Budget $250 book shelf speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-03-2013, 02:09 PM - Thread Starter
es2002's Avatar
Hello,
I just purchased a Denon 2112 receiver and need a pair of book shelf speakers with a budget of $250.
- Room Size: 15X25, carpet
- Mostly watch action movies and listen to classical rock.
I have been looking at the Polk RTi6 and Cambridge S30, but can't decide which one fits my needs better. Will be adding a sub and may add a center channel if needed. I am also open to suggestions. smile.gif
es2002 is offline
post #2 of 11 Old 01-03-2013, 02:12 PM
BufordTJustice's Avatar
Quoted: 310 Post(s)
Liked: 567
Take a look at the Arx A1b. It is an extreme value in its price class. I can't speak for the Cambridge speakers, but the A1b would embarrass the Polk in sound quality, detail, smoothness, and overall sound output (especially bass output). Not even close between those two.
Here's a thread with pix comparing the midwoofers of the $500 Axiom M22 to the Arx A1 (the older, smaller bookshelf):
http://www.theaudioinsider.com/forum/showthread.php?1605-Arx-s-Competiton
The A1b would be worth a look for you.
EDIT: Product link
http://www.theaudioinsider.com/product_info.php?p=arx-a1b-monitor-loudspeaker&products_id=65&
I should also add in the interest of full disclosure that I helped develop and field test the Arx A5 towers. I am not an employee of TAI, but I did help to develop the A5.
Arcam AVR300, Adcom GFA-5500 (Main L+R), Acurus by Mondial A200x3 for center and surrounds, Panny BDT-500 Media Transport, Toshiba SD-9200 CD Transport, MiniDSP 2x4 HD, Vizio XVT 55" LED/LCD (full direct-backlit w/ local dimming), Darbee DVP-5000S, Center and L+R is pending, pending subwoofer.
BufordTJustice is offline
post #3 of 11 Old 01-03-2013, 02:17 PM
zieglj01's Avatar
Quoted: 1675 Post(s)
Liked: 1569
The clear choice for me, is the Cambridge S30
Another nice one, is Acoustic Energy Aelite One
http://www.ebay.com/itm/281044029292?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
__________________________________________
Who AM I
Speakers -- Snell K7 > Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #4 of 11 Old 01-03-2013, 02:31 PM
gtpsuper24's Avatar
Liked: 100
+1 for the Arx A1b if you can bump your budget $50.
gtpsuper24 is offline
post #5 of 11 Old 01-03-2013, 02:36 PM
gtpsuper24's Avatar
Liked: 100
Heres the picture since you can't see them unless you register. Still haven't been able to figure out how Jon has designed such a nice bookshelf in the price range he has it in. Really the woofers in the Arx models are like smaller verisions of the Exodus Anarchy woofer that Kevin Haskins designed.
Thanks Buford I had forgotten about that thread and those pictures.
post #6 of 11 Old 01-03-2013, 02:39 PM
Quoted: 310 Post(s)
Liked: 567
I haven't heard the Cambridge and don't know about what driver technology it uses. However, I don't know of any sub-$600 bookshelf that uses XBL2/SplitGap driver technology. The magnetic planar tweeter is also a very low distortion design.
You ditched your Axioms for the A1's, correct?
post #7 of 11 Old 01-03-2013, 02:41 PM
gtpsuper24's Avatar
Liked: 100
Yes sold all the Axioms and have all Arx setup now. The A1s are doing rear surround duty right now with A5 fronts, A2 center and A2 side surrounds.
post #8 of 11 Old 01-03-2013, 07:25 PM
Elihawk's Avatar
Quoted: 1335 Post(s)
Liked: 1166
You can get Def Tech sm350/450s for 200 dollars/pr from New egg!
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #9 of 11 Old 01-03-2013, 09:30 PM
postrokfan's Avatar
Quoted: 602 Post(s)
Liked: 3646
Another vote for the S30s!
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is online now
post #10 of 11 Old 01-04-2013, 04:39 AM
DLO
DLO's Avatar
If you have a Guitar Center near you, you can go take a listen to some Behringers--they have a couple of passive speakers that fit your budget. Or if you have pre-outs on your receiver, you can check active models also from other companies.
http://www.guitarcenter.com/Unpowered-Monitors-Studio-Monitors,New-Gear.gc?ipp=100
The Behringers tested well a few years back in a blind shootout, though I can't find the link right now.
likemovies likes this.
DLO is offline
post #11 of 11 Old 01-04-2013, 08:37 AM - Thread Starter
es2002's Avatar
Thanks for suggestions everyone. I am planning on visiting Ascend Acoustics this afternoon to check out the CBM 170's. smile.gif
es2002 is offline
Reply Speakers
