Question about Emotiva - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 01-04-2013, 04:58 PM - Thread Starter
Quoted: 311 Post(s)
Liked: 43
Hey guys, how u all doing?
so in pursuit of further improving my home theatre system, im reading these great reviews about the Emotive XPA 3 and XPA5.
as u all know, i have a definitive technology 5.1 system, i have bp6 for the front left and right , CLR2002 for the Center channel and BP2X's for the surrounds. my subwoofer is the SVS PB12 NSD. and my receiver is the onkyo NR818.
now, is it true that adding an xpa 3 will really improve the sound quality even more?
i checked on definitive technology website, it says that my front main speakers (the bp6's) have a power handling of 20 - 175 watts per channel. what does that mean? i mean iv read that the emotiva has 300 watts per channel, so does it mean that my speakers wont be able to handle the emotiva at all?
lamonsasa is offline
post #2 of 12 Old 01-04-2013, 05:06 PM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
You've got a pretty solid AVR, so unless your speakers are "power-hungry" and/or you run your system at very loud volume levels in a very large room, the XPA-3 will most likely not improve the sound quality.
It's not "night and day", the way lots of folks seem to think it is. I have a UPA-5 in my set-up (w/ a Marantz SR6003), and a buddy of mine with a similar set-up has an XPA-3 (w/ a Denon AVR-4310), and neither one of us has the amp for POWER or SOUND QUALITY - we have them more for "peace of mind" and "nice to have". If that's what you want the amp for, go for it. If you're expecting miracles, you'll be disappointed.
eljaycanuck is offline
post #3 of 12 Old 01-04-2013, 05:48 PM - Thread Starter
Quoted: 311 Post(s)
Liked: 43
post #4 of 12 Old 01-05-2013, 01:03 AM
jevans64's Avatar
Quoted: 208 Post(s)
Liked: 162
The XPA-2 is 300 Wrms/ch. The XPA-3 is 200 Wrms/ch. I wouldn't bother with an external amp unless you go to 7.1 or beyond. I figure the Onkyo is good for 80w x 7 and probably close to 100w at 5 channels. The only thing you will probably accomplish is give yourself a bit more headroom and take most of the amp load off the receiver. You probably won't hear much of a difference at normal volume levels.
I think the main benefit I got out of mine going from 146w x 5 to 400w x 5 is the addition of 4 more speakers ( to 9.x ) that are now powered by the receiver. Most of the time the XPR-5 isn't breaking a sweat but Total Recall was a pretty aggressive mix which required ear protection in some places at reference levels. I doubt I'm using 25% of the receiver's available power now.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #5 of 12 Old 01-05-2013, 04:33 AM
Gorilla83's Avatar
Quoted: 378 Post(s)
Liked: 524
In your situation I don't see the benefit to using an external amp with BP6's and 2002 front stage. If you had less efficient speakers that required more power I would so go for it, but it's very unlikely you will notice any significant difference with your setup.
Gorilla83 is offline
post #6 of 12 Old 01-05-2013, 05:31 AM
Brian Fineberg's Avatar
Quoted: 3543 Post(s)
Liked: 3517
Not to high jack this thread but I am considering the same upgrade although I have psb image b6 front with c5 center. Would those benefit from an external amp?
Brian Fineberg is offline
post #7 of 12 Old 01-05-2013, 06:19 PM
Randy Schmidt's Avatar
Quoted: 48 Post(s)
Liked: 25
I have a Denon AVR 4520ci as my preamp and the Emotiva XPR-5. 5 channels are ran off the XPR-5 and surround backs are ran off of the 4520ci... I have not been overly impressed with the XPR-5's output compared to my previous 7.1 setup using a Denon AVR 5805. 170 x 7 all channels driven. Any feedback would be most appreciated.
Theater: Denon AVR 4520ci - Emotiva XPR-5 - Denon 3313 BDP - L/C/R Klipsch KL7800 THX, SL/SR Klipsch KS7800 THX SBL/SBL, FHL/FHR, FWL/FWR Klipsch 5800W - (2) Epik Empire subs/(1) DIY 18" sub - Darbee Darblet - Epson 5030UB/150" Fixed Mount Screen
Family Room: Denon AVR X6200W - Sony XBR55X930D - Samsung UBD-K8500 - (5) Speakercraft Profile AIM8 One
Randy Schmidt is offline
post #8 of 12 Old 01-05-2013, 10:17 PM
jevans64's Avatar
Quoted: 208 Post(s)
Liked: 162
If the Klipsch in your sig are the ones you are running on this system, then you probably didn't even need to go beyond the 4520ci. The info at Klipsch say they are in-wall rated at 150 Wrms. Headroom made a difference to ME because my main 5 speakers can all take over 400 watts. My towers can take 1000 watts each. I'm sure my front speakers would sing if I put each of them on an XPR-1 but then I'd have to wear earplugs.
The Denon AVR 5805 was a beast of a receiver. I had a 5803 and the 5308ci I replaced it with was anemic compared to it but that was the trade-off to get updated processing and HDMI.
Are you even tapping the XPR-5 beyond 3 or 4 LEDs? I haven't clipped my XPR-5 yet but I've gotten up to 8 or 9 LEDs on my Surrounds since they don't have a powered sub in them and are 4-way, 1", 5",8",& 12", rated at 450 Wrms. My L/C/R have powered subs, so they peak at about 7 LEDs at -10 dB from reference.
Randy Schmidt likes this.
jevans64 is offline
post #9 of 12 Old 01-05-2013, 10:32 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 437
Having that large of an amp is too often overkill. Your in-wall Klipsch are 91db efficient and your AVR should be able to drive them to reference levels without clipping if you are like most and do not listen at reference levels - the AVR would have served you just fine - as you've discovered. That is one hell of an amp though. Gives you bragging rights over your buddies!
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #10 of 12 Old 01-05-2013, 10:39 PM
jevans64's Avatar
Quoted: 208 Post(s)
Liked: 162
Only reason I added an external amp to begin with is because I was going from the receiver's maximum 7 channels to 11 channels. Needed at least a 4-channel amp for that. Went to EmoFest with the intention of just getting an XPA-5 but there wasn't a fantastic deal on those, so I got the XPR-5 since it was sitting right there in the foyer saying, " Take ME home, Buddy!! " biggrin.gif Got a fantastic deal on it.
jevans64 is offline
post #11 of 12 Old 01-06-2013, 06:57 AM
Quoted: 48 Post(s)
Liked: 25
At +10 on the master volume of the AVR I get 5 or 6 led's on the XPR-5. At normal listening volume -35 to -25, I don't see the led's at all. I would assume when you say reference level you mean MV at 0. Even though all my inwall speakers are Klipsch and they are very efficient, the 4520ci didn't power them very well compared to the 5805. That is why the XPR-5 was added. What will I gain by adding front heights? Thanks for your insights!
post #12 of 12 Old 01-31-2013, 09:44 PM
Eyleron's Avatar
Quoted: 267 Post(s)
Liked: 168
Are you're sure that's calibrated? Normal listening at -35 to -25...and you turn it up to +10? That'd be asking for 115dB peaks from the speaker. That would require 3,000 watts! You don't have that much amplification, and the speakers can't take that, and the box and drivers are physically incapable of that. So something's off here.
If for some reason you do want such levels, the speaker KL7800 is entirely the wrong speaker to achieve such. You need to look to 98-100dB sensitivity speakers with 12" woofers, not to mention the massive subwoofers you'd need to reach 128dB peaks.
SEOS Fusion 10 Max, 88 Special, Volt 10 LX, SVS PB10 and DIY SI18 subs, Denon X4000, JVC RS400 & 2.35:1 AT Screen
Eyleron is online now
Reply Speakers
