How far from the walls are YOUR speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-05-2013, 10:42 AM - Thread Starter
Accuphase's Avatar
Curious how far from the front and side walls your speakers are placed. I have the DefTech SM65 speakers mounted on 26" stands with the back of the speaker 23" from the front wall and 6' from the sides.
I find that if I move the speakers to less than 1' from the front wall, I can easily notice how boomy the sound gets and vocals definitely lose their clarity. I honestly can't hear the difference if the speakers are moved further from the wall than where I have them now while maintaining the distance from the listening chair.
How far from your front and side walls are your speakers and is the placement limited by space / WAF?
Accuphase is offline
post #2 of 6 Old 01-05-2013, 11:06 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
In the LR I designed/built in '97 I had them 5ft from the sides and 4.5ft out from the end wall. It produced very deep and wide soundstage.
Where I live now its almost endless. 9ft to the sides and 6 & 12 ft to the solid walls behind. I say solid as the L/R are setup in front/middle of two 5ft+ wide archways. With the center mounted to the resulting column in between, with 3" thick foam between the back of the speaker and brick wall.
Again it produces a very deep/wide soundstage.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 6 Old 01-05-2013, 11:44 AM - Thread Starter
Accuphase's Avatar
Are you using towers or bookshelves on stands?
post #4 of 6 Old 01-06-2013, 11:45 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
24" tall 3-way speakers, mounted to 13" tall bases. In the past I've had them mounted to 15" subs. But in this room, I preferred them on their bases which puts them 9" lower and the subs stacked behind the column between the archways.
4DHD is offline
post #5 of 6 Old 01-08-2013, 11:00 PM - Thread Starter
Accuphase's Avatar
Besides the 3" thick foam on the brick wall, do you have any other room treatment?
I'd like to use bass traps but the speakers are in the living room so covering corners with traps is not an option. I've tried tuning the speakers by moving the speakers in and out from the front wall and it's clear that the passive radiators on them really boom near walls. My other speakers never pronounced as much bass near a wall as the 65's.
Moving them further apart widens the sound but too far and I lose that extreme center image (i.e. close-mic'd vocals on Norah Jones). I preferred mine to be set about 8 feet apart with no toe in. Sitting 9 feet away, imaging is clear and the soundstage is wide open.
post #6 of 6 Old 01-09-2013, 12:10 PM
neuspeed94's Avatar
My JBL towers are about 30" from the rear wall and about 4' from the side walls. I have no boominess at all. You want to have the rear ports close enough to the wall to add some impact to the bass, but far enough away that they do not cause boominess and muddy up the sound.
neuspeed94 is offline
Reply Speakers
