Building a surround sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-01-2013, 09:11 AM - Thread Starter
ewhite17's Avatar
I am a newbie. I have about 300$ to spend on my speakers and sub. I want 5.1. What is the best set of speakers I can get for this money. Also ill have about 200$ to spend on the receiver. Factory Refurb products don't bother me. Please help thank you.
ewhite17 is offline
post #2 of 4 Old 01-01-2013, 09:19 AM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
With that budget I'd forget about the .1 and concentrate on the 5. Any sub in that budget range will not be a 'sub'. If $300 is all you have for speakers you should buy the best 2 used speakers in your area that you can find. If you get lucky and find a center channel that matches the mains thats even better. I'm sure you'll agree that a decent 2.0 or 2.1 setup would be better than a crappy 5.1 - right?
Post your location and I'll show you what is available on Craigs List.
The best 'cheap' 5.1 speaker setup I know of is these:
http://www.amazon.com/Energy-Classic-Theater-System-Black/dp/B001202C44/ref=sr_1_1?ie=UTF8&qid=1357060775&sr=8-1&keywords=energy+speakers
ewhite17 likes this.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #3 of 4 Old 01-01-2013, 09:35 AM
benfica1's Avatar
Quoted: 14 Post(s)
MLT 2 maybe?
benfica1 is offline
post #4 of 4 Old 01-01-2013, 09:58 AM - Thread Starter
ewhite17 is offline
Reply Speakers
