's Avatar
Liked: 99
Cross them at 80hrz and you shouldn't run into any issues. They are 2 ways and not 2.5ways which is typical of small dual driver towers. Which means both drivers will be producing midrange and bass instead of a fullrange top driver and just bass driver in a 2.5way. Total surface area of the dual 5.25" woofers is close to and 8" so I don't think you will have much issues.
post #20 of 33 Old 12-31-2012, 10:45 PM - Thread Starter
Ryder125's Avatar
At the end of jan I'll have about $2000 so I'm now thinking of just waiting till then and buy the Sierra towers or the Aperion GVT then the center 2 months later and build it that way... Get the tower and most expensive one out of the way first then it makes it easier and faster to add.
Ryder125 is offline
post #21 of 33 Old 01-04-2013, 12:01 PM
backmeup's Avatar
The Sierra1 is an astounding speaker (you have read the reviews obviously). Get the Sierra1 now. Enjoy it, and when you move to a bigger room, you can place your old Sierra1 fronts as surrounds while putting Sierra 1 towers at the front :-). For imaging and the purity of their beautiful "sound" the Sierra1 is extremely hard to beat (I know of some who place them close to a number of Sonus Faber offerings--- which is more than you want to spend biggrin.gif ).
You obviously know your choices are winners either way, but Dave F. at Ascend has designed some shockingly good stuff and then made it affordable for many. Congratulations on whatever you choose from your list!
backmeup is offline
post #22 of 33 Old 01-04-2013, 12:19 PM
backmeup's Avatar
By the way, you do not want to wall mount a Sierra 1. They should be placed on a quality stand a fair distance (≥18") out from the wall. You can wall mount, but it would defeat the point to having a speaker like the Sierra1.
backmeup is offline
post #23 of 33 Old 01-04-2013, 12:55 PM - Thread Starter
Ryder125's Avatar
why not wall mount the Sierra-1? isn't that when you'd use their Q plugs?
Ryder125 is offline
post #24 of 33 Old 01-04-2013, 01:34 PM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
My Sierras (surrounds) are wall mounted.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
post #25 of 33 Old 01-04-2013, 01:50 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
That is one of the reasons (rear close to wall placement).
The two different plugs are for changing the port response.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #26 of 33 Old 01-04-2013, 04:04 PM
Newbie01's Avatar
Quoted: 44 Post(s)
Liked: 36
I am debating on speakers now myself and the three front runners are HTD LvL 3, EMP and HSU (For sub almost positive I will go with HSU but speakers are a little more ify...just like HTD and EMP makes subs but don't think I will be coming near those with 10 ft pole)....
From the simple stats you put out here...for a Home Theater system it seems EMP should beat the ever living heck out of HTD. 2.5 vs dual 5.25 for Mid!!! I know the silk dome sure cheaps out in allot of ways vs the horn loaded ribbon though... Any thoughts?
Newbie01 is offline
post #27 of 33 Old 01-04-2013, 05:40 PM
DLO
DLO's Avatar
If I could not listen to both side by side to judge, and I had to choose solely on design principles, I would choose Ascend for 1 reason and 1 reason only: their cabinets are uglier. I figure at least some of the price on the Aperions is for that glossy finish, and I'm not really into that. I'd rather have every single dime go to performance and wouldn't even care if they painted the damn things or not when they left the factory.
DLO is offline
post #28 of 33 Old 01-04-2013, 07:29 PM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
I can't say that the e55ti is more dynamic than the HTD lvl 3 without getting much further into what makes one speaker more dynamic than another. I know a little about it, but not enough to say one or the other. Cone area, efficiency, compression (at a certain point), power, etc etc all play part in "dynamics". I will say that these e55ti's mated with the e56ci are extremely dynamic front 3 to me. I would love to put an amp to the front 3..maybe some day. The nice thing about EMP is that they offer a free 30-day IN-HOME trial. If you don't like them...send em back at no cost to you! It's that easy. For a speaker of this price, that (to me at least) is very nice looking and also is +/- 2db with solid off-axis response, I don't understand why it's not recommend/purchased more. With a sister company like RBH they must be doing something right. I researched for a few months and it seemed like every review, both professional and non-professional was positive. People that have heard or own speaker 3x+ the price say they can hold their own easily and that is something to be proud of. They've been taken to multiple Audioholics events where Salk and other companies demo and people have stated they were shocked at the EMP booth and how well the e55ti's performed. Seriously...they're pretty good and VERY good for the Black Friday price.
Anyways, either of your choices will most likely make you happy. Not being biased here and this is totally up to you....but why not try the EMP setup and if you're not feeling it after 30 days then send it back and pick up the HTD stuff. It's definitely a pain to wonder if another speaker would best what you have, but at the end of the day if you're happy and you fell within your budget (if you're budget minded), that's all that matters. Like I said though, either one will likely make you very happy. I wish there was someone close with the HTD's so I could hear them
post #29 of 33 Old 01-04-2013, 07:55 PM
gtpsuper24's Avatar
Liked: 99
That is Arx's design philosophy. High tech components in a brown paper bag. So cast alloy woofers with licensed XBL2 and splitgap technology, neo magnet planar ribbon tweeters with cast alloy face plate, braced cabinets. They just use plain black vinyl across the line, nothing fancy or shiny. They even ship in plain brown boxes nothing fancy with graphics or anything.
post #30 of 33 Old 01-04-2013, 08:30 PM
BufordTJustice's Avatar
Quoted: 188 Post(s)
Liked: 315
I'll go out on a limb and say that the Arx A1b compares favorably with the Sierra 1 with the dome tweeter. I don't think it would be quite as good as the Sierra, but it is definitely in the ballpark. I've heard both, just not in the same room or system.
Sent from my SPH-D710 using Tapatalk 2
Arcam AVR300, Adcom GFA-5500 (Main L+R), Panny BDT-500 Media Transport, Toshiba SD-9200 CD Transport, MiniDSP 2x4 HD, Vizio XVT 55" LED/LCD (full direct-backlit w/ local dimming), Darbee DVP-5000S, Chane A2.4 mains, Chane A3rx-c surrounds, Center TBD, Subwoofer exceeding 120dB at 2m groundplane @ 20hz (custom build), BJC ten-white w/ ultrasonically welded WBT locking banana connectors.
BufordTJustice is offline
Reply Speakers
