Home theater speaker selection - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-31-2012, 02:48 PM - Thread Starter
semschaf's Avatar
Please help! I am in the process of choosing equipment for a home theater/entertainment area. It will be used for 80 percent movies, 20 percent music. I am not an audiophile but would like the system to sound good. The room is 17x45x13. The couch is about 14 feet from the tv which is mounted over a fireplace. My budget is $6000-$10000. I was considering def tech mythos 10 for lcr, gem xl x4 for surrounds, 2 Hsu VTF-15h subwoofers, and denon 4311 receiver. I have grown skeptical of the on walls but I am limited with center channel options due to the tv mounting. Please give any ideas as to what you would suggest. I am open to on walls and floor standing, although my wife would prefer on walls. Thanks
semschaf is offline
post #2 of 5 Old 12-31-2012, 04:12 PM
JerryLove's Avatar
Liked: 81
Movies.
4 meter listening distance.
45' room.
I admit I'm a bit of a fanboy of late: but given the architectural constraints (your need to go on-wall for your center) and your desire for high fedility (which shies away from on-wall fronts) and the fact that you've not indicated if your surrounds need to be on-wall.
I'm gonna recommend Salk SongTower RT's ($2600) for L/R, a custom designed matching center channel ($1300?) and then your surrounds will depend on what form-factor they need to be.
I like your subwoofer choice.
The mirage OMD-5 surrounds are neatly mounted in the pic near the bottom of this page
http://www.audiocircle.com/index.php?topic=112563.0
Get to post #23 here and see where a custom design was used to accommodation the poster's unusual mounting needs.
http://www.audiocircle.com/index.php?topic=112378.msg1168195#msg1168195
And bluntly: it's a beautiful room. IMO, it should have audio gear that adds to the aesthetic.
JerryLove is offline
post #3 of 5 Old 01-01-2013, 08:58 AM - Thread Starter
semschaf's Avatar
Thanks I will look into your suggestion. Anyone have any other thoughts?
semschaf is offline
post #4 of 5 Old 01-01-2013, 09:36 AM
Knucklehead90's Avatar
Quoted: 414 Post(s)
Liked: 348
Since the Salk Song Towers fit well inside your budget what else is there to say? They are an excellent speaker - and a work of art as well. If you don't like them you can send them back for a refund. Not many send them back.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
----- FOR SALE
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #5 of 5 Old 01-01-2013, 10:10 AM
JerryLove's Avatar
Liked: 81
Philharmonic, though that would send you back to Salk for the center. Dennis Murphey (Philharmonic) was involved in several of the Salk designs.
I could name some other names; but of the speakers I've heard (which is many) those are the best I can recommend in this price range.
Names I hear others suggest around this price, but that I have not heard include Tekton and Ascend.
The big-box names in this price range include Paradigm (Studio line) and Bowers and Wilkins (CM line). I have owned both. I consider the Salks and Philharmonics markedly superior.
Reply Speakers
