speaker wire length - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 01-09-2013, 07:19 PM - Thread Starter
Luken8r's Avatar
Im about to wire up some rear surrounds in my living room but the routing of the cable is proving to be a bit of an issue. The easiest way to do it is to go from one side of the room to one speaker and then follow the same run to the other. Is there some rule of thumb for a percentage different in wire length? Im running 14 ga to both, one is going to be about 20 ft and the second is going to be around 35 if I do it this way. Is this difference going to be an issue?
Luken8r is offline
post #2 of 15 Old 01-09-2013, 07:59 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
your fine.
http://www.roger-russel.com/wire/wire.htm
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #3 of 15 Old 01-09-2013, 10:20 PM
ceh383's Avatar
Quoted: 418 Post(s)
Liked: 2584
None what so ever.
Yamaha RX-A2020 | Outlaw M-2200 (x5) | Oppo BDP-103 | Sony CDP-CE500 | Dish VIP622
Definitive Technology BP-8060ST : CS-8060HD : PM-1000 | SVS PC12 Plus | PSA S1500
Sharp LC-70C6400U | miniDSP DDRC-88BM | Belkin PureAV (x2)
ceh383 is offline
post #4 of 15 Old 01-10-2013, 07:02 AM
tezster's Avatar
Quoted: 418 Post(s)
Liked: 283
My surround speaker wire runs are almost exactly the same lengths: 25ft and 40ft run from the same side of the room using 14 ga wire. No problems.
tezster is online now
post #5 of 15 Old 01-10-2013, 07:39 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The issue is not the length, but the resistance of the wire which is dictated by its length and conductivity.
Electrical signals flow through speaker cable at over 100,000 miles per second so the time delay is negligible in any reasonable situation.
As others have pointed out, 12-14 gauge speaker cable is almost a certain guarantee that no matter what, the speaker wire (if properly hooked up) isn't a sound quality issue.
The most common problems with speaker cable is the connections, especially shorting, loose connections, or polarity reversals.
arnyk is offline
post #6 of 15 Old 01-10-2013, 08:55 AM
Bill Fitzmaurice's Avatar
Liked: 4663
Only when the distance differential is at least a thousand miles, give or take. cool.gif
Bill Fitzmaurice is online now
post #7 of 15 Old 01-10-2013, 09:57 AM
noisebeam's Avatar
Quoted: 16 Post(s)
If one of your wires is about 15ft longer you can correct for that by moving the speaker ~5 microns closer to you.
noisebeam is offline
post #8 of 15 Old 01-23-2013, 02:10 PM
spider9's Avatar
I have a speaker run of about 60ft and I'm planning to use 14AUG. I read that website and they mention >50ft isn't a good idea. I should be alright in my 60+ft run?
spider9 is offline
post #9 of 15 Old 01-23-2013, 02:28 PM
Liked: 4663
Use this:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
post #10 of 15 Old 01-23-2013, 04:19 PM
spider9's Avatar
Originally Posted by Bill Fitzmaurice View Post
Use this:
Bill,
I did look at that site and when I plug in my numbers, the output doesn't make much sense to me except the db loss. it's 0.16 and I read less than 1db is not audible!
Honestly speaking, I'm leaning towards the 12 gauge. I don't mind spending the $30 extra to buy the 12 gauge but my concerns is if it's too thick for the receiver or speakers. I have 6 ohm speakers and an old Denon receiver which I'm planning to upgrade with a decent 7.2.
spider9 is offline
post #11 of 15 Old 01-23-2013, 08:51 PM
Liked: 4663
Bill,
Exactly. The reason you want to avoid going beyond 50 feet if possible is to minimize capacitance and inductance losses, and a larger gauge won't help with that.
post #12 of 15 Old 01-24-2013, 09:54 AM
spider9's Avatar
So do you suggest I stick to 14 gauge? I would like to order the wire today from Monoprice.
spider9 is offline
post #13 of 15 Old 01-24-2013, 10:11 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
There would be big arguments about this issue on audiophile forums. Nice to have AVS.
For 60 feet I would likely get 12 AWG just because it's still very affordable. Get CL2 in-wall wire if running through walls or floors.
psgcdn is offline
post #14 of 15 Old 01-24-2013, 11:33 AM
Liked: 4663
You won't hear any difference.
post #15 of 15 Old 01-24-2013, 08:12 PM
spider9's Avatar
Thanks master Yoda and others. and apologize for thread crapping. I would use the same type cable for sub, correct?
spider9 is offline
Reply Speakers
