B&W 801/802 alternative - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-06-2013, 03:57 AM - Thread Starter
deffusse's Avatar
Is there any alternative (both performance and sound like) speakers comparable to B&W 801/802 ? For lower price ofc, 4-5k € budget ...
thx for advice.
deffusse is offline
post #2 of 5 Old 01-06-2013, 07:01 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 181
I believe that the Salk SoundScape line would probably best the B&W 800/801, but they may be slightly higher than your budget, cant remember, lol. I also believe that the Salk HT-2TL would come very close, if not succeed the 800/801. Other quality speakers like the Salks, would be the Philharmoic 3, and the Ascend Acoustics Sierra Tower. I think any one of those that I mentioned will have a better, crisper, clearer, more detailed top end compared to the 800/801. The main place that the 800/801's would win is in terms of bass responce. But, if you can afford a quality subwoofer, then that is a moot point. (note-that for subs, I recommend the Seaton SubM, or the JTR Cap or if on a smaller budget you could look at some of the CHT 18.2's or HSU VTF-15, or even build your own, which would probably surpass all of those that I mentioned as far as subs go.) Hope this helps!
Martycool007 is offline
post #3 of 5 Old 01-06-2013, 07:54 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
801 price is what, 9000 euro or so??
commsysman is offline
post #4 of 5 Old 01-06-2013, 11:45 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
New or used?
I'd go for a used Nautilus 802.
Everyone will have a different opinion.
Some forum members may think Salk is better, but I don't.
AcuDefTechGuy is offline
post #5 of 5 Old 01-06-2013, 01:34 PM
JerryLove's Avatar
Liked: 82
Salk would be a problem with shipping costs regardless. I'd think he'd be most interested in speakers available in Europe.
JerryLove is offline
Reply Speakers
