6, 8-ohm speakers in series - dangerous? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-09-2013, 08:42 AM - Thread Starter
lowella's Avatar
Quoted: 16 Post(s)
I have 4 speakers going down an office hallway, at low volume.
I need to add 2 more beyond those and it would be sooo much easier to wire it in series because I can no longer do a home run back to the receiver. I realize this would add to the ohms. The speakers are 8 ohms each and the receiver/amp is 8-16 ohms capable. I currently have 4 speakers hooked up with no problems...what are the chances 2 more are really going to mess it up?
Would this overload the speakers or the amp?
I think the amp has some protection, it is an onkyo 600 series.
Is there another way such as wiring the first 3 as series and the last 3 parallel off the 3rd speaker (etc?)
I imagine that would change the volume of each speaker more, I want them all at the same low volume. Thanks,
lowella is offline
post #2 of 5 Old 01-09-2013, 08:44 AM - Thread Starter
lowella's Avatar
Quoted: 16 Post(s)
PS I can change the db's from 0, -3, -6, would that help?...they are #4103 from monoprice.com
lowella is offline
post #3 of 5 Old 01-09-2013, 09:11 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Not much.
No, if anything it will underload either.
Run a new wire to the connection between the 3rd and 4th.
Take the two existing wires and hook them to the + terminal on the receiver.
Hook the new wire to the - terminal on the receiver.
If you do what you originally planned - put them all in series, then this would reduce the volume a little, but you would probably be able to compensate for that by turning the volume up.
arnyk is offline
post #4 of 5 Old 01-09-2013, 09:16 AM - Thread Starter
lowella's Avatar
Quoted: 16 Post(s)
lowella is offline
post #5 of 5 Old 01-09-2013, 12:11 PM
DonH50's Avatar
Quoted: 1795 Post(s)
Liked: 1330
+1 to Arny. I would hook them all in series, not a parallel-series combination (which would be harder to wire and load the receiver more).
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Reply Speakers
