Any better suggestions for 5.1 setup (in-ceiling rears) for around $500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 12-31-2012, 10:02 AM - Thread Starter
prskier17's Avatar
My budget can't go much over $500... I'm looking for bookshelf size fronts, a center channel, in-ceiling rears (the only aesthetic and wife approved option), and a small sub (preferrably less than 12" wide to fit in the only "approved" space!). I'm planning to purchase a Denon AVR-1913 or AVR-2113CI to also run two outdoor speakers but those are outside of this budget. Here's what I'm thinking:
Polk: TSI-200's for front LR
Polk: CS10 for CC
Polk: RC80i for rear (would consider RC65i but the larger holes would actually help fish the wires that need to go outside)
This puts me just over $500 at Amazon and Polk has a promotion for a free PSW111 sub if you spend over $499. I see mixed reviews on this sub but haven't found any other options in my price range that include a fairly compact sub.
This is for a living room setup in a house with an open floor plan. The living room is 14' wide x approx. 18' long but the total area is about 40' long and has 9' ceilings. I don't need to shake the house but want decent sound quality 50% music / 50% movies.
I'm open to suggestions!!! Thanks!
prskier17 is offline
post #2 of 14 Old 12-31-2012, 03:20 PM - Thread Starter
prskier17's Avatar
I've been doing more research today and see another option might be the BIC Formula FH6-LCR for all three fronts or as just the center with Formula FH-65B as left and rights. BIC makes in-ceiling as well and I could use the Formula F12 sub... but this puts me up to $700. Any thoughts on the Polks??? I haven't been able to configure anything else close to that price point.
post #3 of 14 Old 12-31-2012, 03:37 PM
vm8444's Avatar
http://www.amazon.com/Energy-Classic-Theater-System-Black/dp/B001202C44
Then inexpensive Inceiling you can find as rears.
Then your left with an extra pair of bookshelves.
These sound awesome check reviews.
I like Marantz
The latest denons lower line seem flimsy.
Yamaha seems really solid lately too.
theaudioguy.ca
vm8444 is offline
post #4 of 14 Old 12-31-2012, 04:45 PM - Thread Starter
prskier17's Avatar
Thanks for the response... I dig further but since I'll be using the system around 50% for music will the Energy's 3" woofers compare with the dual 5'1/4" woofers on the TSI200's?
post #5 of 14 Old 12-31-2012, 07:12 PM
vm8444's Avatar
Probably not the polks will sound fuller
not by much though.
Energy sub seems better
Can you not hear them first?
vm8444 is offline
post #6 of 14 Old 12-31-2012, 07:13 PM
vm8444's Avatar
Crazy how nice they sound though
For such little money.
For ht I'd go with the energys
Music tough call
vm8444 is offline
post #7 of 14 Old 01-01-2013, 09:05 AM - Thread Starter
prskier17's Avatar
Alright VM844.... you've convinced me to take a longer look at the Energy Take Classics.... smile.gif I see this setup for $299 @ Newegg... maybe I'll try this and hold off on the rear in-ceiling speakers so I can upgrade the receiver. The only thing I'm challenged with is the size of the sub. Are there any good options if I bought the 5.0 system and purchased a compact sub?
post #8 of 14 Old 01-02-2013, 02:57 PM
vm8444's Avatar
Great ,
You don't have spend much on a receiver ..
Marantz Yamaha
Nrg 1403 Marantz
673
Or 573 Yama
There's a sub on eBay with free shipping from they're high end line.
Connoisor
Just type in search
Energy sub 8
Energys just need one screw to nicely mount on a wall.
Then you'll see it for $218 free shipping buy it now.
I'd jump quickly .....
theaudioguy.ca
vm8444 is offline
post #9 of 14 Old 01-02-2013, 03:30 PM
vm8444's Avatar
I think I saw them for $100 off today on new egg .
vm8444 is offline
post #10 of 14 Old 01-02-2013, 03:39 PM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
I suggest that you consider the Martin-Logan MLT 2 system, with the addition of the Polk PSW505 subwoofer. You should be able to do that for around $500-550.
The PSW111 is pretty much worthless, which is why you can get it for free...lol. I also think the Energy Take Classic system is totally worthless, and a huge ripoff.
If you want an actual SUBwoofer, it needs at least a 12-inch driver, with adequate power to drive it. Smaller ones just thump and huff and do not produce any real bass.
commsysman is online now
post #11 of 14 Old 01-02-2013, 03:45 PM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
A 3-inch WOOFER????
ROFL
The MINMUM size for something to truly be called a "woofer" is probably around 5 to 6 inches in diameter, and that is with the loading of a properly designed enclosure.
3 inches is the size of the speaker in a cheap clock radio.
It takes a lot of chutzpah to call a 3-inch speaker a "woofer"!!!
It is absurd; that's even too small for a decent midrange speaker, let alone a woofer!
(I also think everything about the Energy Take Classic system is underpowered and absurd...)
post #12 of 14 Old 01-02-2013, 03:48 PM
blake18's Avatar
Quoted: 299 Post(s)
Liked: 183
My klipsch RCX-4 has 4" woofers and it has fantastic midrange performance, not lacking at all.
Lumenlab "Community driven video lab".
blake18 is offline
post #13 of 14 Old 01-02-2013, 04:02 PM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
I don't doubt that at all. There is nothing wrong with a 4-inch midrange, IF it is well-engineered and constructed.
My Gallo Acoustics CL-3 speakers have high-quality bass down to below 40 Hz, and they do it with only 5 1/4 inch drivers.
BUT....
--there are two of them, not one (a lot more total cone area), per speaker.
--the drivers are $200 long-throw low-mass carbon-fiber drivers with exceptionally large voice coils and magnets to drive them at high power levels.
--the enclosure uses a patented transmission-line loading system using special (expensive) materials.
These drivers have very little in common with the kind of cheap 5-inch drivers you get in a $100 speaker.
post #14 of 14 Old 01-02-2013, 04:15 PM
eljaycanuck's Avatar
Quoted: 1226 Post(s)
Liked: 1798
My budget can't go much over $500... This is for a living room setup in a house with an open floor plan. The living room is 14' wide x approx. 18' long but the total area is about 40' long and has 9' ceilings. I don't need to shake the house but want decent sound quality 50% music / 50% movies.
That is a huge area for any modest system to fill with sound - and especially for a budget- to moderately-priced sub to pressurize - but here's my suggestion:
- a pair of bookshelf speakers for ~$200, such as these Polk Monitor 40s; and
- an SVS PB-1000 ($499, shipped).
Later on, add a center speaker, and then surrounds.
eljaycanuck is offline
Reply Speakers
