opinions on polk blackstone 350 s ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 01-05-2013, 01:33 PM - Thread Starter
panzer's Avatar
Quoted: 24 Post(s)
thinking of buying a set of these, looking for owners opinions and what receiver to use, I will be using a sub, thanks
panzer is offline
post #2 of 13 Old 01-25-2013, 08:31 AM
Kurth01's Avatar
I'm looking at these as well. Would be using with a Denon AVR-1913 and would pair with either the Polk PSW125, the Polk PSW505 or the Klipsh Rw-12d. Mine would be a 7.1 set up with the TL350s as L/C/R and front height L/R (I have a pair of in-ceiling Polk RCi60s for rear surround).
I'd love to hear some owners reviews. I've read some commercial reviews from Sound & Vision and Home Theater Sound. Those are very positive, and I've yet to read a negative professional review of these speakers.
But, like the OP, what I'd really to hear would be some AVS forum user reviews. So if you've heard these, any feedback would be much appreciated!
Kurth01 is offline
post #3 of 13 Old 01-25-2013, 08:47 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I think that the 3-inch drivers of the Polk set you mentioned are far too small to produce decent sound levels for home theater.
IMO you would be far better off with the Martin-Logan MLT-2 system which sells for under $400 complete with a fairly decent subwoofer.
You might want to upgrade the subwoofer later, depending on room size and how much volume you want, but the four ML main speakers have 4.5-inch drivers which will give you much more sound; a better system in all respects IMO.
For a relatively low-priced receiver, I would recommend the Harmon-Kardon AVR 1700. Amazon is selling it for $278.
commsysman is offline
post #4 of 13 Old 01-25-2013, 08:54 AM
Smigro's Avatar
Quoted: 208 Post(s)
Liked: 220
$299.99 at Newegg plus a $25 coupon code. Not too bad TBH
http://www.newegg.com/Product/Product.aspx?Item=N82E16882981013&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Home+Audio+Speakers-_-N82E16882981013&gclid=CI3zze3ug7UCFQsGnQodtgMA1w
Xbox GT / PSN ID - Smigro
my blu ray collection - http://www.blu-ray.com/community/col...0&categoryid=7
Smigro is offline
post #5 of 13 Old 01-25-2013, 08:57 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The Klipsch RW12-D is the best sub in that group, by far.
I suggest that you start with a pair of the Polk Monitor 40 or R300 front speakers and a Polk CS20 and add additional speakers to that.
post #6 of 13 Old 01-25-2013, 08:59 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
post #7 of 13 Old 01-25-2013, 10:25 AM
Kurth01's Avatar
Have you actually heard the Polk TL350s or are you opining based on the specs? From everything I've read, they sound really good and put out very good soudn levels for home theater. But I haven't actually heard them and don't know if I'll have an opportunity to. That's why I'm looking for some first hand reviews. I need something small and unobjectionable to my better half, so the TL350s look interesting to me.
I have an opportunity to get the TL350s and the Klipsh sub for about $825, which seems like a decent deal.
Then again, the $275 for the MLT-2 system sounds like a great deal if that system is actually decent. Have you had a chance to listen to the MLT-2s?
Thanks for the help!
Kurth01 is offline
post #8 of 13 Old 01-25-2013, 10:47 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The MLT-2 is very good. Two of my friends have them, and they sound better than any other "box' system I have ever heard.
My experience with the Polks is limited, but my impression was not that good. The speakers became very strained and distorted when the volume was cranked up at all. The laws of physics still apply, and those are very small speakers. The amount of air they can move is small. They don't like it when they are pushed.
If you get the Martin'Logan system, it will sound good by itself.
If you spend another $200 for a Polk PSW505 subwoofer, you will make a significant improvement on that, and your total cost is well under $600.
If you have $825 to spend, there are certainly several better options than the Polk system.
For example, a Cambridge system consisting of a pair of S30 speakers, a pair of S20 speakers, and an S50 center would cost less than $600, and for $200 add a Polk PSW505 sub, and you will have a system WAY WAY better than even the Martin-Logan system.
post #9 of 13 Old 01-25-2013, 11:01 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
The Polk Blackston TL350 is a great speaker set.
http://www.soundandvisionmag.com/article/review-polk-audio-blackstone-tl350
I would take them over the Martin Logans anyday
crazyrob425 is offline
post #10 of 13 Old 01-25-2013, 11:03 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
And you are certainly welcome to spend your money anyway you see fit.
post #11 of 13 Old 01-25-2013, 11:13 AM
Quoted: 443 Post(s)
Liked: 337
Do yourself a favor and next time you talk **** about a speaker GOOGLE it and educate yourself
Yes the ML are a better deal but your information on the TL350's is wrong:rolleyes:
post #12 of 13 Old 01-25-2013, 11:31 AM
Kurth01's Avatar
Ok, I pulled the trigger. Ordered a new but open-box Polk TL350 set and a Klipsh Rw-12d subwoofer. Total outlay = $824.
Unfortunately, I won't be able to have them up and running for a bit. I move into my new place (hopefully) the second week in February. But I'll be sure to come back and post my first hand impressions in case you're still considering your options then.
Kurth01 is offline
post #13 of 13 Old 04-22-2013, 12:51 PM
Dandu's Avatar
I purchased a set of the Polk TL350's along with a polk psw125 and a denon 1713 receiver. They are in a room that is 12x26 and the sound is incredible.
I originally was going to go with some floor speakers but I am glad that I went with the satellites. Even when I crank the volume up there is
zero distortion. Best investment I ever made.
Dandu is offline
Reply Speakers
