Using Foam Blocks to De-couple bookshelf speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-06-2013, 11:41 AM - Thread Starter
boardinguy100's Avatar
Quoted: 13 Post(s)
Anyone know of better material to de-couple bookshelf speakers from desktop. I can't use stands because there isn't enough room. I happen to have lots of foam but wasn't sure if there was something better.
boardinguy100 is offline
post #2 of 11 Old 01-06-2013, 02:19 PM
Bill Fitzmaurice's Avatar
Liked: 5687
This is all you need, assuming you need anything at all. 'De-coupling' is pretty much a myth, promoted by companies that sell de-coupling products.
http://www.lowes.com/ProductDisplay?partNumber=90059-46478-90059&langId=-1&storeId=10151&productId=3374228&catalogId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
But if you do have some buzzing between the speakers and desk this stuff will fix it.
Bill Fitzmaurice is offline
post #3 of 11 Old 01-06-2013, 05:50 PM
65 Electra Glide's Avatar
Quoted: 78 Post(s)
Liked: 50
Wouldn't shelf liner from the dollar tree work just as well?
65 Electra Glide is offline
post #4 of 11 Old 01-06-2013, 07:59 PM
Liked: 5687
Is it 3/32" thick rubber?
post #5 of 11 Old 01-07-2013, 07:05 AM
mark62's Avatar
Liked: 88
blu-tack
mark62 is offline
post #6 of 11 Old 01-07-2013, 07:10 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
Something that works really great to put under speakers is the thin rubbery "waffle" material they sell in RV stores to put on shelves to keep things from sliding around.
It comes in a roll and you just cut a piece slightly smaller than the bottom of the speaker with some scissors.
You do NOT want to completely "decouple" the speaker from the desktop; on the contrary.
commsysman is offline
post #7 of 11 Old 01-07-2013, 09:29 AM
Quoted: 78 Post(s)
Liked: 50
Don't really know for sure, but even if it's not, couldn't it could just be doubled or even tripled until it is?
post #8 of 11 Old 01-07-2013, 09:43 AM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
Curious: Why is a thickness of 3/32" significant when it comes either to "de-coupling" a speaker from a shelf, or to fixing buzzing between a speaker and a shelf?
eljaycanuck is offline
post #9 of 11 Old 01-07-2013, 10:01 AM
Liked: 5687
The stuff I linked to is 3/32" thick rubber, sufficient to stop a speaker from buzzing atop a shelf. I don't know if shelf liner from the dollar tree is the same stuff.
post #10 of 11 Old 01-07-2013, 10:19 AM
Liked: 1964
OK, thanks for the clarification.
post #11 of 11 Old 01-08-2013, 11:05 AM - Thread Starter
Quoted: 13 Post(s)
Reply Speakers
