Suggestions for 3.1 bookshelf speakers under $300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-07-2013, 01:31 PM - Thread Starter
A-Pac's Avatar
Im looking to purchase some front speakers and a subwoofer. The house I recently moved into already has rear speakers in the ceiling, so it'll be 5.1 eventually. It will be used almost exclusively for TV and Movies. Im looking to spend under $300, though more towards $200 range would be preferable...if thats even possible.
Not sure if any more information is needed, if so let me know.
Anyone have any suggestions?
A-Pac is offline
post #2 of 4 Old 01-07-2013, 07:49 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3095
You really need at least $300 for the subwoofer alone. If it were me I would spend the $300 on the front L/R if possible.
Option 1 ($300 on just front L/R)
Ascend Acoustics CBM-170SE ($298 during sale)
Cambridge S30 ($219)
Option 2 (3.0, 3.1, or 2.1)
Front L/R: Pioneer BS22 ($89 on sale at Best Buy)
Center: Pioneer C22 ($99)
Subwoofer: BIC F12 (would put you over budget), Pioneer SW-MK2, or Martin Logan Dynamo 300 or skip completely and save for a better subwoofer from HSU Research, SVS, Outlaw or Rhythmik. The Pioneer and Martin Logan options are really stopgap. Neither extends very low but would do better than your bookshelf speakers for bass.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 4 Old 01-07-2013, 08:04 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Jay1 is offline
post #4 of 4 Old 01-07-2013, 08:27 PM
zieglj01's Avatar
Quoted: 938 Post(s)
Liked: 846
I would look at the Mordaunt Short 10" subwoofer
http://www.accessories4less.com/make-a-store/item/MORDCARN9CAL/MORDAUNT-SHORT-Carnival-9-10-100-Watt-Powered-Subwoofer-Calvados/1.html
And 3 each NXG Pro 4.1 speakers
http://www.amazon.com/Nxg-Pro-4-1-Satellite-Speaker/dp/B0044UHVOK/ref=sr_1_1?ie=UTF8&qid=1357615683&sr=8-1&keywords=nxg+pro+4.1
__________________________________________
Who AM I
Speakers > Snell K7, EOS 150SP
Receiver > Tascam PAR-200
zieglj01 is offline
Reply Speakers
