Tower Speakers, HDTV - Direct connection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-30-2012, 03:31 PM - Thread Starter
amerqureshi's Avatar
Have a great HDTV but the sound is terrible. Has anyone tried unhooking the internal TV speakers and wiring tower speakers directly to the TV (without using an external amp)? How is the sound?
Trying to get away with having to buy ANOTHER 5.1 amp but still getting semi-decent sound.
amerqureshi is offline
post #2 of 7 Old 12-30-2012, 04:56 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
You say you have a great TV but you want to rip it apart and hook up tower speakers to it?sry but that will not work...just get an inexpensive avr and use that...won't cost much and then you can leave the TV intact...wink.gif
Doing what I do best...LIVIN!
josh6113 is offline
post #3 of 7 Old 12-30-2012, 04:58 PM
ambesolman's Avatar
Quoted: 1076 Post(s)
Liked: 901
Whatever amps are in the tv for its speakers wouldn't be enough to drive towers anyway.
ambesolman is offline
post #4 of 7 Old 12-30-2012, 04:59 PM
vardo's Avatar
Quoted: 41 Post(s)
Liked: 130
I don't think the amp for your TV speakers has the power to drive tower speakers. You don't
need to buy a 5.1 amp again. They still sell stereo amps biggrin.gif.
Maybe get something like this....http://www.crutchfield.com/p_580M282/Onkyo-M-282.html?tp=180
or there are cheaper one starting at $100. Don't know what your budget is or what your
tower speakers are.
vardo
vardo is offline
post #5 of 7 Old 12-30-2012, 05:03 PM
JerryLove's Avatar
Liked: 79
If all you want is power for speakers: hit a pawn shop and spend $30 on an old AVR.
JerryLove is offline
post #6 of 7 Old 12-30-2012, 05:12 PM
afrogt's Avatar
Quoted: 1058 Post(s)
Liked: 761
tower speakers are.
vardo
That Onkyo amp wont work because it doesn't have a volume control. You need a preamp to connect to it. More than likely his new HDTV only has an optical output and what is needed is a variable analog output to use with that M-282.
Onkyo makes several stereo receivers that would work though. This one has an optical input too.
http://www.crutchfield.com/p_580TX8050/Onkyo-TX-8050.html?tp=47041
OP should provide the make and model of the TV, it would help tremendously.
Afro GT
afrogt is offline
post #7 of 7 Old 12-30-2012, 05:29 PM
ceh383's Avatar
Quoted: 421 Post(s)
Liked: 2585
Why not a sound bar?
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
Reply Speakers
