Bookshelf Speaker suggestions? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 01-07-2013, 12:42 PM - Thread Starter
davidlan's Avatar
Hi,
I have a Sonos Amplifier and am currently looking to match it with a good pair of bookshelf speakers. The only caveat here is that I have an entertainment center with 2 shelves that are perfect ear level with the room, and that's where I want to put the pair of speakers I end up purchasing (see pic below). The openings are where the oranges are in the picture, and the internal dimensions are 12" x 12" x 12".
My room is about 15' x 10' and I will almost exclusively be listening to music with these speakers.
My price range for just the pair of speakers is $50-$200. I've been looking at several polk models, specifically these:
Polk Monitor30
and these Polk Audio RTi4 (that I can find discounted sales of).
Anyone have any suggestions of other speakers I should consider? Also, some speakers have rear ports while some have front ports. Should I take this into consideration when actually making my purchase and lean towards getting a front ported pair?
Thanks a lot!
David
davidlan is offline
post #2 of 19 Old 01-07-2013, 01:02 PM
GusGus748s's Avatar
Quoted: 414 Post(s)
Liked: 699
Who in their right mind would put oranges in an entertainment center? rolleyes.gif
Level 3 HTD, HSU, EMP, etc. would be better than polk in my opinion, but RTiA4 should be fine if you've got a sub. Usually bookshelf speakers lack bass.
GusGus748s is offline
post #3 of 19 Old 01-07-2013, 01:07 PM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
The Cambridge S30 ($219/pr. at Amazon.com) is a well-regarded, smaller bookshelf speaker.
Do you already have a subwoofer? If 'no', have you budgeted for one? With bookshelf speakers, you will want a sub to handle the lower frequencies.
eljaycanuck is offline
post #4 of 19 Old 01-07-2013, 01:53 PM - Thread Starter
davidlan's Avatar
Yes, I plan on picking up a sub, most likely this one
http://www.amazon.com/Polk-Audio-10-Inch-Monitor-Subwoofer/dp/B0002KVQBA/ref=sr_1_1?ie=UTF8&qid=1357591901&sr=8-1&keywords=polk+sub
eljaycanuck: I have taken a look at those Cambridge Audio speakers but they have a port in the back that wouldn't be able to breathe. Would this be an issue for sound quality?
davidlan is offline
post #5 of 19 Old 01-07-2013, 02:01 PM
Liked: 1798
That is a modest sub. It will perform well in smaller rooms and at moderate volume levels. IMO, if you can budget more for a better sub, you should consider doing so. If you can't, well, that's just how it is. smile.gif
It shouldn't be an issue as long as you don't block the port. The speakers are 9.2" deep and your cabinet is 12" deep, so you should be fine.
post #6 of 19 Old 01-07-2013, 02:11 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
My preference would be the Cambridge for you - however, they do need more space as
they have good bass energy, and will not perform at their best.
Look at the HTD Level Two speakers - they are good with music
http://www.htd.com/Products/level-two-speakers/Level-TWO-Bookshelf-Speakers
As far as the Polk PSW10 - do not walk, however run from that sub.
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
post #7 of 19 Old 01-07-2013, 02:23 PM - Thread Starter
davidlan's Avatar
OK, thanks.
Do you have a different suggestion for a sub in that price range?
davidlan is offline
post #8 of 19 Old 01-07-2013, 03:33 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
Originally Posted by davidlan View Post
OK, thanks.
I would save another $100 and look at the likes of >
Mordaunt Short
http://www.accessories4less.com/make-a-store/item/MORDCARN9CAL/MORDAUNT-SHORT-Carnival-9-10-100-Watt-Powered-Subwoofer-Calvados/1.html
And maybe JBL
http://www.newegg.com/Product/Product.aspx?Item=N82E16882665157
Who AM I
zieglj01 is offline
post #9 of 19 Old 01-07-2013, 04:29 PM
elmorage's Avatar
Liked: 49
If that space is 12x12 you can knock the hsu and htd 3 off your list, they are both ~15 inches tall. The htd level two might be a tight squeeze too at 11.9 inches.
elmorage is offline
post #10 of 19 Old 01-07-2013, 07:36 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3079
+1 The S30 is one of the best budget speakers out there and will fit in that 12X12 space. I was going to recommend the Pioneer BS22s but they're too tall at almost 13 in.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #11 of 19 Old 01-08-2013, 02:22 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
+1
the S30 (rear ported, so you might need to test it first)
the HTD Level 2 (front ported, but tight fit)
sdg4vfx is offline
post #12 of 19 Old 01-08-2013, 02:25 PM
Kamikaze13's Avatar
Quoted: 98 Post(s)
Liked: 49
I do enjoy the range on my Polk RTi4's, for the price I think they're decent.
I did get mine on a boxing day sale so they were really cheap, can't recall exactly how much though.
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is offline
post #13 of 19 Old 01-08-2013, 02:37 PM - Thread Starter
davidlan's Avatar
Ok, might go with the Polk RTI4s if I can get a good price on them. Any thoughts on the Polk PSW10?
davidlan is offline
post #14 of 19 Old 01-08-2013, 02:54 PM
Kamikaze13's Avatar
Quoted: 98 Post(s)
Liked: 49
I also use that sub upstairs for tv watching and kids movies. It's pretty weak but mine is in a 12' x 18' fairly open room with a 13' high ceiling on most of it.
If you can squeeze more cash there are other subs which perform a lot better, but for $100 it's better than nothing (which is what I had).
post #15 of 19 Old 01-08-2013, 03:02 PM - Thread Starter
davidlan's Avatar
Can you recommend a few other subs for around $150-200? My room isn't too big, around 15'x10' with 9' ceilings.
David
davidlan is offline
post #16 of 19 Old 01-08-2013, 03:39 PM
Kamikaze13's Avatar
Quoted: 98 Post(s)
Liked: 49
This is on sale on amazon right now, Polk Audio PSW505 12-Inch Powered Subwoofer 300watt RMS.
http://www.amazon.com/gp/product/B000092TT0/ref=s9_psimh_gw_p23_d0_i2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=center-2&pf_rd_r=0BRYAJBXGN5A97WKNW0M&pf_rd_t=101&pf_rd_p=1389517282&pf_rd_i=507846
or this JBL, 400 watt RMS, http://www.amazon.com/JBL-ES250PBK-High-Performance-12-Inch-Subwoofer/dp/B00166ZFSO/ref=lp_172568_1_6?ie=UTF8&qid=1357685535&sr=1-6
or BIC, http://www.amazon.com/BIC-America-F12-475-Watt-Subwoofer/dp/B0015A8Y5M/ref=lp_172568_1_3?ie=UTF8&qid=1357685535&sr=1-3
post #17 of 19 Old 01-08-2013, 03:43 PM
Kamikaze13's Avatar
Quoted: 98 Post(s)
Liked: 49
Actually did you have a size restriction?
post #18 of 19 Old 01-09-2013, 07:58 AM - Thread Starter
davidlan's Avatar
No real size restrictions, would prefer an 8" or 10" sub though, as the space I allocated for the sub isn't huge...
davidlan is offline
post #19 of 19 Old 01-09-2013, 08:19 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I favor the Polk 505. OK, its a 12" Check it out. It will probably fit.
You may need to put on a little gel to squeeze it into place but after that just wipe it off with a Kleenex and enjoy! ;-)
arnyk is offline
Reply Speakers
