BOSTON ACOUSTICS Horizon MCS130 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-04-2013, 09:33 AM - Thread Starter
ewhite17's Avatar
I am building a low budget surround sound system. Will these speakers be my best bet for spending less than $350 on speakers alone? Is there any major drawbacks of buying factory refurbished speakers?
Website:
http://www.accessories4less.com/index.php?page=item&id=BOSMCS130MIST&extra=a%3A2%3A{i%3A0%3Bs%3A40%3A%2203823345592a403b2f4a37a59384e7ab28f02be1%22%3Bi%3A1%3BN%3B}
Also would going with these speakers plus a onkyo refurbished receiver be better than an onkyo HTIB like
http://www.accessories4less.com/make-a-store/item/ONKHTS9400/Onkyo-HT-S9400-THX-7.1-Ch-Network-Home-Theater-Receiver/Speaker/1.html
ewhite17 is offline
post #2 of 6 Old 01-04-2013, 12:42 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
No, you could do better.
You could get 3 pairs of these silver RBH speakers with 5.25" drivers for $80/pr and then add a $100 Dayton subwoofer
http://www.ebay.com/itm/RBH-MODEL-AC51SILVER-2-WAY-BOOKSHIP-SPEAKER-PAIR-/290827248212?pt=Speakers_Subwoofers&hash=item43b6a7a254
Look like this
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-628
Other speakers that might interest you would be Pioneer BS-21 bookshelf speakers.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882117405
If you need smaller satellite speakers this would be a better deal.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882981013
Afro GT
afrogt is online now
post #3 of 6 Old 01-04-2013, 01:20 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
I've purchased refurbs from Accessories for Less and have been happy with the product. Wouldn't worry about it.
That said, I do agree that the Boston's are fine speakers, but you might be able to find a something better for the money. The retail savings listed on the site is sometimes a little generous.
Those RBH speakers look like a great deal. Try to stay away from the HTIB.
BllDo is offline
post #4 of 6 Old 01-04-2013, 03:03 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would look at 3 pairs of the Pioneer BS21
Or, 2 pairs of the RBH AC-51 (get surrounds later)
And this JBL subwoofer
http://www.newegg.com/Product/Product.aspx?Item=N82E16882665157
However, the Boston set can be a nice one for you.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is online now
post #5 of 6 Old 01-06-2013, 08:36 AM - Thread Starter
ewhite17's Avatar
Thank you very much for your help.
ewhite17 is offline
post #6 of 6 Old 01-06-2013, 08:39 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
For around $300-350 you could get the Martin-Logan MLT-2 system , which has larger drivers in the front speakers and a better subwoofer. I would rate it much higher than the Polk system. Amazon has it, as do Newegg and others.
I suggest that you look at that.
The Pioneer speakers sound good, but have a VERY poor sensitivity which makes them a bad choice for use with lower-priced receivers.
A good receiver choice would be the Onkyo TX-NR414 or 313 or a Denon 1612 or 1613. You should be able to get them new for under $250.
commsysman is online now
Reply Speakers
