Goodbye Center Channel - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #361 of 458 Old 12-19-2013, 08:56 PM
sbradley02's Avatar
Originally Posted by D Bone View Post
Well, I received my Level Two Center, and it lasted 36hrs. The end was last night when we were watching Modern Family and I was switching the center speaker setting between small & none trying to talk myself into the center, and my wife who was sitting next to me but was playing a FB game while watching TV said, "Ewww, whatever you did there, I don't like it". I engaged the Level Two Center from phantom. She never pays any attention to what I'm doing and can't hear even a large change, so when she said that, I actually laughed, explained what change I made and she said "See, you should've just left well enough alone".
For me, in my home, with my equipment and in my layout, a physical center speaker is the compromise solution. I suppose I could completely rearrange the living room, but that would require finding a new wife, and I'm kind of fond of the one I have. I could buy a new home, but that seems to be a little extreme just to add a physical center speaker. So, I took the easy way out and my theater sounds better because of it. cool.gif
Out of curiosity, what are your mains?
sbradley02 is offline
post #362 of 458 Old 12-19-2013, 09:02 PM
D Bone's Avatar
Quoted: 294 Post(s)
Liked: 374
HTD Level Two Towers
Samsung UN60D6420 ~ DirecTV HR-44 ~ Sony S5100 BD ~ Roku 3 ~ Denon AVR-X3200W ~ SVS Prime Bookshelf L/R ~ SVS Prime Satellite Surrounds ~ MultEQ XT L/R Bypass ~ Power Sound Audio XV15
D Bone is offline
post #363 of 458 Old 12-19-2013, 09:04 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Originally Posted by kbarnes701 View Post
Yes, agreed. What I meant was that some people seem to prefer the idea of a phantom center, period.
I'll tell you why I do it. I have a multi-purpose living room with a pull-up ~85" screen that is flanked by a pair of KEF Q65s in stereo. No good place for a center. In this configuration I also only run 2.0. It is space-constrained, but quite good. I've previously had a 6.1 system, where my L & R were substantially better than my center - and phantom sounded better there. I think a center is ideal in ideal circumstances, but I think a phantom center works much better in many cases - and it is a configuration option most people overlook, thinking oh, I must have 5.1 or 7.1.
D Bone likes this.
lespurgeon is offline
post #364 of 458 Old 12-19-2013, 11:24 PM
Vacation's Avatar
Originally Posted by Bill Fitzmaurice View Post
True. I made my first center adequate to match my mains at that time. I designed and built new mains and the center no longer worked well compared to the mains. So I designed and built a new center that was the equal of the new mains. End of problem. If your center isn't of the same quality as your mains it won't sound as good as your mains. One need not be Einstein to come to that conclusion. cool.gif
So what would be a "good" horizontal center channel design that's commercially available?
Vacation is offline
post #365 of 458 Old 12-20-2013, 08:10 AM
JerryLove's Avatar
Liked: 79
The number of posters on this and the other thread who have tried a matching center and preferred phantom just keeps mounting. I predict it won't cause even one single nay-sayer to reconsider.
JerryLove is offline
post #366 of 458 Old 12-20-2013, 08:12 AM
sbradley02's Avatar
Which other thread? And your prediction is in little doubt.
post #367 of 458 Old 12-20-2013, 08:59 AM
Associate Editor @ AVS
imagic's Avatar
Quoted: 4447 Post(s)
Liked: 7351
The B&W Nautilus HTM2 is properly designed:
photo by AVS member ahartig
Mark Henninger
imagic is online now
post #368 of 458 Old 12-20-2013, 09:11 AM
JerryLove's Avatar
Liked: 79
Interesting: because I had this one setup and the phatom was superior in that room:
post #369 of 458 Old 12-20-2013, 09:19 AM
imagic's Avatar
Liked: 7351
Right, because that speaker still has multiple horizontal drivers—the Nautilus design is proper, the Diamond is still compromised.
Mark Henninger
post #370 of 458 Old 12-20-2013, 11:11 AM
Roger Dressler's Avatar
Quoted: 1483 Post(s)
Liked: 683
If that is true, it also applies to the HTM2, as the port is not aligned with the center drivers. And that then tilts the advantage back to the HTM1, as the symmetrically displaced woofers "phantom image" directly in line with the mid/tweet. With a sufficiently low crossover, there will be no significant off-axis lobing issues.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is online now
post #371 of 458 Old 12-20-2013, 11:16 AM
imagic's Avatar
Liked: 7351
Port resonance is low enough that the bass is not localizable, that's true for just about any decent vented speaker.
Mark Henninger
post #372 of 458 Old 12-20-2013, 11:51 AM
JerryLove's Avatar
Liked: 79
Your absolute claim: horizontal drivers = bad.
Your contradiction of your absolute claim: horizontal != bad if the frequency is "low enough that [it] is not localizable"
Though I'm pretty sure that you still cannot support that claim. What stops the right side of a driver from interfering with the left side of the same driver? As I recall, anything spaced <1/4 wavelength acts as a single driver. I can go look up the physics if you like.
post #373 of 458 Old 12-20-2013, 11:55 AM
TullikB's Avatar
Hello Please excuse in advance if this in not the correct forum for my question.
I am thinking about adding a centre speaker to my current Paradigm set up (its taken too long). I have two (2) Monitor 7 (v3) and a Paradigm sub powered by an Onkyo TX-Sr 500. My budget leans towoards a Paradigm Cinema 110C v3 center channel which I can get on ebay for $80 plus $50 shipping to Canada. Will this addition be compatible with existing set-up? Thanks for any input. Lar
TullikB is offline
post #374 of 458 Old 12-20-2013, 12:22 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 112
That is a center I would NOT buy...a straight MTM.
You want one that has the tweeter & midrange stacked vertically, and neither inline with the mid-bass drivers.
The Paradigm SE center is a much better choice. I would rather pay the extra $260 for the SE, than pay the $109 for the 100C v3.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #375 of 458 Old 12-20-2013, 12:26 PM
imagic's Avatar
Liked: 7351
Choosing the right crossover frequency is how you prevent that.
And, there you have it. The HTM2 Diamond crosses over to the midrange at 350Hz. 1/4 wavelength at 350 Hz is about 9.5 inches, and the center-to-center spacing on the HTM2's woofers exceeds 9.6 inches. Now personally I don't think that's a big deal, the woofers will act as one driver for most of their effective range, but not all of it. By contrast, 1/4 wavelength at port tuning is typically several feet—somewhere in the 5-10 foot range for the HTM2 nautilus—and again, so low that the sound from the port is not localizable.
The HTM2 Diamond is simply not as close to ideal in terms of driver alignemnt as the HTM2 Nautilus, which is perfectly logical considering that brand's hierarchy.
Mark Henninger
post #376 of 458 Old 12-20-2013, 03:22 PM
TullikB's Avatar
Thanks for the input. I looked up SE on line and wonder if i'm on the right track are they also known as ~~Centre 1, Centre 3 ??
Thanks again
TullikB is offline
post #377 of 458 Old 12-20-2013, 03:24 PM
Liked: 683
Except in this case the spaced woofers are covering some of the same spectrum as the midrange driver between them, with crossovers with finite slopes. The only real way to know the HTM1's off-axis response is to measure it.
imagic likes this.
post #378 of 458 Old 12-20-2013, 03:47 PM
Bill Fitzmaurice's Avatar
Liked: 3855
CTC spacing need not be 1/4 wavelength unless the listening distance is quite close. In general 1 wavelength is fine. Where 1/4 wavelength spacing is significant is the cone to cone distance for fully additive mutual coupling. This speaker doesn't look bad where comb filtering is concerned, since it is a 3 way with a low crossover point to the mid. Widely spaced two ways tend to be far more problematic.
Where they do dispersion on the horizontal plane will be well less than half that of one driver, which is another reason why horizontal MTMs aren't the best idea. In the case of the HTM2 the woofers could be closer together, but still, with a 350hz crossover to the midrange I don't see a major issue. Again, it's widely spaced 2 ways that have problems.
imagic likes this.
Bill Fitzmaurice is offline
post #379 of 458 Old 12-22-2013, 03:55 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 112
Thanks again
It would seem the SE series is the older. The center 1, 3 are the Monitor series. I saw the SE center on Amazon.
Being you have the Monitor series, get the monitor center.
4DHD is offline
post #380 of 458 Old 12-25-2013, 10:19 AM
sbradley02's Avatar
A secondary benefit in my case is without a center I have enough amplifier channels available to bi-amp the mains
post #381 of 458 Old 12-25-2013, 12:18 PM
A9X-308's Avatar
Quoted: 1040 Post(s)
Liked: 771
Passive biamping provides no benefit.
Montekay likes this.
A9X-308 is offline
post #382 of 458 Old 12-25-2013, 12:24 PM
pokekevin's Avatar
Liked: 102
Oh noes...another debate in a debate is going to start lol.
Happy Holidays folks!
D Bone likes this.
pokekevin is offline
post #383 of 458 Old 12-25-2013, 12:31 PM
A9X-308's Avatar
Liked: 771
Sorry, I couldn't resist.
A9X-308 is offline
post #384 of 458 Old 12-25-2013, 01:03 PM
D Bone's Avatar
Quoted: 294 Post(s)
Liked: 374
mind blown
D Bone is offline
post #385 of 458 Old 11-10-2014, 10:35 AM
boontok's Avatar
Quoted: 13 Post(s)
Liked: 0
I like the idea of not having a center speaker, mainly for it's poor placement in my system (too low below the screen, too high above it), but I like having control over the level of dialogue that was mixed to the center channel (my hearing drops significantly in the 2k-4k range). Is there a way to control the center channel level into the front L&R if you delete the center speaker? I have an Integra DTR-50.3.
boontok is offline
post #386 of 458 Old 11-10-2014, 10:42 AM
sbradley02's Avatar
Unfortunately this is an incredibly rare feature (adjustment of phantom center level), even though it would be trivial to implement in software. Your Integra doesn't have it, and the only one I have personally worked with that does is the Theta Casablanca.
post #387 of 458 Old 11-11-2014, 09:15 AM
Luke M's Avatar
Quoted: 223 Post(s)
Liked: 67
I've looked at a bunch of receiver manuals recently (Denon, Marantz, Yamaha, Onkyo, Sony) looking for any hint that they offered any features related to downmixing...found nothing. My 16 year old budget Sony receiver is just as capable in this regard as a top of the line 2014 model.
Luke M is offline
post #388 of 458 Old 11-11-2014, 12:10 PM
Eyleron's Avatar
Quoted: 225 Post(s)
Liked: 115
My 2005 Pioneer 1014 THX receiver reduced the dynamic range a great deal when downmixing to 4.1. A number of other threads on AVS and HomeTheaterShack talked about and tested this with other receivers as well.
I have Master & Commander DVD & BluRay. If I pick the DTS track, the phantom center doesn't make the receiver reduce DR, but on the Dolby Digital track, it does, and it's terrible. The same as using the receiver's dynamic range compressor settings, which robs the soundtrack of all life and impact.
Other films, even new ones like the Star Trek reboot do this. I'd drag a much less capable center speaker out of storage just to watch the movie with the DR it's supposed to have.
I haven't seen it definitively confirmed that the DR reduction doesn't occur on Blu-Rays over HDMI. As I don't have a receiver with HDMI I couldn't test that.
I'm going to an acoustically-transparent screen shortly, so I'll be building another matching speaker for center.
Eyleron is offline
post #389 of 458 Old 11-11-2014, 01:19 PM
Montekay's Avatar
Quoted: 18 Post(s)
Liked: 31
Exactly! There is no reason to omit the center channel level control just because you are not using a center channel speaker. I've never understood why this is done. Hopefully one day manufacturers will wake up and realize how incredibly stupid this is.
As for needing a center channel, I've always felt that if you only sit on axis and your main speakers image well, there is no need for it. You can always sum the center channel information into the mains creating your own phantom mode and not lose the center channel level. Of course this mandates external amplifiers and the ability to build the electronics to do it or these days you could do it with a miniDSP module and not need to build anything.
As for maintaining center image it's amazing how little it takes to do that. I once put a 2.5" full range driver in as center, crossed into it at 600 Hz and summed below 600 Hz back into the mains and it maintained center image well very far off axis. So basically it was phantom mode from 600 Hz down and an actual very tiny center speaker 600 Hz up. I just did it for s#its and grins but it was amazing how well it worked.
Barring experimental projects like the above, if you are going to have a center speaker it should be comparable to your mains. The original center in my HT was a constant directive symmetric pair system, basically W, MB, M, T, M, MB, W but when I put in near floor to ceiling line array mains the center was lacking. The final solution was a CBT array with comparable output capability with the mains. So basically if you use a center speaker, don't skimp on it.
mk
Montekay is offline
post #390 of 458 Old 11-11-2014, 03:10 PM
Luke M's Avatar
Quoted: 223 Post(s)
Liked: 67
Also LFE and surround.
That's interesting. If you don't use a sub, receivers will redirect bass from the center equally to left and right speakers. Using a small center and the highest crossover frequency the receiver allows (e.g. 250Hz) just might simulate a powerful center, hmm?
Luke M is offline
Reply Speakers
Paradigm Studio 60
