Can black acoustic sponge tiles be died to white? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-04-2013, 06:14 AM - Thread Starter
stevethebrain's Avatar
Quoted: 106 Post(s)
Liked: 25
I'm concidering appling some acoustic treatment behind (for starters) the front main speakers however I prefer a white panel on my white wall.
1.would spary painting cover the sponges open pours and ruin the sound absorbtion effect?
2.would soaking in chorlrox cause the sponge to deteriate?
any tips besides making my own fiberglass panels (I'm not interested in small particals of fiberglass in my breathing air) is appreciated.
STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 8 Old 01-04-2013, 07:19 AM
Bill Fitzmaurice's Avatar
Liked: 4706
Whatever you need to know can be found here, including how to make user friendly traps:
http://www.realtraps.com/articles.htm
Bill Fitzmaurice is online now
post #3 of 8 Old 01-05-2013, 06:31 AM - Thread Starter
Quoted: 106 Post(s)
Liked: 25
Bill I've allready read you'r suggested site amoung others (before posting).
there is no mention of dieing the sponge.
BTW I recently upgraded front speakers and it sounds unreal.
not sure if my room actualley needs acoustic treatment thinking even a few tiles will improve the listening experience.
STB
post #4 of 8 Old 01-05-2013, 08:01 AM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
I wouldn't paint, dye or try to bleach black acoustic foam white. You can just buy white acoustic foam tiles. Google search "white acoustic foam". There are several suppliers on the net that sell white acoustic foam tiles in many sizes and absorption patterns. Here is a link to one that I found.
http://www.silentsource.com/afoams-hushfoam.html
Secret Squirrel is online now
post #5 of 8 Old 01-09-2013, 08:19 AM - Thread Starter
Quoted: 106 Post(s)
Liked: 25
I'm concidering this mattress sponge .
http://www.clivir.com/lessons/show/egg-crate-foam-mattress-pad-x2013-walmart-vs-target-com-pricing.html
not sure if my room actualley needs acoustic treatment thinking even a few tiles will improve the listening experience is this true or false?
STB
post #6 of 8 Old 01-09-2013, 08:23 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
STB
Usually the color of acoustic tiles is changed with paint or stain. If the paint is thick and gloppy it will cover up the absorbing holes and fissures and spoil some or all of the acoustic properties. Covering black with white would seem to need a thick coat of paint.
Other possibilities - covering the tile with fabric.
Then there is the high road - buy new!
arnyk is offline
post #7 of 8 Old 01-09-2013, 08:28 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
STB
Absorbing material needs to be stuff that is intended for the purpose.
This ain't.
The benefits of acoustic treatment is roughly based on the percentage of the room area covered and the quality of the absorbing material. You get extra points for putting stuff where it does the most good, but you are going to get benefits by the square foot - many of them.
If fiberglass and mineral wool give you problems, there is always cotton batt based products that are sold for the purpose:
http://www.audimutesoundproofing.com/acoustic-material.aspx
...and competitive products. Google is your friend!
arnyk is offline
post #8 of 8 Old 01-09-2013, 09:33 AM
Liked: 4706
Not so. By and large there's no functional difference between acoustical foam and open cell urethane mattress or packing foam. The linked foam will work just as good as acoustic foam. Memory foams typically are of much higher density, and therefore will work even better in the low end.
What is a consideration is fire resistance. Most acoustical foams are fire rated. Not all foams are, so when being used for a room treatment one should make sure the product is fire rated.
Reply Speakers
