How do i mount bookshelf if there is no keyhole? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-08-2013, 09:32 PM - Thread Starter
HunterX82's Avatar
I just got the Pioneer sp-bs22-lr and I don't see a way to mount them. I bought a universal mount from monoprice. Can I drill into the bottom of the back? I can attach a picture of the back of you require, I'd just have to find a site to upload.
Thanks for the ideas, my wife would really like them off the end table lol!
HunterX82 is offline
post #2 of 7 Old 01-08-2013, 09:57 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Not particularly familiar with that speaker but seems it doesn't come with mounting options, more meant for stands or shelves than wall mounting. You can drill if you don't mind the aesthetic change. You could also try a mount like the Pinpoint AM-40 if you don't want to drill....
HunterX82 likes this.
lovinthehd is offline
post #3 of 7 Old 01-08-2013, 11:35 PM - Thread Starter
HunterX82's Avatar
I don't mind drilling at all. I'm not familiar with structure of speakers but if a small screw won't hurt the sound great. Thanks
post #4 of 7 Old 01-09-2013, 12:02 AM
lovinthehd's Avatar
Liked: 4775
Only precaution, you might want to make sure of what's on the inside where you plan to drill, I assume there's a crossover network board in there somewhere, so you might want to pull the driver out and take a peek inside first in any case.
post #5 of 7 Old 01-09-2013, 12:02 PM
neuspeed94's Avatar
Small shelves is my recommendation.
neuspeed94 is offline
post #6 of 7 Old 01-09-2013, 01:00 PM
Ak Gara's Avatar
Sounds like you need something like these, speaker brackets.
http://www.richersounds.com/product/speaker-brackets/btech/bt77/btec-bt77
Can hold 25kg and can tilt downwards.
Ak Gara is online now
post #7 of 7 Old 01-09-2013, 01:39 PM
lovinthehd's Avatar
Liked: 4775
Looks identical to what's marketed here as the Pinpoint Am40 I mentioned (and use).
Reply Speakers
