Bi-wiring/Bi-amping Jamo S606 - AVS Forum | Home Theater Discussions And Reviews
Old 01-08-2013, 10:09 AM - Thread Starter
KidRobot's Avatar
Trying to wrap my head around this new setup I got over the holiday season.
Previous to this, I was running an old Yamaha RX-V457 with a Bose Acoustimass 6 Series II system.
Finally took the plunge to upgrade and picked up a Denon AVR-1713, a Jamo S606HCS3, and waiting for delivery of the Klipsch RW-12D subwoofer to complete the system.
Question is, is there a way I can bi-wire the Jamo S606 floor speakers, so I can use the 8" woofers properly?
My main concern is, the Audyssey setup will be treating the tower speakers as full range, and I'm wondering if I can somehow use the Zone 2 outputs from my AVR-1713 to, perhaps, a separate sub amp?
Is this setup feasible? Or am I just making a bigger deal than needed for these 8" woofers in the towers?
KidRobot is offline
Old 01-08-2013, 10:19 AM
Bill Fitzmaurice's Avatar
Liked: 4631
Bi-wiring doesn't do anything. Bi-amping does, but it's only marginally effective if the passive crossovers inside the speaker aren't bypassed. If you want to try bi-amping your speaker and receiver manuals should tell you how to do it.
Bill Fitzmaurice is online now
