Klipsch F1 vs Infinity Primus P363 - AVS Forum | Home Theater Discussions And Reviews
Old 01-05-2013, 12:36 PM - Thread Starter
Raka6's Avatar
Hi guys, Im looking to buy a pair of floor standing speakers for my room. I am currently looking at either the Klipsch F1 or Infinity Primus P363 as both are currently on special and can be had for about 250 (pair). So my question is, if you had the choice between these speakers, which would you choose? Thanks!
Raka6 is offline
Old 01-05-2013, 12:45 PM
Elihawk's Avatar
Quoted: 1019 Post(s)
Liked: 868
Have you heard horn/compression speaker before? Some love them, others do not...
I have heard the Infinity Primus p363 speaker and it is a good budget speaker! Alittle warm, but solid for the dollars!
RPGMasta likes this.
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
Old 01-05-2013, 12:54 PM
sdurani's Avatar
Quoted: 4507 Post(s)
Liked: 2912
I would choose the 363, because I prefer wide dispersion speakers with consistent off-axis response.
Sanjay
sdurani is offline
