BEST bookshelf speaker for under $500. Everybody help out!!! - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 119 Old 01-15-2013, 10:30 AM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Yep. Leave the speakers on small. If you set any of them to large, that bypasses the crossover. 80hz is often a good choice. You could try 60hz and see if you like it better.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #92 of 119 Old 01-15-2013, 11:29 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 788
I bought (2) pairs of Paradigm Mini-Monitor speakers as wides/height speakers to match my other Home Theatre Paradigm speakers.
(2008 Paradigm Monitor 9's for front, CC-390 center, 4 ADP-390 for rear and back surround, hence the Monitor bookshelf for wides/fronts.)
http://www.paradigm.com/products/products-by-category/bookshelf/paradigm/monitor-series-7/mini-monitor
The below picture show the heights mounted, the wides wires routed and they are sitting on the bar stools still as temp solution, I'm modifying my walls to incoperate them.
Those Mini-Monitor speakers are rated 40hz-20khz, and via Audyssey it set them at.....40hz!
I set the crossover to 80hz in my HT, but my point is for standalone bookshelf speakers they can go down to 40hz.
mtbdudex is offline
post #93 of 119 Old 01-15-2013, 10:06 PM - Thread Starter
Truquitos's Avatar
Originally Posted by gtpsuper24 View Post
Guess it depends on what receiver you have as mine for example I can set any of my speakers L/R, C, Surrounds to 40,50,60,70,80,90 ect without disabling the subwoofer. Just go into your receiver and set your L/R main (A1bs) to 50hrz you can leave subwoofer on or off it wouldn't matter just for break in.
this is what my receiver has for the options. not individual speakers to set.
thats how i got my sub set up now.
receiver options
hope those pictures help. as of now i set my speakers as bi amp! just because the picture show 2 speakers instead of a bunch, but i got a feeling that bi amp is not the correct choice here.
Truquitos is offline
post #94 of 119 Old 01-16-2013, 08:56 AM
gtpsuper24's Avatar
Liked: 100
Thats your subwoofer amp correct? Just use the rca subwoofer out from your receiver and plug it into the amp on the back of the subwoofer. Hook your speakers up to the correct binding posts on your receiver NOT the subwoofer amp. Do not use the speaker terminals on your subwoofers amp.
All your speakers should hook in to the correct binding posts/clips on the receiver.
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 100
So hook the front speakers Left and Right to the front left and right on the receiver.
Same goes from the rest, center speakers goes to center channel binding posts label.
On the back of your receiver NOT subwoofer, you should see a RCA output thats labeled LFE or Subwoofer channel. Take your RCA and plug into that and then into the subwoofer amp that says subwoofer in the white colored RCA input. Then switch it to Digtal receiver 5.1 ect (Not Pro Logic) . Set your subwoofer dial to 80hrz with phase at 0.
Set all the speakers to normal not biamp, then just set them to small then since you can't do individual crossovers for each. During the Arx break in you can run them as large at lower volumes that will help give them some bass to break them in.
Don't over think this. Break in isn't a big deal to worry about if you can't get everything exact. It just takes them awhile to start sounding better.
Hope that helps.
gtpsuper24 is offline
post #95 of 119 Old 01-16-2013, 11:26 AM - Thread Starter
Truquitos's Avatar
this is how I got my sub setup now. I will post more pictures later when I get home of the back of the receiver.
post #96 of 119 Old 01-16-2013, 11:35 AM - Thread Starter
Truquitos's Avatar
Hope that helps.
Ok. Later tonight I will work on what you wrote now. Thanks
post #97 of 119 Old 01-16-2013, 11:58 AM
gtpsuper24's Avatar
Liked: 100
That perfect. Now in your receiver menu you set the subwoofer freq to 80hrz but leave the subwoofer freq control knob on the back of the sub set to its highest 150hrz.
That way your receiver will take care of all the crossovers for speakers and subwoofer(s). That lets everything blend together better. Even though your subwoofers knob is set to 150hrz doesn't mean it will get 150hrz signal, it will get 80hrz and slope down from there letting your speakers pick up the rest and everything will blend much more seamlessly.
post #98 of 119 Old 01-16-2013, 09:45 PM - Thread Starter
Truquitos's Avatar
ok great. i made the changes you suggested. in my receiver i set the speakers to SMALL and CROSSOVER to 80Hz. in the SPEAKERS CONFIGURATION i set them to Normal (SB/FW) which is defined as "Normal home theater use with front wide speakers in your main setup" right now im only using my 2 Polk Monitor 70, the CS2 Center and my Sub. the 2 Arx A1b are coming saturday morning!!!!. these are the changes.
Now. when i get my pair of Arx A1b im going to set them as FRONT (Left and right) and my 2 Polk Monitor 70 as rear, but where should i connect them? Surround or Surround Back? Front Height/Wide?
post #99 of 119 Old 01-17-2013, 05:52 AM
skidog's Avatar
Liked: 27
If you are going to use them to the side of your MLP then you want to use the surround connections. For the front you want to hook them up where the others were. The front height input is for mounting 2 speakers up high which from my understanding gives a more enveloping sound and the surround back is for speakers being placed behind you for a 7 channel config. At least that is my understanding of it, I could be wrong. eek.gif
Panasonic TC-P65VT50
Denon 2113ci
Panasonic DMP-BDT220P
Ascend CMT-340SE L/R
Ascend CMT-340SE Center
Ascend CBM-170SE Surrounds
Klipsch RW12-D x 2
skidog is offline
post #100 of 119 Old 01-17-2013, 06:59 AM - Thread Starter
Truquitos's Avatar
Ok, so I guess I'll be connecting them to the surround plugs.
post #101 of 119 Old 01-17-2013, 10:23 AM
gtpsuper24's Avatar
Liked: 100
If your only going to use a single pair of surround speakers 70's, use the "Surround" binding posts. Since they are going to be your only surrounds you can place them anywhere like sides, halfway between side and rear or directly behind will just be preference. But when you decide to go 7 channels you would then move the "surround" to the sides and "Rear Surrounds" would go directly behind.
post #102 of 119 Old 01-17-2013, 12:45 PM - Thread Starter
Truquitos's Avatar
OK great! later on i will sell all my Polks and start working on a better set. ill leave the Arx as front because i been reading they sound and perform better than the Polk. thank you for the help!!
post #103 of 119 Old 01-22-2013, 12:46 PM - Thread Starter
Truquitos's Avatar
ok guys, i got my stands today and my speaker, the stands are almost ready but i came to a problem, my Arx A1b speakers doesnt have a whole to mount them to the stands.
they look hot haha, anyway, what do i have to do to mount these babies to the stands? any help on how o mount the will be appreciate. i have a few screwdrivers and thats about it.
those pictures are from top and botton part of the speakers, as you see there nothing to put a screw there. im new to this.
post #104 of 119 Old 01-22-2013, 12:56 PM
gtpsuper24's Avatar
Liked: 100
They are made of 3/4" MDF so any screw like 1/2" would work. Theres plenty of room on the bottome incase the screw would go all the way through. I've never used screws to hold down the bookshelf to a stand before, i've always used rubber grip pads and stuck the to the stand and provides a non-slip surface.
post #105 of 119 Old 01-22-2013, 02:08 PM - Thread Starter
Truquitos's Avatar
Can you provide me with some links? So using screws at the bottom is fine? I don't wanna damage the speaker with a screw. The Stands came with lots of screws to mount the speakers.
post #106 of 119 Old 01-22-2013, 02:22 PM
bearchan's Avatar
Museum wax will not damage your speakers.
bearchan is offline
post #107 of 119 Old 01-22-2013, 02:44 PM - Thread Starter
Truquitos's Avatar
What rubber grid pads you use? So I can buy them on amazon. Thank you
post #108 of 119 Old 01-22-2013, 02:59 PM
skidog's Avatar
Liked: 27
Just use the little rubber grommets that came with the speaker stands, that's what I did and just now I tipped the stand at least 45 degrees and the speaker didn't move. Unless your hosting AWA in your living room the speakers will stay just fine.
Seriously, I hope you don't drive screws through the bottom of your new speakers!
Denon 2113ci
Klipsch RW12-D x 2
skidog is offline
post #109 of 119 Old 01-22-2013, 03:07 PM
padgman1's Avatar
^^^^^^ Second that - don't use screws in those nice new speakers!!!!!!!!!!!
padgman1 is offline
post #110 of 119 Old 01-22-2013, 03:32 PM
blake18's Avatar
Quoted: 315 Post(s)
Liked: 191
Klipsch rb-61 ii get my vote.
Lumenlab "Community driven video lab".
blake18 is offline
post #111 of 119 Old 01-22-2013, 03:54 PM
gtpsuper24's Avatar
Liked: 100
I just found some of those pads/grippers at Walmart in the hardware dept. I think they were right with those furniture movers/sliders.
These are similar http://www.amazon.com/Super-Grip-Console-Non-Slip-Rubber/dp/B002BQVJ56
post #112 of 119 Old 01-22-2013, 05:59 PM - Thread Starter
Truquitos's Avatar
I definitely don't want to use screws! But I'm having a party so I'm afraid people will bump into them. So I'm gonna look at some grip of some type. Maybe Velcro???
post #113 of 119 Old 01-22-2013, 06:00 PM - Thread Starter
Truquitos's Avatar
Also I need to secure a little bit because I have a little sister, I'm afraid of her hahaha
post #114 of 119 Old 01-22-2013, 06:27 PM
skidog's Avatar
Liked: 27
You could use some blu tack, lots of people around here use it. I know Amazon carries it.
Denon 2113ci
Klipsch RW12-D x 2
skidog is offline
post #115 of 119 Old 01-22-2013, 06:52 PM
benca1's Avatar
+1 on 3 veritas v5.2's!!! I got mine this week from wwstereo and love them!!
benca1 is offline
post #116 of 119 Old 01-23-2013, 11:29 AM - Thread Starter
Truquitos's Avatar
How they sound? How's the soundstage?
post #117 of 119 Old 01-23-2013, 09:01 PM
benca1's Avatar
I
love love love these !! Nicest speakers I have ever owned !! The packaging was awesome and even came with gloves smile.gif sound is amazing to me !! Although I came from klipsch galleries which sucked.
benca1 is offline
post #118 of 119 Old 02-19-2013, 10:00 PM
teester9484's Avatar
Hi, well not sure you've decided on something yet but I'll put in my 2c worth on speakers. I have three bookshelf speakers coming to check out and I can report back by the weekend if you want.
I have a Sony AV unit with 6.1 to test it with. New Yamaha RX-V671 in the box waiting to go in my new "Big Ass Room" aka the BAR. biggrin.gif It is 16*36 feet with 9' ceilings.
What I've ordered is a set of Polk RTI A1, a DCM TFE60B and a set of JBL L820. The last time I did this I compared JBL, Infinity, Polk RTI28 and a few others. The infinity was the closest but the Polk won out. Lately I listened to the new Polk and the famous RTI A9 at Frye's. Both were not impressive as I expected. Maybe it was their amp/receiver setup.
They all run in the $300-350 range per set. Lowest price in order is, DCM, Polk, then JBL.
Cheers
teester9484 is offline
post #119 of 119 Old 02-26-2013, 10:12 AM
Well after listening to the above speakers with music and movies, I've decided to go with the DCM TFE60. They appeared to me and a few others to faithfully reproduce the music. They sounded very much "real or live" and almost like they added another dimension, spacial, a fullness. My past experience with DCM was the same, which is why I wanted to audition one.
The Polk Rti A1 was a close second in reproduction but the speakers volumes weren't very well matched, ie the highs and mids were much more pronounced than lower frequencies. It also didn't sound "real" but canned/compressed or something, almost as if it were coming from a tube, very much one dimensional. I noticed this in the audio room at Fry's in Atlanta as well a few months ago.
The JBL L820 didn't produce a lot of sound compared to the other two due to ohms or just inefficient, not really sure. Even when standing two feet in front of it I could hear the other channel about as loud 6 feet to the side of it. The JBL also sounded artificial like a cheap speaker.
As far as appearances go, in order I liked the JBL, Polk then the DCM. I just don't buy speakers to look at. The DCM's are HUGE for a bookshelf speaker, about 20" deep. People commented they looked like a computer tower sitting there and that's roughly what they are shaped like. The JBL is only about 5" deep and doesn't protrude into the space when wall mounted. The Polk is about 9" deep.
Reply Speakers
