PSB Synchrony One, Amphion Argon 7L and B&W 804 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 36 Old 01-13-2013, 09:03 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
For movies, surrounds matter less. However, for multichannel music, they do matter. If you like music, go with S surrounds. For subs, JL Audio and Velodyne digital drive are top notch but many tout ID brands as better value. I am a fan of sealed subs. The only JLs I have heard were a pair of f212s matched with JBL Synthesis 1400 Arrays with Bryston SP3 and 4B SST2, pretty awesome.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #32 of 36 Old 01-13-2013, 10:04 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 463
I missed the Amphion talk.. too bad. I really like that brand. some of the speakers look a little different, and that was too much for the wife otherwise they would have been in my final decision as well. My local dealer was going to sell me the prio 520s at a very good price. Ive never heard the Synchronys, but congratulations, Im sure they are a great speaker.
Dynaudio Focus 260s, Focus 210C, DM 2/6, Hsu VTF3 MK5 HP, Oppo BDP-103, NaimUniti 2, Naim Stageline N, Pro-ject 2xperience Classic, Marantz SR7007, 60" 4K Samsung LED LCD
callas01 is online now
post #33 of 36 Old 01-13-2013, 10:21 PM
justindo's Avatar
I too have conflicting feelings when it comes to surrounds, although I personally prefer direct radiators and they're easier to resell should you desire to do so down the road.
As for what surrounds to get, if you answer "yes" to the following question, I think the answer is easier, but more expensive: Do you/will you listen critically to a fair amount of high quality SACD, DVD-A, and Blu-ray multi-channel music? If so, get the Synchrony One Bs and don't look back. A fair number of multi-channel recordings utilize the rears for instruments and backup vocals and since music tests a system far more than movies, surrounds using the same drivers and having the same "voice" becomes more critical. You will also not compromise movies at all going that route. It's also important to keep in mind that speakers give you the most bang for your buck in a system, although the surrounds get into a grey area here, hence this debate. If the answer is "no" to multi-channel music, then the answer becomes more complicated but possibly cheaper. I would then ask a second question: Are you an action movie junkie? If "yes" then better surrounds might be worth it, as it really does make a difference having a speaker from the same product series when a helicopter circles around the room, although these type of pans are rare. If you're not an action junkie, then going with cheaper surrounds make more sense as very few non-action films utilize the surrounds for more than ambiance, which can be handled by just about any speaker.
But then there is the issue of your 5-channel amp and aesthetics. On the one hand, it seems a shame to "waste" two of your high quality amp's five channels on inferior speakers. Also, having matching rears is nice for aesthetic reasons and it's arguably strange to have such expensive fronts with such cheap rears. The Imagine Bs have a real cherry finish like the Synchronies and probably sound similar, but they're only a little cheaper than the Synchrony Two Bs which are only a little cheaper than the Synchrony Ones Bs. Ah, the going up the ladder seems to never end! On the other hand, it seems silly to spend a lot of money (more than many people's entire system costs!) on rear speakers when something far cheaper would work just as well for the vast majority of movies. Perhaps the mid-priced Image B6s in cherry (vinyl) might be a nice middle ground. It's not an easy choice and one that I've always had difficulty making. I think it comes down to the two questions I asked, how important aesthetics are, and what you can/are willing to spend.
As far as subs go the JL Audios are awesome if you can/want to spend that much. A system like the one you're putting together warrants it, although HSU and SVS are great "bang for the buck" subs. Members in the sub forum should have some good advice for you.
justindo is offline
post #34 of 36 Old 01-13-2013, 10:28 PM
justindo's Avatar
I also like sealed subs better, especially for music as the bass is tighter, although the sealed ones generally go lower.
I saw some Amphions at Sunil's and they were an odd looking and pricy speaker but I didn't listen to them. Do they make a matching center? The one thing about the PSB Synchronies is that the center is awesome and they are great values.
justindo is offline
post #35 of 36 Old 01-13-2013, 11:00 PM
callas01's Avatar
Quoted: 829 Post(s)
Liked: 463
a couple of their lines have a center channel. I dont know what ones they were, I believe the Ion does, that was the one I auditioned most, and I think the older Prio line had one as well, Im not 100% sure, but I think the Prio was replaced by the Helium??? I think he has dropped the brand, but Im not 100% sure.
post #36 of 36 Old 01-14-2013, 05:24 PM - Thread Starter
olfac87's Avatar
That's all great new advice. I look forward to looking into rears and subs. Thanks everyone for the advice for far.
olfac87 is offline
Reply Speakers
