Paradigm Millenia CT ($699) vs. Airmotiv 5 + XDC-2 ($758) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-09-2013, 07:28 PM - Thread Starter
schung's Avatar
Hi all,
As the title suggests, I'm comparing the two systems. Any input will help!
Also, if you have other suggestions for max budget of $760, please let me know!
Edit: The title should read
Paradigm Millenia CT ($699) vs. Airmotiv 5 + XDA-2 ($748)
I was in a rush when I was creating this thread. Excuse my mistakes smile.gif
schung is offline
post #2 of 5 Old 01-09-2013, 09:31 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
What's an XDC-2?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #3 of 5 Old 01-09-2013, 09:32 PM - Thread Starter
schung's Avatar
oops, meant to type xda-2. Silly me
schung is offline
post #4 of 5 Old 01-09-2013, 09:39 PM
cel4145's Avatar
Liked: 2985
Unless you have an expensive set of cans, you don't really don't need the XDA-2. It's a DAC and headphone amplifier. So you are paying for the headphone amp. The benefits of the balanced outputs will probably not make it worth the cost. You'd be better off to spend the money on speakers.
For that matter, many people on here might say that the ODAC and the Schiit Modi that I recommended in your other thread would be overkill (btw: stop starting new threads--it makes it hard for people to respond with all these different conversations). The ODAC has been tested extensively, and is show to be audibly transparent for reproducing the source. No need to go better than that. I've seen people compare the Modi to the ODAC who found them equivalent, which is why I recommended it as a cheaper, although less portable option.
cel4145 is offline
post #5 of 5 Old 07-10-2013, 10:36 PM
8bitg33k's Avatar
Originally Posted by schung View Post
Hi all,
Which ones did you end up getting and how satisfied are you with your choice?
8bitg33k is offline
Reply Speakers
