Need suggestions: 2.1 or sound bar for my bedroom - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-30-2012, 04:20 PM - Thread Starter
Joni1991's Avatar
Hi everybody,
I previously had Bose Cinemate system (the cheaper one of them) but I sold it while I moved far away from previous location and it was too expensive to get my stuff with me. I was pretty pleased with system and it wouldn't be too bad to go with it again but then I feel bored to buy similar system that I already have and I'd like to try something new.
I'm going to spend maximum of $600 on the system and I definitely don't want there to be surround speakers at all. So I'm looking for most likely 2.1 system or the sound bar. I prefer more active speakers than those which requires amplifier but everything is okay to suggest if it fits my budget.
Joni1991 is offline
post #2 of 8 Old 12-30-2012, 09:48 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
2.1 is a sure improvement over a sound bar. How is this going to be placed in your room? A receiver has multiple advantages over powered speakers for a setup like yours.
Speakers $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16882325059
Sub $180
http://www.newegg.com/Product/Product.aspx?Item=N82E16882665157
Receiver $250
http://www.newegg.com/Product/Product.aspx?Item=N82E16882115373&Tpk=v373
Jay1 is offline
post #3 of 8 Old 12-31-2012, 05:28 AM - Thread Starter
Joni1991's Avatar
It's going to be with TV. The set you showed me looks awesome so I think I go with it and not going to start spending too much time with this choice.
Joni1991 is offline
post #4 of 8 Old 12-31-2012, 08:22 AM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
I own those Def Tech speakers (well actually the SM450) and those are very good! Nice base extension and very crisp, clear sound!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #5 of 8 Old 12-31-2012, 11:02 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
No prob, have fun!
Jay1 is offline
post #6 of 8 Old 12-31-2012, 11:47 AM - Thread Starter
Joni1991's Avatar
I have placed order for the setup Jay1 showed me earlier. I cannot buy right now but for the future is there some good option to add front center channel to this set? smile.gif
Joni1991 is offline
post #7 of 8 Old 12-31-2012, 11:56 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Your best bet would be to just buy another pair of 350's and use 1 as a center. This is the matching unit
http://www.amazon.com/Definitive-Technology-Speaker-Single-Black/dp/B000TD8XCU
Jay1 is offline
post #8 of 8 Old 01-01-2013, 07:15 AM - Thread Starter
Joni1991's Avatar
While I have to wait anyways to buy center channel later I guess I will go for the one which you showed up at Amazon. It is still probably good improve compared to just regular speaker so I'm willing to pay more later. smile.gif
Thanks again Jay1!
Joni1991 is offline
Reply Speakers
