Extreme Noob... denon 1913 7.1 speaker questions help please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-02-2013, 04:45 PM - Thread Starter
mochacody's Avatar
Hi guys I'm sure this has been answered for other people since I've seen some posts but not the exact same config I'm thinking of.
I'm looking at getting a Denon 1913 and thinking of pairing it with Polks for all the 7.1.. my question is are these compatible ?
I'm still learning about clipping and under powering or overpowering and just don't want to screw this up and waste money.
Any suggestions would be welcome. I'm using Polk because Ive been told by many that they are reliable and decently priced
Receiver
http://www.bestbuy.com/site/Denon+-+875W+7.1-Ch.+3D+Pass+Through+A/V+Home+Theater+Receiver/4792355.p;jsessionid=CABFB5E8343019804CD208A0A6BF099B.bbolsp-app03-23?id=1218529597324&skuId=4792355&st=denon%201913&cp=1&lp=1
center
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290212
sub
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290130
fronts
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290269
surrounds x2
http://www.newegg.com/Product/Product.aspx?Item=N82E16882290200
Thank you guys
mochacody is offline
post #2 of 6 Old 01-02-2013, 05:57 PM
IHaveAMullet's Avatar
8 ohm speakers rated to 125 W/ch & powered sub...you should have no issues. Nice choice on the receiver too, just bought one myself. I will be using mine for 5.1 with a dedicated zone 2 for the deck.
mochacody likes this.
IHaveAMullet is offline
post #3 of 6 Old 01-02-2013, 06:30 PM - Thread Starter
mochacody's Avatar
just to clarify are you saying the speakers i chose are good because the rating is what keeps throwing me off..
and yeah this seems like the best receiver available for a good price and Ive been thinking possibly doing the two zone also
thanks for the help
post #4 of 6 Old 01-02-2013, 07:37 PM
Elihawk's Avatar
Quoted: 1326 Post(s)
Liked: 1161
There really are not speakers that are good for a reciever! Short of not pairing low sensitivity speakers with a low powered receiver, speakers don't sound better with certain receivers!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #5 of 6 Old 01-02-2013, 07:51 PM
zI think that'd what op wanted to clarify - that the impedance was matched to the receiver, which of course it is. The only issues I could see would be playing car audio speakers which are too low impedance and would cause clipping and overheating.
post #6 of 6 Old 01-02-2013, 08:05 PM - Thread Starter
mochacody's Avatar
thank you i think i understand now and cant wait to get my setup finished...
oh and i see your current project kudos, looks awesome i hope to get the scratch together to do up my basement soon
Reply Speakers
