Building a theater need speaker help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-30-2012, 09:22 PM - Thread Starter
bmwbrad's Avatar
New here so thanks in advance for your help....I am building a theater in my basement and I am having trouble figuring out speaker setups... I have klipsch in my living room which I like but just want to get some opinions. I am going to be using an onkyo tx717 for my receiver. Any good suggestions for a 7.1 set up for under 700 dollars. If I spend much more my wife might make me sleep in the theater. Thanks again.
bmwbrad is offline
post #2 of 7 Old 12-31-2012, 09:12 PM
JimWilson's Avatar
Quoted: 1296 Post(s)
Liked: 1613
You want to get 7 speakers and a subwoofer for $700? That's a pretty tall order. It would be better to get less speakers, but better quality. You might want to consider starting with 3.1 or 5.1 and then upgrading when funds become available. What size is your room?
If you take yourself too seriously, expect me to do the exact opposite
JimWilson is online now
post #3 of 7 Old 01-01-2013, 06:44 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
There are some kit speakers out there that are phenomenal for a very low price. How are you at building Legos? Because these kits just come as a flat pack so all you have to do is assemble, glue and install the drivers. Well, the crossover can be a bit tricky, but you can get them pre-assembled for a price. But if you are limited to $700 including the sub that's an awfully tall order. You could do 5 of these for $625 and save up for a sub. These will keep up with or outdo anything costing upwards of $500 each!
http://www.diysoundgroup.com/waveguide-speaker-kits/karma-series-kits/karma8-kit.html
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #4 of 7 Old 01-01-2013, 07:26 AM - Thread Starter
bmwbrad's Avatar
My budget went up a little talked the wife into it. The room is 15x32 and with a sub I am looking at like 1200. I found a good deal on amazon for 5 small energy speakers who I heard are made by klipsch? And I was thinking of pairing them with some good towers maybe some klipsch ref. and a ref sub. Not sure to go with a 10 or 12 inch sub and that would put me around 1200. And other suggestions. On better speakers combos for the money.
bmwbrad is offline
post #5 of 7 Old 01-01-2013, 08:30 AM
commsysman's Avatar
Quoted: 987 Post(s)
Liked: 526
For a large room like that, your priority had better be for some relatively large front speakers with decent sound quality.
I suggest that you consider the KEF iQ70 speakers, which are less than half or their former price now at KEF Direct ($600 per pair). If you do not want floorstanding speakers, you could go with the KEF Q300 for about the same price.
Those are very good to build your system around.
For a center speaker, the KEF C6LCR speaker is $269.
You should get a decent 12-inch subwoofer with as much power as possible.
The Klipsch RW12D is good, and the SUB12-HG is also fairly good. (around $300-400).
That will give you a good 3.1 system, which is where 95% of your sound comes from.
Satellite speakers can be had for much lower prices later; they are relatively non-critical.
commsysman is offline
post #6 of 7 Old 01-01-2013, 12:10 PM
JimWilson's Avatar
Liked: 1613
Even if your ceiling height is only 8 feet that nets you around 4000 cubic feet of total volume, which is well beyond satellite territory. Anything that small will pretty much be swallowed up by the room.
Along with the KEF's another possible system would consist of the Pioneer Andrew Jones speakers; the SP-C22 center, SP-FS52 for the front left and right, and then a pair of SP-BS22 for surrounds. Add the PowerSound XV15 subwoofer and you would have a good setup that fits in your budget.
post #7 of 7 Old 01-01-2013, 01:47 PM
gtpsuper24's Avatar
Liked: 99
+1^
The PSA XS15 or XV15 would both be good.
gtpsuper24 is offline
Reply Speakers
